Looking for educated opinions on Venomrex wheels PURCHASED
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jmneill, Jan 20, 2019.
  1. Apr 13, 2019 at 2:27 PM
    #141
    Jellero
    Jellero Well-Known Member
    Josh
    NC
    2018 DCLB 4x4 TRD Sport SSM
    A few....
    I just removed my last post....didn't make much sense. I think I'll order the set from Venomrex unless you can see another set or type would work better?? Keep me posted with what you choose and how it works. Thanks so much!
  2. Apr 13, 2019 at 4:23 PM
    #142
    NIKE5ZOOM
    NIKE5ZOOM Active Member
    Caden
    Dickinson, ND
    2017 TRD Sport 4x4
    Those are the same dimensions as the ones I bought with gorilla. I dont think those will work. Wish I had took a picture when I had them test mounted but there is small space between the threads and the wheel and I think a standard lug is going to be the way to go on these. Your options are open on whether you want to do a spline or standard socket though. Both a standard wall 19mm and 21mm socket fit in the wheel.
  3. Apr 13, 2019 at 4:51 PM
    #143
    NIKE5ZOOM
    Caden
    Dickinson, ND
    2017 TRD Sport 4x4
    They still have the conical seat but the holes in the wheels which the studs come through are just a little smaller than any aftermarket wheel I've seen.
  4. Apr 13, 2019 at 5:03 PM
    #144
    jmneill
    jmneill [OP] Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    I went with the aforementioned Gorilla XL's, and they worked for me. Three full additional revolutions over the Venomrex lugs that got, at least in my humble opinion, a very iffy 5 1/2 revolutions to full torque.
    @NIKE5ZOOM 's problem is obviously legitimate. I'll be pulling my lugs for the f'ing 3rd time tomorrow to see what's up. If mine are as they appeared to be when they went on, I'll pull a wheel and mic the ID of the lug holes. The lugs are what they are. If the XL portion of the lug lost 2mm, there wouldn't be anything left but thread and no structure.
    Jellero and 2001 4x4 like this.
  5. Apr 13, 2019 at 5:11 PM
    #145
    NIKE5ZOOM
    Caden
    Dickinson, ND
    2017 TRD Sport 4x4
    Let us know how yours are once you get it off and measure!:goingcrazy: gonna be real confused if yours somehow ended up a different size
  6. Apr 13, 2019 at 6:21 PM
    #146
    jmneill
    SE
    I'm feeling your frustration, believe me.
    1st Venomrex sent my Ford lugs, forcing me to buy some junk lugs at the tire shop to get the rims on temporarily. Venomrex then overnights me the right lugs along with some bling for the trouble. (kudos to them for attempting to make things right) During the installation of these, I decide 5 revolutions just isn't enough for me to feel comfortable off-roading with these wheels. Ergo the XL's get ordered, torqued to spec and I finally felt comfortable.
    Now this.
    I'll post up my findings... : /
  7. Apr 14, 2019 at 2:52 PM
    #147
    jmneill
    SE
    So this sucks. The situation is exactly as @NIKE5ZOOM
    describes.
    I torqued all 24 of the XL lugs down to 80 ft lbs as they slowly sunk into the nice soft rim beneath them. And, despite being torqued to spec, without the seating of the conicle lug properly mating with the rim, I LITERALLY backed out all 24 nuts with a standard length 1/2 in drive ratchet with very, very, little effort. Highly unsafe condition, and while I'm not happy with the situation, I'm incredibly happy @
    Jellero gave me a heads up to NIKE5's findings.
    Not sure where I'll go from here, the Venomrex lugs are back on for the time being. The XL lugs have almost certainly squished the aluminum down around the studs, likely necessitating some mallet action the next time the wheels are removed. (At which point I'll likely have the wheels machined to accept the XL lugs)
    @2001 4x4
    Jellero likes this.
  8. Apr 14, 2019 at 2:59 PM
    #148
    Jellero
    Josh
    NC
    A few....
