looking for small lift under 2"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kieran, Mar 28, 2015.
  1. Mar 28, 2015 at 10:10 PM
    Kieran
    Kieran [OP] Friendly Neighbourhood Canadian
    Toronto
    09 Access Cab V6 TRD OffRoad
    None yet.
    Hello,
    I am wondering what the best way to go about adding 1-1.5" to the hight of the truck. I want to keep access to undergrounds and not change any geometry too much. I am not looking for a 2"+ just want it to sit a hair higher. I already have a +1 tire size so it sits a little higher to begin with. Its a 2009 AC TRD OR.
    any ideas?
    Thanks
  2. Mar 28, 2015 at 10:14 PM
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Ironman4x4 has a 2" lift kit that works great. I've been using it for a few years. I just recently upgraded to their foam cell pros that are fully adjustable. Go check my started by threads for both threads.
  3. Mar 28, 2015 at 10:15 PM
    KnoxTac0713
    KnoxTac0713 Well-Known Member
    Justin
    Knoxville, TN
    13 DCSB SR5 4x4 Barcelona Red
    Bilstein 6112, rear 2.0 Icon VS shocks, TRD Black SEMA wheels, 255/80/17 Cooper ST Maxx, SOS Rear bumper, SOS bolt on sliders,TRD skid plate, derped badges, 15% tint, color matched oem grille, lamin-x amber fog covers, TRD cat-back exhaust, Tacoma bed mat, Tonno-pro trifold, Depo black tail lights, front tow hook w/ D shackle, Wheeler's Superbumps rear, Wheeler's 1 inch block rear, Custom Car Grills mesh grill insert, light bar in lower valence
    5100s set at 1.75 w stock coils or 5100s set at 0 w/ Eibach springs for 1.5" of lift?
  4. Mar 29, 2015 at 2:54 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    I currently have 5100's set to .85 with stock Offroad coils, and that gave me an inch. Set to 1.75 will give you pretty close to 2"
  5. Mar 29, 2015 at 3:28 AM
    jasontojo
    jasontojo Well-Known Member
    jason
    west virginia
    SR tacoma 4x4 2.7L
    5100 Bilsteins, Toytec Fr coil lift springs, Deaver AAL packs, Mobtown tailgate reinforcement, Intermittent wiper switch, ECGS Fr Diff bushing
    I am looking to do the same. Do any of you know if you have to do any other stuff to the suspension besides chaniging spings and shocks. I am looking to do this on the cheap, but dont want to buy junk. I might also want to eventually put in a hidden winch pan will this make me want to put heavier springs? Any help on this would be appeciated.
  6. Mar 29, 2015 at 4:32 AM
    JohnnyWayne
    JohnnyWayne The Past Through Tomorrow
    Johnny
    Lantana, FL
    '12 DCLB TRD Sport
    Look out for snakes in the grass guerrilla marketing.
    For budget 2" I would go the bilstein route as mentioned above ;)
  7. Mar 29, 2015 at 5:10 PM
    Kieran
    Toronto
    None yet.
    Do you think if I put 5100s on all four corners. If i set the front ones to .85" and left the rears without a AAL it would level out the OR? Or would it be wise to put a AAL on the back? Generally what do people run for a mild lift with 5100s.
  8. Mar 29, 2015 at 5:19 PM
    adamr94
    adamr94 Well-Known Member
    Adam
    NC
    06 Regular Cab 4x4
    i'd do an AAL, if I was going to do it
  9. Mar 29, 2015 at 5:34 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Adding an AAL with only .85" up front is going to give you more than stock rake i.e. Nose dive look.
  10. Mar 29, 2015 at 5:39 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    I went with OME 884s on bilstein 5100s set at 0 and gained right at 2". This set up will ride better than using the stock coils and setting the 5100 shock at 1.75 because you aren't preloading the coil. But it will be more expensive b/c you have to buy the coils. It comes down to comfort vs $. Hope this helps.
  11. Mar 29, 2015 at 5:41 PM
    Kieran
    Toronto
    None yet.
    thats what i was thinking... but with the fronts at .85 is it going to be level or have a high nose...
  12. Mar 29, 2015 at 5:47 PM
    Fitz235
    Rob
    New Hampshire
    Right now, mine is almost level (with 5100's all around, fronts @ .85). The back is 1" higher than the front, so just a slight rake. I have the original 2+1 leafs that came with the '05.
    If you have the 3+1 leafs you should be level @ 1.75.
    If you go the AAL route, @ .85 you will have a good rake, as the back will be a good deal higher than the front depending on which AAL you go with.
    Just be aware, if you do go to higher than .85, there's a chance you will get the front differential vibe. It's fixable with the ECGS bushing ($60) though.
  13. Mar 29, 2015 at 6:43 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Neither. You should still have a slight rake if you do nothing to the rear
  14. Mar 29, 2015 at 7:03 PM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    so of i do a 1.75 lift with the front and rear, how much is it? and can you give me a list what i need? I want to do the same set up on my 09 sport.
  15. Mar 29, 2015 at 7:15 PM
    Ojohnson
    Ojohnson Well-Known Member
    Ollie
    York, SC
    06 Tacoma DCLB TRD Sport 4x4
    Replaced OEM lights with LED's for the following: MAP, Dome, License plate, and reverse lights.
    @rngr what do you have on the rear? And are you level or do you have some rake?
    Im about to purchase an AAL for the rear and I already have the Billies for the front just waiting for AAL to install everything. I was going to keep stock coils and set Billies at 1.75 but from what I hear I will still have some rake with my 1.5" AAL. So I'm curious about your OME 884's. I didn't want to spend more money but hey I will if I have to.
  16. Mar 29, 2015 at 8:26 PM
    Kieran
    Toronto
    None yet.
    So i think I will order all 4 Billies... i will run the fronts at .85" and just the shocks on the rear... I hope to level it out a bit and improve the ride... If i want to lift it a bit further in the future I will increase the lift on the fronts and add a AAL on the rear...
    does this sound like a good plan?
  17. Mar 29, 2015 at 8:36 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    I think this will accomplish exactly what you are shooting for. Please take before and after measurements, and post pics when you have it installed. I would like to accomplish the same end result - slight lift in the front, decent ride, and a little more room for 265/75-16 tires. Mine is a 2013 AC 4x4 TRD Off Road, with the rear 2+1 oem leaf springs...
    BTW, from most of the research I have done on this issue, if you want a bit more lift, I would seriously look at different springs with the Billies @ 0 or .85 instead of 1.75 with the oem coils. That's just me.
  18. Mar 29, 2015 at 8:42 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I left my stock setup in the rear and 5100's at 0.85. Trucks level and rides great.
  19. Mar 29, 2015 at 8:45 PM
    boatbuilder
    boatbuilder Well-Known Member
    Jim
    Tonasket, WA
    12 regular cab 4 cyl 4wd
    A lot!
    I second the Ironman system. I LOVE mine!!!!! Would do it again in a heartbeat.
  20. Mar 30, 2015 at 5:23 AM
    JohnnyWayne
    Johnny
    Lantana, FL
    '12 DCLB TRD Sport
    ^^ How long has that Ironman been on boatbuilder? Just curious.
    EDIT - Nevermind, found you in the other thread, you have the rusting issues as well it appears.
