Looking for TRD Skid Plate
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 1Shifter, Feb 20, 2016.
  1. Feb 20, 2016 at 12:35 PM
    1Shifter
    1Shifter [OP] Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    I'm looking for a slightly used aluminum TRD OEM skid plate for my 09 Prerunner. Toyota part number is PT21235075. I found one new online for a 196 bucks delivered but thought I'd check the used market. I live in Maryland, zip 20653.
  2. Feb 23, 2016 at 11:38 AM
    Bumpr1080
    Bumpr1080 Well-Known Member
    Andy
    Tabernash, CO
    06 TRD Sport
    Icon, all pro and more....
    I think I have what you're looking for. I replaced my 06 TRD Sport Aluminum skid with RCI skids last summer. You're just looking for the plate yes?
  3. Feb 23, 2016 at 2:37 PM
    1Shifter
    Jeff
    09 PreRunner
    Yep just the plate, I assume that I can just drop the old steel skid plate and swap it out with the aluminum plate.
  4. Feb 23, 2016 at 2:52 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Technically you stack them, leaving the black splash guard/skid plate still installed.
    Though I took mine off the other day without ill effects, it sits closer to the lower valance than it did before, but that's about it.
    I don't know why the Toyota install instructions say to leave the black piece installed, but they do.
  5. Feb 23, 2016 at 2:56 PM
    1Shifter
    Jeff
    09 PreRunner
    So the aluminum plate fits over the black steel skid? If so that's one less thing I have to worry about!
  6. Feb 23, 2016 at 2:59 PM
    T4RFTMFW
    Yeah, you remove the front 2 bolts and loosen the rear 2 bolts, slide the aluminum skid onto the rear bolts and let it hang. The black skid is supported by some metal hooks up front so it doesn't fall, and the aluminum skid is supported from the rear (it has notched openings for the rear bolts). Then you thread the bolts through the front holes in the aluminum skid, into the holes for the black skid, and then into the mount and tighten it down.
    1Shifter[OP] likes this.
  7. Feb 23, 2016 at 3:00 PM
    renlo
    renlo Well-Known Member
    2019 TRD OR 4x4 DBSB A/T
    No, the aluminum replaces the black steel one. There are 2 brackets pre installed on the aluminum skid plate with 2 new bolts. You reuse 2 of the original bolts.
  8. Feb 23, 2016 at 3:02 PM
    T4RFTMFW
    Not true.
    http://toyotaparts.sparkstoyota.com/install/PT212-35075inst.pdf
    #2(c) says "do not remove engine under cover."
    Aka black skid/splash pan.
    TRDSport10 and renlo[QUOTED] like this.
  9. Feb 23, 2016 at 3:09 PM
    renlo
    Well I guess I installed mine wrong, oh well, less weight.
    T4RFTMFW likes this.
  10. Feb 23, 2016 at 3:10 PM
    1Shifter
    Jeff
    09 PreRunner
    Sweet...sounds easy enough. I appreciate the advice!
  11. Feb 23, 2016 at 3:10 PM
    T4RFTMFW
    I took mine off last weekend. Only thing I don't like is how much closer it sits to the lower valence (like I said above), but it does look nicer with less of a gap in that area.
    Of course now when I get backed into at the drive thru again it'll just shove the skid into my bumper cover that much more than it did the first time.
  12. Feb 23, 2016 at 3:11 PM
    T4RFTMFW
    Super easy. Lining up the bolts through both skids was the hardest part of it, something that was easy when I removed the splash pan. Assuming the holes in both skids didn't line up very well the first time.
