Looking for information
Discussion in 'New Members' started by Champlin.J, Sep 26, 2018.
  1. Sep 26, 2018 at 11:00 AM
    Champlin.J
    Champlin.J [OP] New Member
    Joshua
    2006 Toyota Tacoma 4 cylinder 2.7L 2wd
    Muffle, 3" lift all the way around 35" Toyo AT tires.
    Hey guys, I'm Josh I own a 2006 Toyota Tacoma 4 cylinder 2.7L. Over these past few months I've been having some issues losing oil I don't have any leaks I've even removed the skid plate to look and found no leaking from the oil pan or anywhere else on the engine block but I'm consistently losing approximately a liter and a half of oil every 2000 miles. I have 172,000 miles on the truck early last year my main coolant bypass line blew on me when I spoke to Toyota they informed me that it was common but there wasn't enough claims of engine damage to warent a recall but they did improve the part from a plastic line to metal. Once I replaced that my truck was running fine it hasn't over heated since. I have been putting a lot of miles on my truck so I notice my gas mileage going down check my oil saw that it was lower than normal at this point I was only 2800 miles since my last oil change. I took it in to Toyota and had an oil change done about 5 weeks late I was at 2500 miles and my truck started to make noise and run rough it sounded like my valves were tapping and sure enough my oil was low again I took it back got an oil change and now I'm at 1892 miles from the last oil change and the noise is back and my oil is low. I'm just wondering if it is my oil rings or if there something else that could be causing this to happen?
    irayfz6 and twitchhero like this.
  2. Sep 26, 2018 at 2:43 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW...hope you get it figured out.
    irayfz6 and Bigdaddy4760 like this.
  3. Sep 26, 2018 at 3:13 PM
    twitchhero
    twitchhero ___YOU BOYS LIKE___ MEX-I-CO???
    North Carolina
    2017 Tacoma TRD Off-Road
    See Profile for a full list of Modifications: *Suspension* -Total Chaos Upper Control Arms -Total Chaos Lower Control Arms -Rock Rash performace welded spindle gussets -King EXT Coilovers with adjusters (front) -King Tundra EXT Shock with adjusters (rear) -Icon RXT leaf pack (Option 2) -Timbren active off-road bump stops (front) -Timbren active off-road bump stops with U bolt flip kit (rear) -DRT cab mount relocation -DRT Shackle hangers with DRT cross member -Dobsins front leaf greasable bolts -Polyurethane front body mounts *Performance* -AFE intake (noisemaker) -JLT oil catch can -OTT Tune -Stoptech stainless steel brake lines -Power Brake D-Line kit -Extended stainless steel rear brake lines -AGM Odyssey battery -Tacoma TRD Pro Exhaust *Interior* -Window Tint -Tacoma Door Sill Protectors -Clazzio (black leather seat covers) -Dashtop Single Mount -Sound deadening material -GATOR floor mats -Cup holder hero mats -Garmin mini front dash cam -JOYING Headunit -Tacoma Kicker tweeter upgrade -Kicker KS front and rear speakers -Rear USB -Meso Customs interior lights *Exterior* -Tacoma tailgate inserts -Mobtown offroad "No drill" Bolt-on rock sliders. -All-Pro Hi-Lift bed rail mount /w Hi-Lift -Rear Diff breather relocated -Alpha REX TRD Pro style headlights -Baja Design squadron sport (Amber fog lights) -Total Chaos Fabrication bed stiffeners -Window Deflectors (AVS) -TRD Pro Grille -Summit DAKAR (BRONZE) -Toyo Open Country R/T Trail (35x12.50 R17) -Sequential turn signals -Softtopper (black) -Toyota Bed Mat -Vinyl wrapped tail gate (black) -C4 high clearance fender liners -C4 High clearance Rock Runner rear bumper w/ Baja Designs S1
    Look for bluish white smoke coming from the tail pipe when idling or driving. It may help to have someone watch. It may possibly be bad oil rings. You stated that your coolant line blew. Was it coolant that leaked all over the place? I'm wondering if its a bad head gasket since you have small channels in the gasket and if it cracked in between a coolant and oil channel and oil is entering your coolant. Hence the increased pressure and your coolant lines blowing. Hope this helps OP and welcome to Tw!
  4. Sep 26, 2018 at 4:14 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW
    :hattip:
    buckhuntin-tacoma likes this.
  5. Sep 26, 2018 at 4:16 PM
    Bishop84
    Bishop84 Well-Known Member
    Valve seals or piston rings. It can be hard to differentiate the two.
    Valve seals usually smoke on startup, and you'll notice a puff when decelerating, especially in a manual.,
  6. Sep 26, 2018 at 4:39 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome!
  7. Sep 27, 2018 at 4:39 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
