Looking for more power in this 3rz
Discussion in '1st Gen. Tacomas (1995-2004)' started by Abeyancer, Jun 19, 2019.
  1. Jun 19, 2019 at 11:03 PM
    Abeyancer
    Abeyancer [OP] Not so secret, secret van guy
    Jimmie
    PNW
    98 4x4 ex cab tacoma 3rz
    A new butterfly is made because when a TB is bored out the old butterfly no longer seals correctly since it's actual oval instead of round. Its par for the course on any TB bore job but I had the little extra done by having a new throttle shaft machined (what the butterfly is screwed into) in order to reduce air turbulence over it
  2. Jan 2, 2020 at 8:28 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I’m curious about the pink top injectors on the 8 port head. Your ‘98 should’ve had the injectors with just 2 jets per injector like mine. Each jet sprays down a single port on the 8 port head. The pink injectors are a 12x multi jet spray each injector.
    Any noticeable mileage change with these?
  3. Jan 2, 2020 at 1:17 PM
    Abeyancer
    Jimmie
    PNW
    No noticable difference in the city mileage category (which is 90% of my daily driving)
    Regretfully I can't tell you if the highway miles are affected because when i rebuilt the transmission I used a kit that had a defective 5th gear synchro so I can't comfortably get up to highway speed
    Brake Weight likes this.
