Looking for help with my front 5100 bilsten struts / bottoming out
Discussion in 'North West' started by Hiluxborn, May 17, 2016.
  1. May 18, 2016 at 2:31 PM
    inesshell
    inesshell blah blah blah
    All stock Superwhite 10' AC
    that coil does not look like it has much room left to compress.....shock should have plenty of room to compress. If you decide on replacing, I personally like ome nitro shocks over the gas used in 5100. Pair it with a match coil will give you a more cushioned ride IMO.
  2. May 18, 2016 at 3:53 PM
    Hiluxborn
    Hiluxborn [OP] Well-Known Member
    Clint
    2002 white tacoma trd
    5 inch tuff country lift, adjustable bilsten 5100's. Toyo MT's on 16' wheels. Magma flow muffler. Viper alarm/auto start. Moog sway bar links,tie rod ends and lower control arm bushings.
    The tuff country lift in its installation instructions says to use the stock coils ad a stock length strut. With this being said I'm not sure why there is a problem. I can just go out and keep buying more junk. I could get new stock oem springs
  3. May 18, 2016 at 7:22 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    The 2 highlighted are the same...
  4. May 18, 2016 at 10:09 PM
    Hiluxborn
    Clint
    I don't understand....
    What if I get a 3 inch lift spring and set the struts at 2.5 this will be one more inch taller then the spacer. Can I do that? Or does the lower cross member have to come off and go back to stock?
  5. May 18, 2016 at 10:12 PM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    Those coils are likely totaled. Need new ones
  6. May 18, 2016 at 10:13 PM
    Hiluxborn
    Clint
    What about the idea oh removing just the spacer and installing a 3 " spring and putting my struts at 2.5? Will this work?
  7. May 18, 2016 at 10:17 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^If you mean a spring intended to provide a 3" lift, no it won't work with the shocks set at the 2.5" setting.
  8. May 18, 2016 at 10:19 PM
    Hiluxborn
    Clint
    Why? That's 5.5?
  9. May 18, 2016 at 10:23 PM
    jakebray
    jakebray Well-Known Member
    jake
    SoCal
    13 PreRunner
    Locked DCLB with Kings and crap
    You shock will have no down travel at that point, it unfortunately doesn't work that way
  10. May 18, 2016 at 10:26 PM
    jakebray
    jake
    SoCal
    13 PreRunner
    I would buy some new springs they look pretty shot, a newer spring will be stiffer and hopefully not want to fully compress as easily
  11. May 18, 2016 at 10:34 PM
    Hiluxborn
    Clint
    So it's going to be really stuff then. ....so why couldn't I get spring that lifts 4 inches and I just the shock to 1.5? I'm just going to park this truck or sell it if it can't be fixed. Iv been adding my recorded and after buying the truck for 9,500 I'm already at 13,900. It's been a money pit
  12. May 18, 2016 at 10:34 PM
    KenLyns
    Belly of the Beast
    The shock length does not increase when you move the spring perch up to the 2.5" setting, it just preloads the spring. Trying to preload a longer/stiffer spring intended for 3" lift will just keep the shock extended all the time. You'll get just ~3" lift, with a really rough ride and no suspension travel.
  13. May 18, 2016 at 10:39 PM
    Hiluxborn
    Clint
    And so you say get a oem stock spring and the bottoming out should go away? What about bump stops ? The lower control are has two per side . They have five inches between them and the frame. The sway bar King on the back wouldn't allow long ones
  14. May 18, 2016 at 10:41 PM
    KenLyns
    Belly of the Beast
    Try these with the shocks set at 0": They offer minimal lift (so your DB lift geometry is maintained), but the rate is stiffer at 500 lb/in vs 465 lb/in stock.
  15. May 18, 2016 at 10:51 PM
    #35
    inesshell
    i would not get a spring intended for lift and preload at the highest 5100 notch. That is just too much preloading and would just kill that shock faster while getting you no travel at all. Also this would not get you the desired lift you wanted, just a really big disaster waiting to happen when that tension lets go at a failure. You could use the existing 5100, preload the existing spring if it is still good and find a smaller top spacer.
    If you decided to preload to 2.5, it would be a bitch to compress a spring to that level, especially one with that is stiffer rating than a stock spring. Compressing my 886 coils on a ome shock scared the shit out of me
  16. May 18, 2016 at 10:55 PM
    #36
    Hiluxborn
    Clint
    Ok. Thanks for explaining that to me. How can I really tell if the spring is bad. Am the shop is going to say it is. I also didn't install the struts. I paid to have them installed
  17. May 18, 2016 at 10:59 PM
    #37
    inesshell
    cant tell until you have them taken off from the strut. Also from the looks of the photo you have the massive top spacer ontop as well as a smaller top spacer sitting between the top hats and the spacer. I am guessing this is adding too much tension on the coil and compressing it further. I think you can get back some travel and comfort if you remove that small spacer.
  18. May 18, 2016 at 11:01 PM
    #38
    Hiluxborn
    Clint
    I'll look. I'm not sure what small spacer you are talking about. Did you see the video by chance as well?
  19. May 18, 2016 at 11:07 PM
    #39
    inesshell
    i just watched the video, you need bigger bump stops to prevent the shock from bottoming, you spacer lift is literally stealing all of your down travel on your coils and strut. looking at the photo again, you are stacking spacer lifts, meaning you have two, remove one so you dont completely snap your strut because the coils are already bending/ touching before you even compress the strut - just a matter of time they just break in two.
  20. May 18, 2016 at 11:14 PM
    #40
    Hiluxborn
    Clint
    That's the way the tuff country 5 inch system comes. You can feel the shock bottom. I also stated that longer bump stops on the back wouldn't fit pastvthecsway bar. This kit also didn't come with bump stops. I'll bring this stuff up to the shop tomorrow where I got the struts. The old stuck ones didn't bottom out like this. They did wave a little bit not a slamming when going over gravel holes or rutted roads.
