Looking for off-set wheels but not sure how much off-set I need
Discussion in '1st Gen. Tacomas (1995-2004)' started by R.etheridge, Jan 31, 2011.
  1. Jan 31, 2011 at 3:42 AM
    R.etheridge
    R.etheridge [OP] Well-Known Member
    Middle GA
    03 Tacoma TRD 4x4
    I have a 03 DC 4x4 that I put a 3in lift on about a year ago. I have 16in 09 TRD wheels on it on it now with 1.25 in spacers. I would like to buy some aftermarket wheels so that I can get rid of the spacers. I want 16in so that I can use my same tires because they are in really good shape and were not cheap ( yoko geolanders at/s). My question is what off set do I need on the new wheels in order to clear the UCA's? I love the look of my wheels and tires now with the 1.25in spacers because it doesnt let the tires stick way outside of the truck body but clears the UCA's perfectly so I really want to go no more outside than what im looking at now. I searched the forum but never could find the answer to my question. Thanks in advance to anyone that can help me out.
  2. Jan 31, 2011 at 4:43 AM
    Space Wrangler
    Space Wrangler Well-Known Member
    JCT
    Ga
    04 DC 4x4
    04 Tacoma 4x4 Double Cab SAW 2.0's Alcan's Ion 171 wheels 15x8 (-27mm bs) 32" BFG AT's
    i think the magic number is 4.0 or 4.5 if you're running a 16" wheel. ....someone may way to verify that though..
  3. Jan 31, 2011 at 4:51 AM
    98tacoma27
    Ben
    Not Beech Creek
    They BS you are currently running (with the spacers) is about 4.25. As Space Wrangler has said, any where between 4.0-4.5 will be good.
    Side note: You two have remarkably similar avatars.
  4. Jan 31, 2011 at 10:50 AM
    R.etheridge
    Middle GA
    03 Tacoma TRD 4x4
    4.25 thats in inches correct? Im not sure 4.00 will fly because with the 1.25 spacers it just does clear the UCA so 4.25-4.5 will probably be ideal for me. I had to go with spacers for a little bit for $$ reasons or lack there of. Didnt want to but you gotta do what you gotta do sometimes. I havent had any trouble out of them thus far but I really wanna get away from them.
  5. Jan 31, 2011 at 10:56 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    The less back spacing you have the more your tires will stick out I have 3.74" backspacing.
    Really all you need to do is remove the wheel and and lay it down on the front side. Measure by putting a straight piece of wood on the back side of the wheel with the spacer sitting on the wheel and measure from the wood to the spacer & that will give you your current backspacing. If you buy a wider wheel adjust accordingly to achieve your desired stance.
  6. Jan 31, 2011 at 6:27 PM
    R.etheridge
    Middle GA
    03 Tacoma TRD 4x4
    im not following how your measuring to be honest.
  7. Jan 31, 2011 at 6:57 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
    the less backspace you have... the more your tires stick out thus clearing your UCA's and/or frame rub. backspace is measured backwards i guess
  8. Jan 31, 2011 at 7:02 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    ^^ This.
    Backspacing is the distance between the back of the rim and the rim mounting point.
  9. Feb 1, 2011 at 1:16 AM
    R.etheridge
    Middle GA
    03 Tacoma TRD 4x4
    I figured it out. I just wasnt tracking as to how you were measuring for how much backspace but I got it now. Ill take one off today and see how much I have. The only set of wheels that I found that I like are pro comps so far with a 4.5BS so I might not have much of an option. Thanks for your help though
  10. Feb 1, 2011 at 1:18 AM
    R.etheridge
    Middle GA
    03 Tacoma TRD 4x4
    does anyone have some wheels on their taco with 4.5 backspacing and if so could you snap a picture from the back and front for me so I can see what it looks like. it would be much appreciated.
  11. Feb 1, 2011 at 5:33 AM
    TexasTacoma37
    Search for pics of folks with 285's. Almost everyone who runs 285's has wheels with 4.5" backspacing.
  12. Feb 1, 2011 at 7:57 AM
    R.etheridge
    Middle GA
    03 Tacoma TRD 4x4
    awesome, I get it now so less is more. Ive done some research on some other forums and found that 4.5 BS is what im looking for I think. I believe the fj TRD wheels are 4.5 BS so im thinking of looking at them because I really cant seem to find an aftermarket wheel that I like in a 16x8 thats 6 lug except for the pro comp xtreme alloy series 7089 black finish. If anyone knows of any other wheels with the 6 spoke design that are the matte black finish, please let me know so I can check them out
  13. Feb 1, 2011 at 7:59 AM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    4 inch backspacing will make your tires poke out more than 4.5 inch backspacing. the smaller the backspacing, the more clearance between tire and your UCA
  14. Feb 1, 2011 at 8:02 AM
    TexasTacoma37
    That's correct for a given rim width.
    But if the rims width changes and the backspacing stays the same, all of that width difference will go into making the wheel poke out more.
    Example, my rims are 9" wide, with 5.5" backspacing. They will stick out more than a 7" wide rim with 4.5" backspacing, even though I have more backspacing.
  15. Feb 1, 2011 at 8:06 AM
    R.etheridge
    Middle GA
    03 Tacoma TRD 4x4
    ok so I guess what im asking is I have a 3in lift a true 3in with 285/75/16's will a 4.5BS be enough to clear my tires from my UCA's on a 16x8 rim?
  16. Feb 1, 2011 at 8:14 AM
    imtwistd
    imtwistd Going nowhere as fast as possible
    I forgot
    Liverpool NY
    08 dbl cab long bed sport 4x4 beast
    AllPro offroad front LT with Fox 2.5 shox and AllPro expedtion rear springs with Fox piggy back res shox, TRD skid plate, Toyota roof rack, Undercover tonnuea cover, Pro comp 3" lift, 4 Pro comp 8" offroad lights, 17" XD Series "SPY", Nfab tube steps and light bar, Fitch Fuel, Flexalite fan, Unichip, URD cai, TRD supercharger, URD y-pipe, Banks monster cat back, debadged, projection head lighs, LED tail lights and a loud stereo, Stainless Steel Brake Lines front and rear, Doug Thorley long tube headers, Walboro 255 fuel pump, KC rock guards on my Pro Comp 8" lights
    I have a set of mickey thompson wheels and tires I'm trying to sell. They're 16x10 with 265/75 16 baja radial MTX. I had them on my 08 with a 3" lift and I never had a problem. My dad had them before me on his 03 doublecab with no lift and never had a problem. Here is my truck with the MT wheels and tires.
    They are for sale, if your interested send me a pm.:D
  17. Feb 1, 2011 at 8:18 AM
    R.etheridge
    Middle GA
    03 Tacoma TRD 4x4
    not interested
  18. Feb 1, 2011 at 8:31 AM
    JLee
    Jerry
    Grass valley CA
    Yes you will be fine.
  19. Feb 1, 2011 at 8:34 AM
    JLee
    Jerry
    Grass valley CA
    Those don't look like 16x10's man I'm thinking you got 16x8's maybe 16x9's with a 10" rim those 265's would be so bulged out i have 15x10's and my 12.50's bulge out more then your tires.
  20. Feb 1, 2011 at 10:23 AM
    R.etheridge
    Middle GA
    03 Tacoma TRD 4x4
    awesome thanks. now does anyone have pics back and front with a 285 on a rim thats 8in wide, with a BS of 4.5 so that I know that it wont stick out so far from my body? Because if this BS size does, i will go with another option
