Looking for some details from members
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nismo86, Jun 29, 2009.
  1. Jun 29, 2009 at 7:35 AM
    nismo86
    nismo86 [OP] Member
    I'm looking to buy a 05-06 tacoma extended cab but i'm not sure what features to get since I know there is so many packages to pick from. I know i'm going to get 4x2 unless I get a good deal on a 4x4, but the 4x4 gets worse MPG I believe.
    Which year is better, 05 or 06? Why?
    How come the auto gets 2 MPG better (when combined together?)
    What MPG are you guys getting and how do you drive? Looking for people who our stock since my truck will remain mostly stock.
    Going to be using it for carrying dirt bikes, a waverunner and everyday use.
  2. Jun 29, 2009 at 7:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    late 06 would be best, as the motor mounts are a little beefed up. The auto gets beter MPG due to a little taller OD gearing.
  3. Jun 29, 2009 at 7:46 AM
    ClemsonTacoma
    ClemsonTacoma Well-Known Member
    Cam
    Lexington, SC
    Tacoma
    Pioneer DEH-P5100UB single din HU and black dash kit, Alpine 12" sub custom inverted box bed liner'd, various interior trim painted black, 48 blue LED domelight, cheepo floor mats, hose clamp mod, Cobra CB and knock off firestik, Stock steelie rims, with 265/75/16 Sumitomo HTR Sport A/T's
    i have an auto 09 dc short bed, and i get around 19 city stock, i have a heavy foot and i rev the engine alot and burnout but city driving around here is all divided highway with merging so theres little to no stoplights
  4. Jun 29, 2009 at 7:51 AM
    nismo86
    nismo86 [OP] Member
    05 have bad motor mounts/failing ones?
  5. Jun 29, 2009 at 7:54 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The newer the better - seems they ironed out some things since they first came out.
    I have an 07 (produced in Nov 06 I think) and I consistantly get 18mpg (mix city/highway).I have an Auto Access cab 4.0L. I'm mostly stock....
    Since you're buying used, you might have hard time finding exactly what you want.
  6. Jun 29, 2009 at 12:12 PM
    nismo86
    nismo86 [OP] Member
    What do the different packages offer? Do the 05 has motor mount problems?
  7. Jun 29, 2009 at 12:22 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    The manual is geared differently so it's mileage isn't as good. It revs higher for a given speed than the auto. I was getting about 16mpg mixed and about 19 highway before adding the lift and the tires. Keeping the RPMs below 2000 (auto) will give you the best mileage.
  8. Jun 29, 2009 at 12:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    yes. There have been some instances in which they have failed.
  9. Jun 29, 2009 at 1:51 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    There is a sticky about the 05's and the motor mounts failing in the 2nd gen Taco section. ;)
  10. Jun 29, 2009 at 2:58 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    I was getting 20.5 mpg in my auto v6 before the tires. Do yourself a favor and get a 4x4. You MAY never use it, but its piece of mind to have it. Personally If I wanted a 2wd, I'd buy a car, but to each his own.
  11. Jun 29, 2009 at 3:01 PM
    ClemsonTacoma
    Cam
    Lexington, SC
    Tacoma
    yeah dont be like me and think your never going to use it, i wish i had it everyday
  12. Jun 29, 2009 at 7:48 PM
    nismo86
    nismo86 [OP] Member
    Yeah it might be a good idea, but how much worse is the MPG?
  13. Jun 29, 2009 at 8:01 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    It just depends on how you think you'll be using it mostly...
    I've had 4x4's most of my life, but don't go offroad as much as I used to. Bought an 06' prerunner access cab long bed and I'm glad I made the choice on 4x2. It still does great on hunting trails and the ground clearance is same as the 4x4. I'm getting 22.5MPG on the highway and around 17-18 in the city.
  14. Jun 29, 2009 at 8:14 PM
    nismo86
    nismo86 [OP] Member
    Wow sounds like some pretty good mileage. I'm sure the 4x4 will get 2 mpg or worse?
  15. Jun 29, 2009 at 8:18 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    4X4 seems to be about 1-2mpg difference, not much when you consider your needs. I am in the same boat as carmellocafe, offroad ability was not a major factor in my choice but I can still do what I need to.
  16. Jun 30, 2009 at 1:58 AM
    FoxRacR17
    FoxRacR17 Well-Known Member
    Kevin
    SoCal
    09 4x4 SR5 DoubleCab Short Bed
    Fox 2.5 C/O's, Fox 2.0 rear shocks, toytec 1.5" AAL, TC UCA's, blue/white dashboard lights, seatbelt chime removed, Synthetic leather armrests, WO seat covers front and back, Goodyear Wranger Duratrac 285/70/17, KMC XD Addict 17x9 rims
    I just filled up my 09 4x4 DC on my way down to work tonight and it took 15.2 gallons and went around 290 miles if i remember right, but what i do remember for sure is that I did the math and got 19.5mpg. I'm pretty happy with that.
  17. Jun 30, 2009 at 4:21 PM
    nismo86
    nismo86 [OP] Member
    Any other problems or issues with the 05-06?
  18. Jun 30, 2009 at 4:48 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    That's rare for a 4X4. Look at (hundreds) of MPG threads and you'll see.
