Looking for info on overland racks and tents.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Billybigrig22, Aug 16, 2024.
  1. Aug 20, 2024 at 11:04 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
  2. Aug 20, 2024 at 11:11 AM
    Billybigrig22
    Billybigrig22 [OP] Member
    Bill
    2015 Tacoma TRD Pro
    I ended up buying a rack and tent Sunday. I'll post it after I get it set up
    GARSHA91 likes this.
  3. Aug 20, 2024 at 11:38 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Thats great. Just in time for fall
  4. Aug 20, 2024 at 12:17 PM
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    Make sure you post in/start a build thread :thumbsup:
  5. Aug 20, 2024 at 2:08 PM
    Rms8390
    Rms8390 Well-Known Member
    Dallas, TX
    2015 PreRunner DCSB
    Voodoo Bed Rack Prisnu Roof Rack MT64 OME Suspension lift ARB onboard air OVS Everest RTT
    Cant vouch for voodoo’s stuff enough. Quality and bulletproof. Good customer service too.
    KB Voodoo[QUOTED] likes this.
  6. Aug 20, 2024 at 2:24 PM
    banditcamp
    banditcamp Well-Known Member
    daniel
    2015 Super White DCSB Off Road
    I've never had a RTT because the places I use choose to put my tent are pretty far away from any place a truck can go. As I'm getting older that's changing and I may get a rtt. I agree with taco Tuesday that the less moving parts the better. Solid welded bed bars that you can remove by your self is nice if you plan to change your set up often. I have low bars and tall bars. Heavy metal off road makes them. If you plan to do a soft rtt or what I call a hard clam shell then the low will help with mpg, and lower center of gravity if you plan to do more complicated wheeling trips. But a wedge on the higher bars is much faster to set up. On that subject a hard shell in general is faster to setup and take down vs a soft. Aluminum will stand up to elements longer than plastic. So that's things to factor in when buying as well.
