Looking for the perfect bed rack
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BigHealey66, Oct 25, 2018.
  1. Oct 25, 2018 at 7:56 AM
    BigHealey66
    BigHealey66 [OP] Member
    2018 Cement Tacoma OR
    Thinking about some mods!
    I'm looking for a bed rack that will be used for long loads (ladders, canoe, surfboard, etc.) for my 3rd gen short bed with factory trifold cover. The perfect rack would be cab height, bed rail mounted, and somehow compatible with the factory trifold tonneau cover. I bet there is a thread out there, but I couldn't find it. Any recommendations?
    Jeremy4x4 likes this.
  2. Oct 25, 2018 at 8:01 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
  3. Oct 25, 2018 at 8:07 AM
    Hextall
    Hextall Well-Known Member
    NH
    17 Inferno OR DCSB
    irayfz6 likes this.
  4. Oct 25, 2018 at 8:10 AM
    BigHealey66
    it's kind of utilitarian, but it checks off all the boxes. Thanks for the lead.
  5. Oct 25, 2018 at 6:12 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Our URTC will allow a cover to fold open, but being able to open the cover is highly overrated. Accessing the bed through the tailgate is pretty easy, and if you really need to open the cover, the rack is super easy to take off.
    Check out our TACO Max racks:https://www.max-modular.com/shop-max-modular/
  6. Oct 25, 2018 at 8:09 PM
    pralix
    pralix Active Member
    William
    2017 Cement Tacoma TRD Pro
    how do the URTC brackets work with a Bak Revolver? Can I fully roll the cover open?
  7. Oct 25, 2018 at 8:36 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    The only retractable covers it works with is the Retrax and Pace Edwards Switchblade.
  8. Oct 26, 2018 at 5:50 AM
    whoispurplegoo
    whoispurplegoo Well-Known Member
    SE Florida
    2018 MGM Sport 4x4 DCSB
    I searched for a while and couldn’t find anything that fit my needs and worked with the OEM tonneau. I only needed a rack for the occasional transport of paddle boards and lumber/ladders, so I wanted something that could be removed without a ton of effort. I ended up getting a Rola T3 and had the mounting brackets drilled out to fit around the tonneau cover latch pins. I wish I could find something where I didn’t need to remove the cover, but this works for now.
