Looking for more HP with my new supercharger.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by d1977, Jul 28, 2015.
  1. Jul 28, 2015 at 10:01 AM
    d1977
    d1977 [OP] Member
    I have a 2011 Trd Tacoma, I put a supercharger in it just about 3 months ago.
    I was expecting a lot more power and torque....does Toyota just flash it and make sure it runs ?
    Does it need a proper tune to get the full results out of a supercharger ?
    I have an afe cold air intake and cat back exhaust.
    I was wondering what results would come with a new 2.55 pulley, fuel upgrade kit, 7th injector kit and a new map ecu3, all from URD.
    If its not going to add quite a bit more hp and torque, I would assume, its not worth it.
    Im a newbie...any help would be great.
  2. Jul 28, 2015 at 10:03 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Don't forget headers, ypipe, a 3" exhaust
    mattgecko likes this.
  3. Jul 28, 2015 at 10:10 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There is no 7th injector that I am aware of for the 1GR. These engines run extremely rich on the stock blower tune. A good correction of that to get into a better AFR would be a 2.85 or 2.7 pulley, but you will have to trim the supercharger snout for the 2.7 pulley.
  4. Jul 28, 2015 at 10:12 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  5. Jul 28, 2015 at 10:13 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    The 7th also helps cool the rotors iirc
  6. Jul 28, 2015 at 10:16 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Another alternative to the 7th injector if you are using it for cooling properties is a water/meth injection kit. I see that kit requires the Ucon software to run it.
  7. Jul 28, 2015 at 10:18 AM
    d1977
    d1977 [OP] Member
    Lol, shit. Is it worth it ?
    Whats a cost efficient way to gain more hp ?
    What would i need ?
  8. Jul 28, 2015 at 10:18 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Ouch. That sounds intense. I wonder how easy the valve body upgrade is and if its even worth doing if you have a pulley larger than a 2.5.
  9. Jul 28, 2015 at 10:18 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    How much u want?
  10. Jul 28, 2015 at 10:20 AM
    d1977
    d1977 [OP] Member
    Thats the question, what can i gain without breaking the bank.
    Id love to get another 40-50 hp.
  11. Jul 28, 2015 at 10:21 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    its easy.. and yes.. its worth it :cool:
    12TRDTacoma[QUOTED] likes this.
  12. Jul 28, 2015 at 10:21 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Headers, ypipe, 2.85 should be close
    XPOTRPR likes this.
  13. Jul 28, 2015 at 10:21 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    this
  14. Jul 28, 2015 at 10:28 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Can you purchase the valve body and do it yourself?
  15. Jul 28, 2015 at 10:29 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    This is the biggest problem, and why not a lot of people invest in this upgrade unfortunately. I just happened to luck out, bought it from another member and did the swap in his garage in a few hours.
  16. Jul 28, 2015 at 10:30 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
  17. Jul 28, 2015 at 10:35 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    With all the issues I've heard about Lvl 10, I wouldn't use them. There are numerous threads regarding Supras, Eclipse, as well as others who had issues. I posted links in another thread a while back regarding this as well.
    But, if you can swing an IPT valve body.. I'm sure you will enjoy it. Shifts are so much quicker and firmer. from 1st to 2nd is just insane in an awesome and grin inducing way.. especially when you get wheel chirp with 33's. lol:burnrubber:
  18. Jul 28, 2015 at 2:41 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    More boost and you will most likely blow the engine. The owner of the dealership where I bought my Tacoma tried it on one he owned and he blew the engine on his.
  19. Jul 28, 2015 at 4:32 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Plenty of us with this or even more with no issues..
  20. Jul 28, 2015 at 4:38 PM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Werty is a good dude. That's where my valve body came from. :)
    WorldWar546 and thewarriordinghy like this.
