looking for extended rear Bilstein (2012 Tacoma)
Discussion in 'Suspension' started by super_white, Nov 4, 2018.
  1. Nov 4, 2018 at 3:20 AM
    super_white
    super_white [OP] Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I'm getting a parts list together for my lift. I'll be using OME Dakar leafs which provide about 2.75" of lift. I'm looking for Bilstein shocks and all I see are 1" lift and 4"-5" lift. Anything available that you can use with about 3" of lift? May also be doing a u-bolt flip when I install the leafs.
  2. Nov 4, 2018 at 5:52 AM
    Gfunk123
    Gfunk123 Well-Known Member
    '13 limited taco
    3” level kit front, Dakar HD w/ Billy B110’s, 1.25” spidertrax, 265/70r18 Falken Wildpeaks AT3W
    You can use b110’s.
  3. Nov 4, 2018 at 10:07 AM
    MadRiverTaco
    MadRiverTaco Join TW, they said. It's free, they said.
    Brenden
    Waterbury, VT
    2012 Black DCSB TRD OR "Caroline"
    King 2.5 Ext. w/ Compression Adjusters (Front & Rear), Dakars w/ D29XL, TC UCA's & LCA's, ARE CX, 17" SEMA Pro's, 265/70/17 Falken Wildpeaks, BORA spacers, Rigid Side shooter ditch lights, ATHF bedside reinforcements, OME carrier bearing drop bracket, extended rear brake lines, Northstar 27F battery, Yakima Jetsream crossbars, OEM roof rack, OEM skid plate, TRD Pro grill, URD TCAI, 5.7L Throttle Body, BensonX bedside tool mounts, fire extinguisher bedside mount, AMP research bed step, Redline Tuning hood struts, ECGS needle bearing mod, CV Boot slide mod, Differential breather mod, U-Bolt Flip Kit w/ Timbren Bumpstops, A-pillar RAM mount w/ cell phone holder, ProFX tow mirrors with turn signals and heat, "Raptor" lights, DEPO taillights, motorized Pop n' Lock
  4. Nov 4, 2018 at 10:34 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Thank you both.
    Most of the parts I've been looking at are from Headstrong.
    I thought the B110's were going to be too long.
  5. Nov 4, 2018 at 11:53 AM
    Navigator1
    Navigator1 Assistant to the Regional Manager
    Spokane WA
    18 TRDORDCLBCEMENT
    These say they’re for 2-3.5” lift. Probably a safer bet than the b110s just based off measurements.
