Looking for future-proof small lift
Discussion in 'Suspension' started by ekard, Jan 8, 2010.
  1. Jan 8, 2010 at 1:44 PM
    ekard
    ekard [OP] Well-Known Member
    San Jose, CA
    2011 DC SB 4X4 OR
    TRD Exhaust, Bilstein 5100's, Eibach coils, TSB Leaf pack, Toyota Bed Mat and D-Rings, Dakine Tailgate Pad, Wet Okoles, WeatherTech Floormats, PA15-TOY iPod Adapter, Goodyear Duratracs 265/75/16, SCS F5 wheels
    So I'm pretty happy with my new truck (2010 DC SB 4x4 OR). I got it for hauling my dirt bike and it's doing a pretty good job so far. I plan to get the TSB leafpack next week, so that should make it even better.
    I am a little hesitant that I won't like the resulting rake though, so I've been looking at solutions for lifting the front a bit. I don't want a front and rear lift yet since I prefer to keep the moto loading somewhat reasonable. I also don't want to completely eliminate the rake since I don't want a saggy rear end when loaded.
    So I'm guessing that I'll be looking around the 1-1.5" front lift range as a starting point right? That said, if whatever I get has the capability to go higher, that would be nice if my interests change down the road. So from what I can tell, my options are:
    $ - 1500's set at 0.85 or 1.75
    $$ - 1500's set at 0.00 + Eibachs
    $$$ - Toytec Coilovers (minimum 1") (still a 1500 shock)
    $$$$ - Icon Coilovers
    I'm not interested in spacer kits. And as much good stuff as I've read about them, OME seems out since it's around a 2.5" lift minimum.
    Money isn't a deal breaker, but I don't want to waste it on something I don't need.
    I like the idea of the Toytec and/or Icon's being infinitely adjustable within their lift range. (I assume you could tweak the individual fronts to account for lean, instead of having to use a spacer right?)
    I'm pretty comfortable with the way the truck drives and handles bumps right now. A stiffer ride doesn't bother me, since it will be nowhere near as stiff as my Subaru, but I don't want to sacrifice off-road flexibly too much.
    I guess some questions I have are:
    - Are the Eibachs worth getting over the TRD OR springs that I have?
    - Are the Toytec springs worth getting over the Eibachs (ride wise, not including the extra adjustability)?
    - Has anyone compared the Toytec and Icon setups?
    - Is there anything else I should be considering/researching?
  2. Jan 8, 2010 at 1:47 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Keep it stock and clean. You will save about 10-15k!
  3. Jan 8, 2010 at 1:50 PM
    ekard
    San Jose, CA
    2011 DC SB 4X4 OR
    Not possible. Half the fun in owning something is making it your own.
  4. Jan 8, 2010 at 8:03 PM
    choptop
    choptop Molōn labe!
    Scott
    Austin, TX
    2014 4Runner TEP
    If I had the $$$ adjustable coil overs would have been my first choice. I went with the Eibach/ 5100 setup at 0 and it worked out nicely. Any of the choices you have listed are good options.
  5. Jan 8, 2010 at 8:08 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    i agree, definetly customize it :D its gotten me broke and in a HUGE amount of trouble with the gf :( but she tends to enjoy it every once in a while when i take her wheeling AND she still loves me <3
  6. Jan 8, 2010 at 8:08 PM
    HBMurphy
    Paul
    So California Coast
    None
    I tried!
  7. Jan 8, 2010 at 9:38 PM
    spiceman
    spiceman Well-Known Member
    Hawaii
    '07 4x4 DC OR, Desert Sand Mica
    Window Tint, Sockmonkey bed decals, Eibach 1.6" coils, 5100s front (set @ .85) / rear
    I am installing Eibachs with 5100s set at zero this weekend. 5100s front and rear. I wanted to reduce the rake as well and that is the option I chose.
  8. Jan 8, 2010 at 9:48 PM
    Tacozona
    Tacozona Well-Known Member
    WA (state of)
    2002 Xtra Cab TRD 4x4
    ARB bumper Warn winch 3" suspension lift canopy with safari rack AR Teflon Mojave wheels BF Goodrich MT
    Great advice. I should have listened. :rasta:
  9. Jan 8, 2010 at 9:55 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    18 PreRunner TRD OffRoad DCSB
    Well three of those 4 options involve billy 5100's, so why not just get those first and see if you want more lift/springs later?
  10. Jan 8, 2010 at 10:11 PM
    HBMurphy
    Paul
    So California Coast
    None
    That was my intent... little did I know! about 15k later!
