Looking for sugestions on Lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Famouskmksrh26, Feb 11, 2010.
  1. Feb 11, 2010 at 6:58 AM
    Famouskmksrh26
    Famouskmksrh26 [OP] Active Member
    Sa, TX
    2003 4x4 TRD Limited
    TRD SuperCharged, Flomaster, Daystar 2 1/2" LVL kit
    Ok ive been look for almost a year now for a lift for my 03 4x4. i think i may have found one but im not sure.. Its a revtek 3" lift with blocks in the front and new longer rear shocks in the back...Let me know what you think..
    this kit is about 450 with the shocks from 4wheel parts and 300 to install..
  2. Feb 11, 2010 at 7:19 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    blocks in the front? you mean spacers in the front blocks out back?
    IMO thats a garbage lift and a rip off price on install and price of the kit. i had spacers on my truck and the ride quality went out the window after i put them on. i'd find a better lift. if your working on a budget then i'd look into the OME kits or bili 5100's.
  3. Feb 11, 2010 at 8:16 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    I would suggest coil spring lift kit from OME vs spacer lifts...check out ToyTec lifts.
  4. Feb 11, 2010 at 8:29 AM
    Famouskmksrh26
    Sa, TX
  5. Feb 11, 2010 at 8:36 AM
    sirsaechao
    Tim
    CA
    With your progressive rated TRD springs you will ride like crap with those hockey puck spacers from RevTek. I would suggest some OME/ToyTec coils matched with OME Nitro front and rear shocks, rear longer AAL for a better lift over spacers and blocks. Also most will suggest Bilstein adjustable 5100 front shocks over spacers for that price.
  6. Feb 11, 2010 at 8:58 AM
    Famouskmksrh26
    Sa, TX
    how much did all of that run you
  7. Feb 11, 2010 at 9:03 AM
    sirsaechao
    Tim
    CA
    Check out
  8. Feb 11, 2010 at 10:32 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
