Looking for instrument panel replacement bulbs
Discussion in '1st Gen. Tacomas (1995-2004)' started by Italian02Tacoma, Jun 16, 2010.
  1. Jun 16, 2010 at 2:06 PM
    Italian02Tacoma
    Italian02Tacoma [OP] Member
    Tennessee
    02 4WD Dbl cab
    I have a few bulbs out around my tach and speedo, and I was wondering if any one knows of an online store that sells replacements. Wouldn't mind going with LEDs if possible. I have an 02 dbl cab. Thanks.
  2. Jun 16, 2010 at 2:59 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
  3. Jun 16, 2010 at 3:29 PM
    tacomaforlife
    tacomaforlife Well-Known Member
    Robbie
    AIKEN, SC
    Its a Toyota what more is there to say.....
    TRD S/C 3" sky jacker suspension lift,33" kumho road venture mt kl71's 16" 320c pacer wheels,billet grill,EBC slotted and dimpled rotors,super 44 muffler with gutted cat,smoked l.e.d. tail lights, deck plate mod with K&N filter,fog/blinker mod,cobra cb with 4' firestick antenna/100W PA,clear corners with l.e.d bulbs,55w back up lights,urd O2 sim., blue l.e.d bulbs behind gauge cluster.
    i got 4 blue l.e.d bulbs from suntekstore.com for $7 bucks only bad part is takes a little while to get them because they are shipping them from china mine work great and they are bright.
  4. Jun 16, 2010 at 7:18 PM
    felotacoma
    felotacoma Active Member
    felipe
    miami
    99 PreRunner SR5
    can you post some pics, and is there a picture by picture how to remove the panels to get to the light bulbs, thanks
  5. Jun 16, 2010 at 7:19 PM
    RPain
    RPain I drink, and I break things
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    bought all my led's at superbrightleds.com :) got them 3 days after i ordered
  6. Jun 16, 2010 at 7:38 PM
    tacomaforlife
    Robbie
    AIKEN, SC
    i would upload picks but my laptop is messed up at the moment but i can give u step by step instructions.
    1. you will need to pull off the a/c control knobs then pull of the black a/c panel
    2.u will find two screws one in the left corner behind the a/c panel and another in the right corner.
    3. then you can pull back the black shroud that houses the a/c controls and radio.
    4. next you will find four bolts i think they are 10mm underneath the steering wheel and there also will be on screw on the left side of the panel.
    5. once all the bolts and screws are off you can pull the panel down then you can remove the plastic panel that surrounds the key hole it will pop out no screws.
    6. now you will move to the top panel that surrounds the gauges, on the left side bottom of the steering wheel you will find one screw and two screws above the gauge cluster.
    7.Next make sure u unplug all buttons and adjust the steering wheel as low as it will go then you will be able to pull out the black panel.
    8. Once the black panel is of you can access the gauge cluster, you will find four screws, once removed you can pull out the gauges cluster.
    9.On the back of the cluster there will be four large sockets that have 194b bulbs to pull out turn the socket insert bulb.
    10. then put it all back.:D