  11. Jan 8, 2010 at 11:12 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    go for the gold! ICONS!!
  12. Jan 9, 2010 at 9:10 PM
    spiceman
    Hawaii
    Installed my Eibach 1.6" coils with 5100s front (set at 0) and rear. It rides smoother than stock. They lifted the front right at 1.5". 34.5" prior and 36" after. The rear is almost exactly 37" (stock /no TSB). All measurements from the ground through the center of the hubs. I have already had my alignment and I am very happy. The lift was just what I was looking for.:bananadance:
    Before
    After
  13. Jan 10, 2010 at 3:19 AM
    bucksnort06
    bucksnort06 Well-Known Member
    pete
    cape cod
    09 TRD
    4 leaf TSB, 5100's all four, eibach 1.6" coils, ARE cx cap, yakima racks, weathertech floor mats/rain guard/hood guard.
    +1 on the eibachs and billsteins for a mild lift. Took most the rake out of my truck and rides awesome!!
  14. Jan 10, 2010 at 10:34 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    What's the different spring rates between stock coils and billies @ 1.75 vs Eibachs and billies set to 0? Do Eibachs require any kind of extra maintenance over stock coils?
  15. Jan 10, 2010 at 10:59 AM
    spiceman
    Hawaii
    Since TRD OR springs are progressive, I think it would be hard to determine the spring rate pre-loaded @ 1.75". Since they are progressive the rate increases during compression. I think the initial rate of TRD OR springs is 540# and the Eibach spring rate is 620#. I may be imagining things but the Eibachs with Billys set @ 0" ride smoother than the stock TRD OR set-up. It only lifted by front about 1.5" and left about a 1" rake, exactly what I wanted. The alignment is back in specs and the ride is smooth.
  16. Jan 10, 2010 at 11:17 AM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    well if we all listened to that,we would'nt have such a great site,right.and stimulate the economy.lol.
  17. Jan 12, 2010 at 10:42 PM
    spiceman
    Hawaii
    After I drove a few days the Eibach springs seemed to have settled. The lift at the 5100 stock settings, Eibachs only, was Left: 7/8" and Right: 1". I went ahead and increased the 5100s to .85. The total lift now is Left: 1 5/8" and Right 1 3/4". From what I have read in this post it appears the 4x4s need the .85 setting on the 5100s to achieve more than 1" of lift. The PreRunners appear to get more lift at the stock setting.
    Suspension mods to date: Eibachs, 5100s on all four corners, NO 1/4 spacer, NO TSB.
    Measurements before lift:
    LF: 34 1/2"
    RF: 34 3/4"
    LR: 36 7/8"
    RR: 37 1/4"
    Measurements with 5100s at stock setting:
    LF: 35 3/8" -> 7/8" of lift
    RF: 35 3/4" -> 1" of lift
    LR: 36 7/8"
    RR: 37 1/4"
    Measurements with 5100s at .85:
    LF: 36 1/8" -> 7/8 + 3/4 = 1 5/8" of lift
    RF: 36 1/2" -> 1 + 3/4 = 1 3/4" of lift
    LR: 36 7/8"
    RR: 37 1/4"
    I ended up with 3/4" of forward rake both left and right. I will post pictures soon. I hope this helps some that are trying to decide on what settings to use for the 5100s. I will now need to get a new alignment but I will drive it for a while to make sure it has settled and that I am satisfied.
  18. Jan 13, 2010 at 4:34 AM
    sincitytaco
    sincitytaco Well-Known Member
    Las Vegas
    Icons, Bilstein 5100, Rear Leaf TSB, 17x9 American Racing Chamber Teflon, 275/70/17 Goodyear
    I can't tell a difference from the before and after, LOL.
    I have the eibachs on my Double Cab and the front actually sits higher than the rear. I like it though. I have them on the TRD bilsteins and They definately ride firmer though than stock. I wonder how you say the 5100s ride smoother when they are actually dampened firmer than the OEM versions, Weird.
  19. Jan 13, 2010 at 5:47 AM
    Burns
    Burns Excellent Member
    NJ
    17 DCSB Off-Road
    None!
    I went the cheap route and installed the Eibachs on my stock TRD billys and I got about 1.5" of lift and I am very happy with them. I have the tsb rear so I have a little bit of rake which is what I wanted and I just got my tires installed yesterday (265/75/16's Firestone Destination AT's) and I am pleased with the way it came out . :D
  20. Jan 13, 2010 at 1:21 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    I have SR5 package, no TRD Springs
    1. :worthless:
    2. This is an interesting option. I wonder which rides better, stock coils on billies @ 1.75, or eibach with stock shocks. Thoughts?
