LOOKING FOR BHLM in Arizona
Discussion in 'Arizona' started by Annolino122, Sep 15, 2013.
  1. Sep 15, 2013 at 8:45 PM
    Aw9d
    Aw9d That one guy
    :ohsnap:
  2. Sep 15, 2013 at 8:47 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    :wave:
  3. Sep 15, 2013 at 8:56 PM
    fenderpicks
    fenderpicks Well-Known Member
    Heat up the oven to 300 degrees, turn it off, put the light in for 10 mins.
    Take it out, use a flat head and pry at a area until it gives u enough grip and just pull it apart... once u get just 1 area out enough, u will be able to grip it and pull it open....
    To put back together.
    Stick the headlight back in for 10 mins, pre heat to 300 , turn off.
    Just the gray housing (NOT THE LENS)
    After 10 mins is up with the gray housing, go grab the lens and stick it back in.
    Just push it down firm at everywhere. and make sure the clips, clip back in.....
    And that should be it.....
  4. Sep 16, 2013 at 10:12 AM
    Annolino122
    Annolino122 [OP] Well-Known Member
    Evansville
    2014 Tacoma TRD off road
    Okay thank you so much. I think my mistake was clamping it and putting it all back in together
