Looking for LED lights to replace my Daytime Running Lights. Any suggestions?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RearViewMirror, Apr 26, 2013.
  1. Apr 26, 2013 at 11:22 AM
    RearViewMirror
    RearViewMirror [OP] Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2013 DCSB 4X4 TRD Off Road *Sold*
    As the title says I'm looking for a pair of LED lights to replace my DRL's. I purchased these off Amazon and as you can tell from the pictures they are total fucking shit:
    As you can tell one of the lights is installed in the housing crooked (quality control at it's best). I took a chance and installed them in the DRL's and shocker it blew the fuse. Reversed the bulbs in case of a polarity issue and shocker again blew the next fuse. Replaced my DRL's with the Silverstars that I had in them. The only reason that I would like to replace the lights is the Silverstars seem to run a little hotter than the factory DRL's. Not so much that it is going to melt the lens but when I took them out you could tell that they were running a little hot. I would return these but due to the half page of instructions on how to return them and the "up to 30 days" to get my money back I just said fuck it. Chalk it up to a $12 lesson learned.
    So... Anyone know of a quality set of LED lights that might work for my DRL's?
    Thanks in advance.
  2. Apr 26, 2013 at 11:29 AM
    neonlazer
    neonlazer Mechanically Goofy
    Jeffrey
    Lafayette, LA
    '12 DCSB 4x4 SR5
  3. Apr 26, 2013 at 11:42 AM
    RearViewMirror
    Craig Christ
  4. Apr 26, 2013 at 2:49 PM
    ndcmack
    ndcmack Well-Known Member
    NICK
    Western Washington
    BSP 4x4 TRD Sport DCSB
    Not enough
    My 05' doesn't have DTRL's but I have all LED bulbs with no issues. Don't forget to order the CF18 flasher if LED's are going into your turn signals(Confirm your 2011 uses the same flasher). Check out www.superbrightleds.com.
  5. Apr 26, 2013 at 3:05 PM
    RearViewMirror
    Craig Christ
    Cool thanks!
  6. Apr 26, 2013 at 4:51 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 70 17 cooper at3
    I have a pair of vled triton v3 in 5k I'm thinking of selling. Let me know if you're interested.
  7. Apr 26, 2013 at 6:11 PM
    CBoy808
    CBoy808 Sticker Making Dude
    Tacoma Mall Crawler
    If you purchased these from Amazon, you should return them. their return policy is excellent. If you choose damaged or not as advertised when you setup the return they will even pay shipping back to them. Its REALLY easy as they give you a label all you have to do is print it out, box it back up and give it to the post man.
  8. Apr 26, 2013 at 6:23 PM
    lemon177
    lemon177 Well-Known Member
    Matthew
    kauai/oahu
    09 tacoma 4x4 sport pyrite mica
    TRD supercharger, URD 2.85" stealth pulley, TRD exhaust, TRD intake, DTLT headers, URD y-pipe, TRD boost gauge, PLX DM100 touch with OBDII and SM-AFR modules, 885 OME 3", Icon UCAs, Satoshi grill, Solid rear window, SCS stealth 6, 285/75/17 toyo AT2.
    you also may need to run a resistor with those LEDs you got.
  9. Apr 26, 2013 at 6:29 PM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    im in the same boat. bought a set of CSjumpers LED's, could barely notice them. looking for a solution now.
  10. Apr 26, 2013 at 6:33 PM
    RearViewMirror
    Craig Christ
    Yeah I thought about that. I should have known better with a $12 set of LED lights. It is my fault for not doing my research before purchasing them. I didn't realize that there is more involved than just switching out light bulbs to LEDs. I may but for $12 not really worth my time and effort.
    Now that I have done a little more research I think you are probably right. But, like everyone says, you get what you pay for. It is pretty obvious that they are not really well crafted. The pictures from the Seller and what I received are not exactly the same to say the least lol.
  11. Apr 26, 2013 at 6:36 PM
    RearViewMirror
    Craig Christ
    Man I really like your truck in your Sig. I dig the subtle look! Good job
  12. Apr 26, 2013 at 6:42 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Toyota's wiring on the socket is what's causing the fuse to blow.
    You need the "CK" type LED units.
  13. Apr 26, 2013 at 6:48 PM
    RearViewMirror
    Craig Christ
    "CK"? Sorry I'm kind of stupid with this. Learning though :)
  14. Apr 26, 2013 at 7:15 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    It has to do with the way the socket is wired.
    For some reason, Toyota put both grounds on the same side, rather than the same end, so the LEDs short. Lamps don't because 4 separate wires feed the filaments, but on LEDs have two hots but the ground is common to both circuits.
    The CK type LEDs correct this. They have them on Superbright, or you can get them from CSjumper as neon indicated.
  15. Apr 26, 2013 at 7:19 PM
    RearViewMirror
    Craig Christ
    Ah okay. Thanks that makes sense now.
  16. Apr 26, 2013 at 7:20 PM
    650H1
    NH
    thanks man!
  17. Apr 27, 2013 at 1:26 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    King George, VA
    2017 Silverado
    Grandpa Chrome edition
    Unhappy with the results?
  18. Apr 27, 2013 at 8:46 AM
    Asianguywithatruk
    CenCal
    05 taco DCSB
    I am absolutely happy with them. Just going a different direction. I'm about to do a retrofit and I'm thinking about putting in some xbaled so I don't want the v3 tritons to outshine the led ring.
