Looking for someone in Washington state to install my suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RUD3BOY, Feb 16, 2022.
  1. Feb 16, 2022 at 4:08 PM
    RUD3BOY
    RUD3BOY [OP] Member
    2021 Cement TRD OR MT
    I bought the ARB OME BP-51 suspension kit with heavy duty leaf springs, coil over shims that add an inch to the front coilovers, Sumo spring bump stops for the front and back, and Camburg Kinetic Series upper control arms. I'm looking for someone in Washington state that has experience installing these components. Most of the shops won't install them if they were not bought through them. I tried installing the front suspension myself but got confused and there is not any good instructions or YouTube videos to go off of. I have all the tools, jacks, and stands to do the job. Let me know!
  2. Feb 16, 2022 at 4:32 PM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
  3. Feb 17, 2022 at 4:53 AM
    PacoDevo
    PacoDevo Well-Known Member
    Pops
    Bazetta Twp. Ohio
    2016 SR5 DCLB white "Quinn the Eskimo"
    Find a good mechanic who works for a shop and see if he will do it on "the side/his free time"??
  4. Feb 17, 2022 at 6:53 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    If you were in CO. I would do it lol.
  5. Feb 17, 2022 at 11:46 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    If you have all the tools and some basic knowledge on how to use them, you should be able to do yourself. There are many videos on YouTube. I dove into myself and finished it in a weekend with the help of a buddy. I have to admit there were points where I was about to give up, but my buddy gave me the support I needed. :)
    CherylJane likes this.
  6. Feb 17, 2022 at 12:55 PM
    RUD3BOY
    RUD3BOY [OP] Member
    I have the tools, but I got both tires off and the sway bars disconnected then one video looked like it skipped a bunch of steps, then another video was using a short cut. It was starting to rain a bit so I got frustrated and panicked and put it all back together. I'm gonna give it one more shot before I pay someone.
  7. Feb 17, 2022 at 1:02 PM
    KingOfTheNorth
    KingOfTheNorth Kum and Go King
    97 4runner
    All the mods
    My first lift install I was a bit overthinking the process and thought it had to be harder than it actually was. There are some secrets that make the job way easier. All in all I have a suspension lift install down to about 4 hours by myself. Give or take depending on the beer intake. That lift isnt any different than any other so when you youtube it dont depend on searching for that exact lift install. You can search any 3" mid travel set up for the 3rd gen tacoma. If you have any questions fell free to pm me.
  8. Feb 17, 2022 at 1:04 PM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    •remove skid plate
    •mark cambolt positions
    •jack and block
    •loosen the LCA cambolts (you’ll need an alignment when you’re done anyway)
    •remove the lower knuckle bolts
    •swing LCA down
    •coilover comes down and out, easy peasy
    •break rear U bolts free
    •jack up frame ‘til rear hangs
    •block it
    •put the jack under rear diff
    •adjust it up/down to remove shocks then springs
    no sweat, you got it.
  9. Feb 17, 2022 at 1:05 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If your coilovers are assembled already, it is pretty easy. If not, this method is lower energy and safe. Be sure to have an alignment scheduled before you go at it:
    https://www.youtube.com/watch?v=jr0v63Q7CQs
    MNMLST likes this.
