Looking for good 3" lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by staplak, Nov 29, 2009.
  1. Nov 29, 2009 at 1:35 PM
    staplak
    staplak [OP] Well-Known Member
    Guntersville, AL
    04 Black Prerunner SR5 DoubleCab
    Thule Xsporter Rack
    I have just bought a 2004 prerunner and was wanting to add 3 inches under it. I was looking for some advice on which direction i should go under 300 dollars. I will not be offroading in it. I want it just for looks.
  2. Nov 29, 2009 at 1:50 PM
    jodiddly33
    jodiddly33 Well-Known Member
    Jonah
    DFW
    2010 Golf TDI
    www.toytech.com has a ton of different lift options. I'm in the same boat as you, mainly want a lift for looks and on a budget. I believe there's one there that has spacers or coils up front and an AAL in the back in your price range.
  3. Nov 29, 2009 at 4:43 PM
    Werloc
    Werloc Large Member
    Bob
    Central, NJ
    2003 Double Cab 4X4 TRD 3.4 V6
    +2
    I want to add a few inches, and on a major budget. Still saving for my tires which should be just around the first of the year. Going to get 32", so I "may" need to do the lift.
  4. Nov 29, 2009 at 4:47 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    spacer lift. The best spacer lift is the type of spacer that goes on top of the stock coilover. Dont use a spacer that goes between the spring and top plate. PITA to install. Ive got the procomp spacers and i maintained stock ride. Procomp spacer and readylift are exactly the same and are good choices for a tight budget.
  5. Nov 29, 2009 at 4:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Check out the Bilstien 5100's. You can get a front and rear set for under 300 bucks from Downsouth motor sports. They will give about 2.5" lift up front, and you can get an AAL for the rear.
  6. Nov 29, 2009 at 4:59 PM
    Yoytoda
    Roland
    completely stock
    when adjusting the billies to 2.5" do you lose any down travel? with a top plate spacer you still maintain 4up 4down stock travel.
  7. Nov 29, 2009 at 5:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    With any lift, (except long travle) you loose down travle. The top plate spacers are bad, as the extend the length of the assembly, and can cause the ball joints to wear excessivly, and shocks to break when hitting a large bump. They do NOT keep the "4 up/4down" stock travel, as the bump stop limits up travel, and the ball joint limits down travel.
  8. Nov 29, 2009 at 5:39 PM
    jodiddly33
    Jonah
    DFW
    2010 Golf TDI
    Chris, would the stock springs be okay with billies on all four corners at 2.5"? Would there be a need for uca's?
  9. Nov 29, 2009 at 5:49 PM
    Yoytoda
    Roland
    completely stock
    So with the billies or SAWs or king shock, the shock limits the down travel rather than the balljoints?
    EDIT: I have to respectfully disagree. I have a 2.25" spacer and when installing it i had to jack up the lca to get the top nuts on the co started. once the co with spacer was in place i had no problem pulling the uca down and tightening nut on the bottom and the joint had room for more down travel but i believe the shock limited down travel. The SAWs are about 2.5" longer than stock shocks (overall) and do not require ucas from what i can remember
  10. Nov 29, 2009 at 6:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The Ball joints are the end limiting factor. If useing extended shocks, you need to use an UCA that allows for more travle. The OEM shocks limit the travle to a limit near the end of the ball joint travel. Anything longer, damages the ball joint. By useing a Top plate spacer, you are efectivley makeing the shock assembly longer, thus when extending, its doing so against the ball joint. When this happens, the ball joint is damaged, and if the ball joint stops the shock abruptly enough, this will happen:
  11. Nov 29, 2009 at 6:06 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats why, if useing a shock capable of more travel than OEM, you really should consider upgrading UCA's.
  12. Nov 29, 2009 at 6:15 PM
    Yoytoda
    Roland
    completely stock
    Ok that make sense. I was under the impression that the 5100s were extended travel shocks...making them no different than cos or top spacer
  13. Nov 29, 2009 at 6:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Nope. They are OEM replacements. What sets them apart, is they are larger in diameter than the OEM, and valved better for a preloaded spring rate, or heavier spring rate from an after market coil.
  14. Nov 29, 2009 at 6:25 PM
    Yoytoda
    Roland
    completely stock
    I really appreciate the info and im sure this can deff help the OP.
    I will be swapping the spacer out for either billies or maybe spend the money to upgrade to SAW COs and Total Chaos UCAs to do a mid travel but more for offroading flex (rock crawling) rather than hauling across the desert
  15. Nov 29, 2009 at 7:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That would be a good set up. Also check out OME.
  16. Nov 30, 2009 at 7:10 AM
    staplak
    Guntersville, AL
    Thule Xsporter Rack
    I think u give me the wrong web page?
  17. Nov 30, 2009 at 7:16 AM
    staplak
    Guntersville, AL
    Thule Xsporter Rack
    When u add the shocks does that give you your height or do u have to put the spacers and AAL on there also?
  18. Nov 30, 2009 at 7:18 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The shocks have 4 settings for the spring seat. So 4 lift options. 0", .85", 1.75", and 2.5". For the rear, you would need an AAL.
  19. Nov 30, 2009 at 7:31 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    toyteclifts.com
  20. Nov 30, 2009 at 7:45 AM
    staplak
    Guntersville, AL
    Thule Xsporter Rack
    Im guessing this option would give me a better ride vs putting spacers in the front and blocks or shackles in the back?
