Looking for differential pictures as reference from members please.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dacon, Oct 12, 2017.
  1. Oct 12, 2017 at 4:59 PM
    Dacon
    Dacon [OP] 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    This is how the angle of the 2nd shaft into differential looks like after 3" lift. Have orders 2* angle shims and still waiting for them. In the meantime I would like to see how the angle looks like on a tacoma stock, no lift, no load in the back on a leveled plane.
    Please post pictures if you have/can. Thanks.
    Tacoma2GR likes this.
  2. Oct 12, 2017 at 7:42 PM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    Get carrier bearing spacers
    tcjacado likes this.
  3. Oct 12, 2017 at 10:04 PM
    Dacon
    Danny
    Gilbert, Arizona.
    ^^^ bad mod.
    mateo_roberto likes this.
  4. Oct 13, 2017 at 5:26 AM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Please explain...
  5. Oct 13, 2017 at 5:26 AM
    CNDSndstrm
    CNDSndstrm Well-Known Member
    Windsor, ON
    2017 Tacoma TRD Off-Road
    I think any mod that includes spacers is considered a bad mod
    Dirty Harry likes this.
  6. Oct 13, 2017 at 7:06 AM
    OffsetPlayer2
    OffsetPlayer2 Cornbread fed
    In the woods and fields, NC
    17 DCSB Off Road 4wd
    Weather Tech floor mats
    I'm curious as well since they were designed to drop the driveshaft back to, supposedly, their factory angles. Never had any of mine lifted so I never needed them so genuinely curious.
  7. Oct 13, 2017 at 8:18 AM
    .jake
    .jake Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    @Dacon I'm in Queen Creek if you want this see it in person. Mine is a DCLB though. Let me know if it helps.
    Edit: I'm 4WD and all stock still.
  8. Oct 13, 2017 at 8:35 AM
    dynamicweight
    dynamicweight Well-Known Member
    Hey, first off, I don't mean to piss in your cheerios, but I don't think you can draw lines on your picture like that. You need to take into account the perspective of the camera unless the camera is also normal to the plane created by the two lines. In other words, completely straight on.
    That being said, I also went outside and took a pic of my 2016 DCLB on a flat surface for you ;) It does have a shell on it though.
  9. Oct 13, 2017 at 8:36 AM
    PEAKIT
    PEAKIT Well-Known Member
    UT
    24 Off Road long bed Premium Taco.
    OME 888 nitro front, SPC upper arms,B110 rear shocks, Timberen bump stops, extended brake hoses, U bolt flip, sway bar delete, Dakar HD leaf pack with extra leaf, Snug top HD shell, MobTown Skid plate, cooper Maxx 255-85-16 4:88 Nitro gears,Spider trax 1.5 spacers, AirBedz, debadge, Pro grill.
    This is what too straight looks like. I have the ome carrier spacer kit. It didnt vibrate with the full OME Dakar pack. A year later I added in the extra leaf and 3 degree shims and it vibrated like crazy. I should have just done a 1 degree or washers under the carrier drop spacer.
  10. Oct 13, 2017 at 9:20 AM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    The shim the OP ordered is also a spacer. (one rotates the axle, the other drops the driveshaft).
  11. Oct 13, 2017 at 1:25 PM
    Dacon
    Danny
    Gilbert, Arizona.
    Thanks, yes I am interested of seeing yours and comparing.
  12. Oct 13, 2017 at 1:28 PM
    Dacon
    Danny
    Gilbert, Arizona.
  13. Oct 13, 2017 at 1:29 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    OP, do you have driveline vibrations since the lift? If not I would leave it alone because that angle doesn't look horrible. If you do, then experiment with those angled shims under your leaf pack but no two trucks are the same so you're gonna have to find your sweet spot
  14. Oct 13, 2017 at 2:07 PM
    Dacon
    Danny
    Gilbert, Arizona.
    Just a bit of shudder/stutter from still to go and after is OK.
  15. Oct 13, 2017 at 2:11 PM
    TireFire
    Olympic Peninsula
    I don't think any amount of driveline vibrations is okay. Hope you get it sorted with those shins. Definitely a better approach than spacing down your carrier bearing
  16. Oct 13, 2017 at 2:37 PM
    PEAKIT
    UT
    3 degree shim
    Greenbean likes this.
  17. Oct 14, 2017 at 11:59 PM
    Dacon
    Danny
    Gilbert, Arizona.
    Have rigged with zip ties an old iPhone and took a video of the driveshaft/pinion angle while driving to the local store in the hood at around 25-35mph. Need to shim it soon, it hunts for best angle in load rotation.
    Is a bit longish at beginning from I set recording till driving.
    https://www.youtube.com/watch?v=TunfIeuX6pQ
  18. Oct 15, 2017 at 12:58 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Why not address axle wrap too/instead?
    Working angle is 0-1 degree on the front u-joint; it has no companion u-joint to help cancel vibration. Middle and rear u-joint working angles are equal, to cancel each other. That is how you set up a 2-piece.
    A carrier drops attempts to zero the middle angle and equalize the front and rear angles; much like a 1-piece non-cv. Not how it's done on a 2-piece.
  19. Oct 15, 2017 at 8:28 AM
    shackley
    shackley Well-Known Member
    Albuquerque, New Mexico
    2018 TRD Pro MT Super White
    RCI rock sliders, Goodyear Ultraterrains 265/70/R16, BAK X2 tonneau
    I wonder what the effect on the ujoints is, since they have no zirc fittings and can never be lubed with such a radical shaft angle?
  20. Oct 15, 2017 at 9:23 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