    Wow! So sorry to see this! Thanks for the quick and quality feedback.
    jmneill[OP] likes this.
  9. Apr 14, 2019 at 3:31 PM
    #149
    NIKE5ZOOM
    Caden
    Dickinson, ND
    2017 TRD Sport 4x4
    Glad that we got it figured out. Would've been quite destructive for you to lose those wheels while driving. I've got some 19mm lug nuts standard length coming in the mail so I'm gonna run with those. luckily you can machine those out a few more mm and remove any damage if it's bad.
    Edit: I sent a message to Venomrex so hopefully in the next version of these wheels they open up the seat a couple more mm so ET lugs can be used. And hopefully they add to their site that currently the ET lugs aren't compatible.
    jmneill[QUOTED][OP] likes this.
  10. Apr 14, 2019 at 3:40 PM
    #150
    Jellero
    Josh
    NC
    A few....
    Did you go with hex or spline nuts?
  11. Apr 14, 2019 at 4:19 PM
    #151
    NIKE5ZOOM
    Caden
    Dickinson, ND
    2017 TRD Sport 4x4
    I just went with a hex. Both will work fine. Just whatever your preference is on looks.
    I think that the wider body of a hex will look better and take some more space in the bolt holes. But thats the only reason I'm going with those. Pretty nitpicky haha. Should get them in midweek.
    Jellero likes this.
  12. Apr 14, 2019 at 4:48 PM
    #152
    Formidable
    Formidable Well-Known Member
    2017 TRD PRO 6MT
    Nice wheels. But... needs more negative offset to push wheels further out IMO.
  13. Apr 14, 2019 at 4:49 PM
    #153
    Jellero
    Josh
    NC
    A few....
    Hey man, its its your ride! I'm sure they'll look great! Thanks for the great info!
  14. Apr 14, 2019 at 8:49 PM
    #154
    Uleth
    Uleth Member
    Would be great if Venomrex or Airborne22 could respond with an official professional opinion. I’ve been running the Venomrex supplied lug nuts for 1000km - no issues personally.
  15. Apr 15, 2019 at 12:12 PM
    #155
    Airborne22
    Airborne22 It's tough being a trophy husband
    Glen
    Suffolk, VA
    2018 Trd Off-Road SB Inferno Red
    See my build page!
    I am by no means a professional, but I will contact Venomrex and see what's up.
  16. Apr 15, 2019 at 1:06 PM
    #156
    Airborne22
    Glen
    Suffolk, VA
    See my build page!
    So help me understand what is happening here. Are the Venomrex lugs not long enough to supply a proper seat? Or are the holes an odd size to not allow aftermarket lugs to seat?
  17. Apr 15, 2019 at 1:52 PM
    #157
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    They seat fine, it’s just the wheels are too thick (or stock wheel studs too short) so the nuts only grab 5ish threads of the stud. I think the issue is trying to find a proper ET nut.
  18. Apr 15, 2019 at 2:03 PM
    #158
    Airborne22
    Glen
    Suffolk, VA
    See my build page!
    From Venomrex..."
    Glen, thank you for reaching out. This issue has never come up and this week we’ve had two separate inquiries on it. I’m assuming this is for a toyota? They are infamous for having short studs actually. We have passed this info along to our engineering department and are looking to get to the bottom of it. At this time I do not have an ET lug nut I can guarantee as this issue is new and in process of being researched. That being said - our Venomrex Tacoma TRD Pro is Driven daily without any issue using our standard acorn seat lug nuts. "
    Mack411 likes this.
  19. Apr 15, 2019 at 7:03 PM
    #159
    jmneill
    SE
    Excellent. Hopefully they take heed of the feedback. :thumbsup:
  20. Apr 16, 2019 at 4:46 AM
    #160
    jmneill
    SE
    As mentioned in NIKE5ZOOM's post #158, the use of any XL lug nut will require a small change In the present design of the wheel.
    There's simply no room for the 'XL' portion of the lug nut to fit in the stud holes.
    NIKE5ZOOM likes this.
