Looking for first Tacoma. Would you buy one of these?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Staggs, Oct 11, 2019.
  1. Oct 11, 2019 at 2:53 AM
    Staggs
    Staggs [OP] Active Member
    https://boston.craigslist.org/gbs/ctd/d/lawrence-2003-toyota-tacoma-v6-2dr/6995955224.html
    https://hartford.craigslist.org/cto/d/oakville-2004-toyota-tacoma-sr5/6975506073.html
    Looking into getting my first Tacoma.
    Originally wanted a first gen due to the size but I've also been looking at 2nd gens as an option due to the fact there are more available in good shape.
    I found these 2 first-gens near me and both seem like good options, at least to me.
    I was just wondering what any ody else thought regarding condition and price.
    The first thing I will look for is rust on the frame and I'm hoping both sellers will allow me to do a leakdown test if I'm able to get a mobile compressor that can give me 100psi.
    What should I know about these motors in terms of longevity.
    And if they re in really good shape I plan on rust treatments and to keep them going for a long time including an engine swap once the original wears out.
    Also, I was wondering if first gens also came in 4cyl 4WD.
    GQ7227 likes this.
  2. Oct 11, 2019 at 2:59 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Yes they came in 4 Cyl 4WD. I converted my I4 PreRunner to a 4x4 using stock IFS parts.
    Hamer95USA likes this.
  3. Oct 11, 2019 at 3:40 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    The first ad doesn't mention the frame nor does it show pics of the frame. Your biggest priority will be to ensure you aren't getting a bad frame. Most everything else can be remedied or repaired by a DIY.
    The second ad says frame is fine at least. And it looks like it is in the pic of the tire. Especially in your location, check the frames thoroughly. Don't want you to be that sad story we read every now and then on here, someone wondering what their options are couple months down the road of buying their first gen and they didn't inspect thoroughly the frame and it's junk. :( sad stuff indeed
  4. Oct 11, 2019 at 3:48 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Looks like the red one only got half a lift kit installed.
    Hamer95USA and Rubberband like this.
  5. Oct 11, 2019 at 4:04 AM
    Staggs
    I've never had a 4cyl give me a hard time so I'm partial to them but I've read good things about the 3.4 V6 in first gen Tacomas.
    GQ7227 likes this.
  6. Oct 11, 2019 at 4:08 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Cant go wrong with either in the 1st gens. Only real "negative" difference is the V6's need a timing belt every 90k. My 2.7 inline 4 has been trouble free for the 40k miles Ive put on it in a little over 2 years. Only thing Ive done is new spark plugs when I first got it and regular oil changes.
    GQ7227 likes this.
  7. Oct 11, 2019 at 5:46 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i thought you've had your Taco for longer than that!?
    what about the 2.7 valve cover gasket? do those hold up better/longer than the 3.4
  8. Oct 11, 2019 at 5:54 AM
    DLillest
    DLillest Well-Known Member
    Quebec, Canada
    2007 SBM DCSB 6MT 4x4
    That burgundy one has a super clean interior but im a sucker for black. Not sure if the black has a v6 or 4cyl. I'd go with the v6 if I had the choice.
    TacomaJunkie8691 and Hamer95USA like this.
  9. Oct 11, 2019 at 5:58 AM
    TacoMike
    TacoMike Well-Known Member
    Pennsylvania
    '19 SR AC Utility 4x4
    I had a 2004 2.7L 4x4 for 15 years with 130,000 miles on it. That motor never leaked a drop of fluid. I'd still have it if I didn't total it. Changed a few emission sensors over the years, had the frame replaced. The steering rack had to be replaced. A hole rusted in it where it mounted to the frame. Other than that it was a fantastic truck.
    Hamer95USA and GQ7227 like this.
  10. Oct 11, 2019 at 7:51 AM
    Staggs
    Black is v6
    Hamer95USA and DLillest[QUOTED] like this.
  11. Oct 11, 2019 at 11:19 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Go for the 04. The 03 seems pretty cheap for what it cliams to be, and since the pics won't load I can't even really look at it, lol.
    Plus they seem WAY more interested in telling you about their financing than anything about the truck...
    Definitely inspect the frame very carefully. Don't take their word for it. Take a hammer with you and tap around on the frame, and pay close attention to the front leaf spring hangers.
    Assume NONE of the maintenance has been done on either vehicle unless they produce receipts.
  12. Oct 11, 2019 at 12:02 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Red one seems a little sketch. But if it's close go check it out and bring a mechanic buddy with you. And the black one is good from the looks and ad
  13. Oct 11, 2019 at 12:36 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Surprised no one saw right away the missing lug nut, or worse, stud, missing from the front wheel on the red one.
    CrustyTaco likes this.
  14. Oct 11, 2019 at 12:39 PM
    Staggs
    Thanks.
    I'm leaning towards the back one.
    If only he would get back to me!
    I don't know many people into cars sadly.
    Hope that changes now that I'm here.
    GQ7227 likes this.
  15. Oct 11, 2019 at 1:09 PM
    RedManRocket
    Red
    2002 Double Cab LT
    It'll change for sure, also the size of your wallet changes dramatically :D
  16. Oct 11, 2019 at 1:17 PM
    geoyota760
    geoyota760 Allergic to pavement
    PHOENIX, AZ
    2019 TRD OR
    5.29 Nitros Bilstein ICON Kansei BFG
    Had an '03 DCSB...loved it. Very reliable and easy to source parts and repair DIY with this forum.
    The second black Tacoma would be my choice...however, taking your time with this process and getting familiar with (and not jumping at the first you look at) the Tacoma's out there will help you choose the right truck for you.
    When I was shopping, I spent about 3 months and viewed 11 trucks before I pulled the trigger on my 03'. As others have stated here, I saw a lot of shiny tops with rusty frames asking for top dollar. Also saw some guys with lifted Tacomas and blown CV's with axle grease all over the undercarriage. And good catch on the missing lug nut @Kwikvette
    Not to mention that odd raked out lift in the rear...I'd steer clear of that rig.
    Small missing details like that always make me wonder...what else is missing?
    Owner records and receipts made me warm and fuzzy too...good luck man, and prepare for your wallet to become much lighter posting up here.
    Cheers...
    :cheers:
    joe25rs likes this.
  17. Oct 11, 2019 at 2:16 PM
    tony2018
    tony2018 Well-Known Member
    man...saw a tow bed pick up a dcsb 1st gen, burgundy red or something like that. Wanted to follow but a red light kept me from doing that.
  18. Oct 11, 2019 at 2:16 PM
    jbrandt
    Justin
    Pics wouldn't load for me earlier, but yeah, um, there are supposed to be SIX of those per wheel, lol... Not that it's difficult to fix, but it shows (like I mentioned earlier) that the dealer is likely pretty shady. As someone else already mentioned, looks like they forgot to lift the front.
    I was sketched by this add even before I could see the pics, though.
  19. Oct 11, 2019 at 3:04 PM
    jbrandt
    Justin
  20. Oct 11, 2019 at 4:48 PM
    lmhp1985
    lmhp1985 Well-Known Member
    Boston MA
    2004 Tacoma Silver
    I’m thinking about putting mine on sale but she is more expensive then those, this is 2004 automatic transmission V6 with 28k miles, I bought last May since I been driving 1k a month. I live RI and work in Boston
    GQ7227 likes this.
