Looking for help re towing capacity- 05 4x4 6cyl access cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bellebuoy, Sep 28, 2014.
  1. Sep 28, 2014 at 2:43 PM
    Bellebuoy
    Bellebuoy [OP] Member
    Salt Spring Island BC Canada
    05 Tacoma 4WD 6 speed std
    My Taco has 6 spd-manual/six cyl. Extra main leave and lifting shocks on the front. I currently towing a 19' travel trailer App 4000#.
    Wondering who has experience in towing a larger trailer? Understand Taco is meant to be rated for 6500# & 500# hitch weight?
    I'd appreciate any feed back and comments.
    Cheers
    Bellebuoy
  2. Sep 28, 2014 at 3:16 PM
    Pool Runner
    Pool Runner Well-Known Member
    Nor Cal
    '14,TRD/OR, Entune & Nav '13 Subaru Outback
    Lowes Slimline Tool box, OEM Bug shield.
    That 4,000 should be no sweat for the truck , but I recommend a brake controller and WDH (weight distribution hitch).
  3. Sep 28, 2014 at 4:26 PM
    Bellebuoy
    Thanks for the come back. I do have elect brakes and a good equalizer hitch. Forgot to mention these points. 4000# is what I'm towing now. Wondering what experiences folks have had with 5000 & 5500# or.... .
    I did pull a mini excavator on a fairly good size flat deck the other day and it was a bit of a grunt but did it fine. Looking to get feed back on full time towing travel trailer larger than the 4000#'s that I have now.
  4. Sep 28, 2014 at 4:36 PM
    Mobtown Offroad
    Mobtown Offroad Boss
    Joe
    Harrington, DE
    2002 SR5 4Runner
    Having a manual transmission is better for towing. You won't have to rebuild it as often like an automatic because they don't get as hot. But, you will have clutch replacements. I'm not sure how often, depends on how often you're towing and how much weight. But it's far easier to replace a clutch than rebuild a transmission. And when it comes time, get an HD clutch.
    You'll be fine trailering 4000lbs. If you're concerned about longevity, replace all gear oils with Redline (transmission, rear differential) and get a rear differential heat sink cover. Keeping the oils cool is key to max life of truck.
  5. Sep 28, 2014 at 4:41 PM
    TrdSurgie
    TrdSurgie revised
    Oahu
    You should look at you're rear axle.
  6. Sep 28, 2014 at 4:42 PM
    Mobtown Offroad
    Joe
    Harrington, DE
    2002 SR5 4Runner
    What do you mean?
