Looking for experienced advice on a lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JWROSE4, Jul 2, 2015.
  1. Jul 3, 2015 at 6:26 PM
    #41
    Larry
    Larry CARL
    CARL
    You can also wrap any quote or part of a post in quote tags.
    Like this:
  2. Jul 3, 2015 at 8:35 PM
    #42
    JWROSE4
    JWROSE4 [OP] Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    So another question....going with the OME kit is there any reason for me to redo the brake lines? Also some are saying they are running the same lift with new UCA's and others are not. Is that just because the ones that are just personally preferred to get new ones or is it recommended to get new ones?
  3. Jul 3, 2015 at 8:41 PM
    #43
    VandalTaco
    VandalTaco Well-Known Member
    Will
    Moscow/Idaho falls, Idaho
    07 DCSB TRD SPORT
    OME 887 lift, 16" XD addicts, 285 duratracs, leather seats, badass JL/Focal stereo
    UCAs recommended but not required for any lift above 2.5". Aftermarket UCAs will allow you to get a better alignment and are said to improve drivability. Not sure about the brake lines. I know for just an AAL you don't need to do anything but I'm not sure what you should do if you were to get a whole new leaf pack.
  4. Jul 3, 2015 at 9:22 PM
    #44
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    You won't need to extend brake lines.
  5. Jul 3, 2015 at 9:23 PM
    #45
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    If you're going to be flexing your suspension I'd recommend extended brake lines.
  6. Jul 3, 2015 at 9:27 PM
    #46
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    OME shocks are designed not to droop beyond what the stock brake lines can handle. If you don't go beyond 3" and use OME shocks you will be fine.
    I went with 884's and Dakars for a 2" lift in front and 2.75" in rear. I wanted to keep the front lift to 2" to avoid higher CV angles, alignment issues, and the need for new UCA's.
  7. Jul 3, 2015 at 9:33 PM
    #47
    Mxpatriot
    Not needed. OME and an AAL won't have the articulation to stretch stock lines.
  8. Jul 4, 2015 at 6:13 PM
    #48
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Does the 285/70/17 rub at all?
  9. Jul 4, 2015 at 6:20 PM
    #49
    Alfred
    Alfred
    California
    He'll yeah! You'll need some trimming and a cab mount chop.
  10. Jul 7, 2015 at 4:28 PM
    #50
    JWROSE4
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Well....it looks like this lift might be happening a little sooner than I was planning. An old lady totally scraped her bumber all the way from my rear wheel across rear and front door. Luckily the scratch is in the rock guard area along the bottom of the truck and after a little buffing and a can of matching spray paint from E&M I am repaired and good to go. Oh and the $1400 the old lady had to pay me for the damages.
