Looking into a lift kit
Discussion in 'Hawaii' started by Alohajerry, Mar 12, 2018.
  1. Mar 12, 2018 at 7:41 PM
    Alohajerry
    Alohajerry [OP] Active Member
    Jerry
    Oahu
    2017 toyota tacoma trd sport 4x4
    Ive been looking around and i came across something i was interested in. I wanna do a 4” lift kit and i was looking into a Rough country. What do you guys i nothing tryin to go high or spend a lot just something i could afford
  2. Mar 12, 2018 at 7:52 PM
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    Have never heard anything good about Rough Country lifts.
    If affordable is what you have to work with, Bilstein 5100’s all around is usually recommended, plus 3-leaf Add-A-Leaf in the rear, and no more than a 3” lift.
    If you have some more cash, the Old Man Emu set ups are solid, as is the Bilstein 6112/5160 combo from the reviews.
    If you can wait and save up more, best would be to go for Kings, ADS, Icon, or Fox with leaf spring packs (Alcan, Deaver, or Dakars) and control arms (Total Chaos, Icon, Dirt King, BajaKits, or Camburg).
    justyr1 likes this.
  3. Mar 12, 2018 at 7:58 PM
    Harri Ant
    Harri Ant Active Member
    2017 Tacoma 4x4 O/R
    personally I would stay away from the bracket lifts, but to each its own.. I prefer function over height. Any of the kits stated above are proven, affordable, and easy to install
  4. Mar 13, 2018 at 12:45 AM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    anything over 2 inches, you should do UCA's. I got 2 inches on mine with 5100's and 2887's. they work great for me.
    also, I too have never heard anything good about RC stuff. But don't have any first-hand experience with them.
    What is your price point?
  5. Mar 13, 2018 at 12:52 AM
    aphillips916
    aphillips916 Well-Known Member
    Aaron
    Winchester, Kentucky
    2018 Cement TRD Sport
    What do you mean by 2887s? I just ordered Bilstein 5100’s all around and am looking to get old man emu lift coils
  6. Mar 13, 2018 at 2:44 PM
    TRDeeznutz
    TRDeeznutz Smash Da Skinny Pedal
    Kaleo
    Kapolei, HI
    2013 tacoma trd sport
    2887 coils are OME coil springs. They are actually made for 4runners but can also be used on tacomas. I have the same setup on my 2013 tacoma prerunner. Bilstein 5100’s set on the lowest purch an got 3” but im sure they settled a bit over the years and its more like 2.5”.
    aphillips916[QUOTED] likes this.
  7. Mar 13, 2018 at 2:56 PM
    aphillips916
    Aaron
    Sweet, so I’ve got Bilstein ordered for front and rear, do I need 2887’s in the front and rear or just the front? Or are add a leafs for the rear? So confused with all of this lol
  8. Mar 13, 2018 at 3:23 PM
    Harri Ant
    2017 Tacoma 4x4 O/R
    The bilsteins are adjustable up front have 3 or 4 different height settings, you can also pair them with different springs and use them on a lower height setting. The back will give you no additional lift, if you want to lift the rear you can add blocks, add a leaf, or just new rear leafs
  9. Mar 13, 2018 at 4:26 PM
    TRDeeznutz
    Kaleo
    Kapolei, HI
    Like everyone says if you’re going to lift the front higher than 2.5” it is highly recommended that you get aftermarket ucs’s. Since your already ordered 5100’s all around you can look into 886’s, 887’s, 888’s or eibach coils springs.
    As for the rear’s just like Harri said blocks, aals or new leaf packs.
    I have a set of 2” tapered blocks if your interested in going that route.
  10. Mar 13, 2018 at 4:32 PM
    wirenut
    wirenut I like this place
    Andrew
    NH
    98’ T4R
    OME/5100 - 300lb 3.5” loft setup Prinsu 3/4 rack
    There is a massive amount of information on this subject, if you do a simple search for “3rd gen lift”
  11. Mar 13, 2018 at 9:24 PM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    I got a RC lift set at a tad above 4 inches. It's solid. I don't do any heavy off reading though. If you do the 4 inch then you don't need UCAs cause they are staying almost exactly at the same angle as stock. If you do their 6 inch lift then consider UCAs.
    If it's just for street use or shmall kine off road then RC will do the trick just fine. If you are planning on doing heavy off-roading thena drop bracket probably isn't the best choice but with a little reinforcing work it'll be strong enough.
  12. Mar 13, 2018 at 11:29 PM
    ahkouchi
    Andrew
    Big Island Hawaii
    The OME on the 3rd gen are a little different. For the 2887 coils, they lift 2 inches. I know on the 2nd gen it is 3 inches.
    Hit me up in a DM and I might be able to help you more. Also, hit up Marie @HeadStrong Off-Road for help. I found them to be the best prices for shipping to Hawaii. They helped me a lot when lifting my 2016 Tacoma and my friends 4runner
  13. Mar 15, 2018 at 9:29 AM
    HeadStrong Off-Road
    HeadStrong Off-Road Well-Known Member Vendor
    2011 Toyota Tacoma and 2019 4Runner
    Thank you so much @ahkouchi for your recommendation we truly appreciate it! :broccoli::kona::dancingbacon::bananadance::taco:
    lemon177 likes this.
  14. Mar 17, 2018 at 12:30 AM
    lemon177
    lemon177 Well-Known Member
    Matthew
    Oahu
    09 tacoma 4x4 sport pyrite mica
    TRD supercharger, URD 2.85" stealth pulley, TRD exhaust, TRD intake, DTLT headers, URD y-pipe, TRD boost gauge, PLX DM100 touch with OBDII and SM-AFR modules, 885 OME 3", Icon UCAs, Satoshi grill, Solid rear window, SCS stealth 6, 285/75/17 toyo AT2.
    Also recommend @HeadStrong Off-Road Just ordered 5100s with 887 and aal for the rear. I know you already have/ordered 5100...but headstrong will also give you an option to have them assembled, which makes install ALOT easier
    This was for my dad's 2016 4x4 tacoma
  15. Mar 17, 2018 at 12:58 AM
    aphillips916
    Aaron
    Thanks, wish I had known that lol
    I’ve already gotten them in :rolleyes:
  16. Mar 17, 2018 at 1:03 AM
    aphillips916
    Aaron
    What’s the difference in 887 and 888? Doesnt 888 help it sit higher?
  17. Mar 17, 2018 at 1:06 AM
    lemon177
    Matthew
    Oahu
    Yes 888 is 5mm (iirc) taller.
    HeadStrong Off-Road likes this.
  18. Mar 17, 2018 at 1:27 AM
    aphillips916
    Aaron
    Is there any advantage to that over the 887?
  19. Mar 17, 2018 at 1:45 AM
    lemon177
    Matthew
    Oahu
    Depends on how deep you wanna go into it...now, at a certain point 4x4 will have faster wear to the cv boots with more height (some say 2-3 " is safe but anything more is pushing it). Another concern is that technically, no matter what spring you use 885/6/7/8, you are preloading that spring...yes they're designed for it, but when you compare them, the 888 will be stiffer that the 887 (they both have the same spring rate of 590). So if you want a plush ride, you want the spring that fits your setup, and that's why I'd go with @HeadStrong Off-Road recommendations.
