Looking for Picture
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sac130e, Jun 4, 2011.
  1. Jun 4, 2011 at 1:36 PM
    sac130e
    sac130e [OP] Well-Known Member
    Scott
    Milton, FL.
    11' TRD Off-Road 2wd
    JVC Nav. System and entire Memphis Audio Speakers/Amps
    Changing the oil soon..anyone have pci of the correct plug to pull for the oil t o drain? Don't want be one of those that pulls the tranny plug. I have a 2011 DC 4.0L for reference.
    Thx
  2. Jun 4, 2011 at 1:44 PM
    KellyJoe
    KellyJoe Well-Known Member
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
  3. Jun 4, 2011 at 1:46 PM
    kirkofwimbo
    kirkofwimbo Say no to Bro
    Clayton
    Wimberley, TX
    ‘17 TRDOR DCSB
    Just remember it's not the flat pan. It's the one forward of that, looks kinda like an udder with one teet
  4. Jun 4, 2011 at 1:48 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Airaid Short Ram Intake, 285x75R16 Mickey Thompson MTZs, 16" Konig Countersteer rims, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Best thing I can say is, don't pull the plug until you find both plugs. Then do the one that's closest to the front bumper, right between the wheels. Not the one that's directly underneath the gear shift.
    There will be a hole in your skidplate to access the oil lug. It can be a bit of a bitch to see.
  5. Jun 4, 2011 at 1:58 PM
    sac130e
    Scott
    Milton, FL.
    Thx for the info..glad I asked, didnt know about the drain line needed for the filter. Thought it was built in to the drain itself. Looks like I am off to the store for some tubing. As for the drain plug, I have never seen a gasket on any other vehicle I have owned and never put one on..is this cool if there is not one one there now?
    Scott
  6. Jun 4, 2011 at 4:42 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    There should be one on there now. You can reuse them at least 2-3 times.
    I do, and I don't have any oil leaks. Just check a few days afterwards in case though.
  7. Jun 4, 2011 at 11:30 PM
    JKD
    JKD Well-Known Member
    Crawl under the truck with your head toward the front and give your transmission a big ole' hug. The transmission drain plug will be on your sternum, and the oil drain plug will probably be close to your forehead depending on your height.
