Looking for towing mirrors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Frankenstein09, Aug 16, 2019.
  1. Aug 16, 2019 at 6:18 AM
    Frankenstein09
    Frankenstein09 [OP] Well-Known Member
    Russ
    NE Ohio
    06 TRD 4.0 SB
    Freshly stock
    NE Ohio. Looking for a set of used towing mirrors. Trying to save a buck. They are about $120 new. Let me know if you have a set and might be trading or selling you truck.
  2. Aug 16, 2019 at 7:40 AM
    Pigpen
    Dan
    Northwest Montana
  3. Aug 16, 2019 at 7:10 PM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
