Looking for suggested repair idea
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rich*2001, Jul 2, 2023.
  1. Jul 2, 2023 at 8:28 PM
    Rich*2001
    Rich*2001 [OP] New Member
    2001 tacoma prerunner v6
    None
    Hello, I'm new here and I'm looking for a fix. My 2001 tacoma prerunner has been pulling left and right, and the steering feels loose. It's been this way for years. I took it into the dealership, and they fixed it but that didn't last. I read it can be wheel bearings but I just wanted to see what TW could come up with.
    Thanks in advance.
  2. Jul 2, 2023 at 8:57 PM
    02hilux
    Planet: EARTH
    Wheel bearing? Is it making noise? Jack the front tire off the ground and shake/pull the tire to check for play and go from there.
    opteron likes this.
  3. Jul 2, 2023 at 10:37 PM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    What did the dealership "fix"?
    Bivouac likes this.
  4. Jul 5, 2023 at 4:58 PM
    Rich*2001
    None
    02hilux - No noise and no wobble. After watching a couple videos for referance, it seems it might be something in the steering column.
    Gen1andDone - I don't know but the steering felt unusual and it reverted after not too long.
  5. Jul 5, 2023 at 5:02 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    At a certain point, ya just have to replace everything in the front that's rubber.
    MalinoisDad likes this.
  6. Jul 5, 2023 at 6:00 PM
    Gen1andDone
    The invoice from the dealer should describe, even if brief, what work was done as well as parts that were replaced.
  7. Jul 5, 2023 at 7:41 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I was just about to say this. Yeah, replace all the bushings.
  8. Jul 5, 2023 at 7:49 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Welcome to TW…
  9. Jul 5, 2023 at 10:01 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    First thing I’d check is steering rack bushings- easy way to check, start the truck, kneel down so you can look underneath and move the steering wheel back and forth
    https://m.youtube.com/watch?v=9K9kgaN1X9Q
    no affiliation with the video and the example in the video is as bad as I’ve ever seen it because the truck is literally missing the bushing on the right u bolt but your rack shouldn’t move much at all.
  10. Jul 6, 2023 at 2:33 PM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Do your own front end shake down. Check all of the things that move or spin.
    Curious as well what the dealer did last time it was worked on. Especially since it "worked" but not for long.
  11. Jul 7, 2023 at 5:46 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Check tie rod ends. Where the steering shaft connects to the rack there is a rubber rag joint. This creates a loose feeling down the road. There is also a joint under the dash that can go bad. Also check the ball joints and steering rack. Worn control arm bushings, upper and lower can create a loose feeling as well.
