Looking for intro help for powering lights/equipment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by st101, Oct 1, 2014.
  1. Oct 1, 2014 at 10:07 AM
    st101
    st101 [OP] Well-Known Member
    Hello all,
    In my sleepy state, I accidentally posted this in the "Garage/Workshop" sub-forum last night.
    Was wondering if I can get a quick nudge in the right direction on expansion/modification of the electrical system in the vehicle so I can provide power to lights, a computer, cameras, etc. If there is a good sticky or tutorial thread somewhere, please link me over! I have a 2014 DCSB TRD Sport.
    Have tried making a few searches on the forum but I can't find much aside from 'show off your distribution box!' threads.
    Elsewhere on the web I've seen people adding 2nd batteries, new distribution/relay boxes, using add-a-fuse on the existing in-cab fuse box, or just wiring straight up to the battery. Which is the right solution for which application?
    Should light bars with fairly large current-draws be hooked up direct to the battery?
    At what point are mechanical relays appropriate?
    When do I use solid wire and when do I use stranded wire?
    Does everything get a fuse or only the beefier items?
    How can I provide power to items without having to turn the key to accessory mode or ignition? Subsequently, how can I prevent leaching of the battery for those items over night?
    At what point does it become "too much" for the battery? Some of the overland folks have a winch, air compressor, refrigerator, and a boatload of lights (obviously not all running at the same time) -- what kind of power distribution system are they likely to be using?
    Thanks in advance for any help/guidance!
  2. Oct 1, 2014 at 12:15 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    tried to answer a few of your questions, hopefully some more people will chime in as well
