looking for facts about the prerunners
Discussion in '2nd Gen. Tacomas (2005-2015)' started by janelle2388, Oct 5, 2012.
  1. Oct 5, 2012 at 11:14 AM
    janelle2388
    janelle2388 [OP] Well-Known Member
    Corey
    Montana
    09 tacoma access cab SR5
    3 inch icon lift, dual exhaust, 17 inch pro comp rims, tinted tail lights, black badges, BHLM, T-Rex eye lids, 10" alpine type R sub, alpine deck, alpine amp, K&N CAI, icon UCA's, 2" AAL, 32" led light bar
    ok i dont mean to come off as a retard, but what exactly is a prerunner. i tried looking it up but all i got is that its a 4x2 not a 4x4, and there cheaper then a 4x4 brand new (base price). is that all there is thats different? i grew up way up north and never even heard of them till i lived in mississippi for a little. so im just looking for facts about the trucks and not opinions on what is better.
  2. Oct 5, 2012 at 11:15 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    the prerunner is the same truck as the 4x4 but minus all the 4x4 stuff. literally the same everything besides the tranny, diff, driveshaft etc
  3. Oct 5, 2012 at 11:17 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    prerunner is a 4x4 with the 4wd removed, it has the same suspension, compared to the 5 lug 2wd only, lifts etc if they fit on a 4x4 most likely they will fit pre runner.
    also with a prerunner you get 4x4 height
    EDIT: beat me to it
  4. Oct 5, 2012 at 11:24 AM
    2004TacomaSR5
    2004TacomaSR5 Sentinel Prime
    Jon
    Montana
    2004 Tacoma DCSB & '79 Toyota Pickup 4WD
    A fellow Montanan! Welcome to TW! Yeah, basically all a Prerunner is is a 2WD on a 4x4 chassis. They can come in all the TRD configurations just like the 4x4 along with the simple SR5 package.
  5. Oct 5, 2012 at 11:26 AM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    It's the truck that does a "Pre-run" of the trail to make sure it's safe for the almighty 4x4
    :stirthepot:
  6. Oct 5, 2012 at 11:26 AM
    97yota4wd
    Eric
    Mesa, AZ
    but the 5lug 2wd and the 6lug 2wd prerunner are completely different trucks.
  7. Oct 5, 2012 at 11:28 AM
    janelle2388
    Corey
    Montana
    ok so if i want to keep the towing and weight load and dont need the 4wd go with the prerunner, right? and better MPG? sorry to ask looks like i might be moving south and if i dont need to spend the money on the 4wd and i dont need it i might go with a prerunner.
  8. Oct 5, 2012 at 11:30 AM
    97yota4wd
    Eric
    Mesa, AZ
    yes, and they will get about 0-2 mpgs better
  9. Oct 5, 2012 at 11:41 AM
    seric007
    seric007 Well-Known Member
    prerunners as super-duper awesome. FACT.
  10. Oct 5, 2012 at 11:45 AM
    seric007
    someone recently did a prerunner to 4wd conversion. differences you ask? Different spindles up front, obviously the t-case and a different bell housing on the rear of the transmission (exact same internals, however). Different driveshaft due to t-case and the transmission mount is mounted about 2 inches forward.
    otherwise, they are the same truck. :D
  11. Oct 5, 2012 at 11:46 AM
    The Traveler
    SoCal
    Don't forget that little switch we have too ;)
  12. Oct 5, 2012 at 12:40 PM
    seric007
    oh you mean the dash trim piece that has the defective hole cut in it on the 4wd? good thing they patched it properly in the prerunners.
    :laugh:
  13. Oct 5, 2012 at 12:52 PM
    shemp
    shemp Well-Known Member
    Because of their lower weight, prerunners have a higher payload capacity than 4x4's. Slightly over 3/4 ton for the 4-cyl.
    MPG will NOT differ, except slightly in CITY driving. The extra weight requires more energy to accelerate on a 4x4. On the highway, there is no difference. If EPA says any differently, they're LIARS (which they are, I guarantee it. 4x4 4cyl does an easy 6 mpg better than EPA claims).
  14. Oct 5, 2012 at 12:58 PM
    shemp
    Eh, what? There are no parts listed as "spindles". There are steering knuckles (same for prerunner and 4wd), and there are hubs (different for prerunner and 4wd).
  15. Oct 5, 2012 at 1:02 PM
    97yota4wd
    Eric
    Mesa, AZ
    no, the spindles are different. the hubs and the steering knuckles come in 1 unit, i believe.
    i dont know the actual word for them, but everyone calls them spindles.
  16. Oct 5, 2012 at 1:08 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
  17. Oct 5, 2012 at 1:21 PM
    Brandon###
    Brandon### Well-Known Member
    http://www.toyota.com/tacoma/specs.html
    You can compare the #'s yourself. Towing capacity is the same. Payload is higher (135lbs) for the prerunner.
    If you ever think you might need 4x4, get a 4x4. The option is <$2,000. You won't regret it.
  18. Oct 5, 2012 at 1:25 PM
    seric007
    spindle
    these are obviously not stock.
  19. Oct 5, 2012 at 1:32 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    This
    If you lift them you don't need to be concerned as much up front as there are no 4WD components , and you can use LIFT SPINDLES
  20. Oct 5, 2012 at 4:10 PM
    janelle2388
    Corey
    Montana
    thank you very much, wish i found that on my own.
    thanx everyone else i appreciate the info
