Looking for green 4157 LED bulbs
Discussion in 'Lighting' started by damoihunta, Dec 20, 2012.
  1. Dec 20, 2012 at 3:09 PM
    damoihunta
    damoihunta [OP] TACO's anyone???
    2012 double cab 4x4
    Procomp 3" lift 33" on XDs LED gauge swap LED map and dome lights grill craft mesh grill Rigid Industries D2s floods Rigid Industries SR6 driving lights Soon to come.
    Okay so, I want to put green 4157 wedge bulbs in for my DTRL 4157 bulb but can't find 4157 LEDs. Everything is referenced back to a 3157 LEd bulb. I tried it but it doesn't work. The 3157 doesn't light up when it's supposed th and blinks really fast when I turn on the turn signal. Anyone can help? What do I need to do? I've been looking on line for bulbs but no luck
  2. Dec 22, 2012 at 5:53 AM
    09DBLCAB09
    09DBLCAB09 Well-Known Member
    A LED bulb is going to blink fast for your turn signal regardless unless you put a resistor in or a new turn signal relay
  3. Dec 26, 2012 at 7:58 AM
    ihadmail
    ihadmail Well-Known Member
    Chapin, SC
    2008 4Runner SR5 4x4
    Car seat
    You can buy a blink rate controller for a motorcycle and install it with the LED lights to make them blink at the right speed.
  4. Dec 27, 2012 at 12:33 PM
    damoihunta
    2012 double cab 4x4
    Will the 3157s work replacing the 4157s as the DTRLs. Will they work the same way? Just with a resistor? I was told to just Mod the opening so that the bigger bulb will fit into the hole?! And where do I get the motorcycle blink rate controller ?
  5. Dec 27, 2012 at 12:50 PM
    ihadmail
    Chapin, SC
    Car seat
  6. Dec 27, 2012 at 12:53 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
  7. Dec 27, 2012 at 6:11 PM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    There isn't a flasher for the dtrl model trucks. That flasher is for a non dtrl model and will not work on any truck that has the dtrl function. Its an entirely different plug. As far as green dtrls I havet had anyone ask and im curious to see if I can make that happen.
    Oh and when they say 3157 or 4157 the bulb is the exact same. The difference is the way that it is wired.
    I have white/green but none that are solid green
  8. Dec 27, 2012 at 9:05 PM
    damoihunta
    2012 double cab 4x4
    So DTRLs white and blink green? Cool, I'd like to check those out... Can you get or make green/ amber? Where to buy? Do you have a web site?
  9. Dec 27, 2012 at 9:10 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    It is neither 3 prong nor 4 prong.
    Trucks that do not have DRL have an 8-pin flasher. The replacement from Superbright will cure hyperflash.
    Trucks that have DRL have a 12-pin and there is no replacement available that will cure the hyperflash.
  10. Dec 27, 2012 at 9:11 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Only difference between 3157 and 4157 is the wattage.
    4157 burns a little hotter.
  11. Dec 27, 2012 at 9:21 PM
    csjumper2003
    Savannah, GA
    I can get em if I get more interest in them as I have to buy like 50 at a time. I dont have a website yet, working on that. I do have a thread I set up on the 2nd gen for sale thread though.
  12. Dec 28, 2012 at 2:13 PM
    csjumper2003
    Savannah, GA
    Pm sent
