Looking into an RCD 4.5" Lift
Discussion in 'Arizona' started by ATriplett513, Nov 6, 2011.
  1. Nov 6, 2011 at 12:38 AM
    ATriplett513
    ATriplett513 [OP] Well-Known Member
    Phoenix, AZ
    2011 Dbl Cb, 4x4, 4.0L, 6-speed
    I've good things about the 4.5" RCD kit on here, so I'm considering that with some 33's on my truck.
    Anyone know of a good shop in Arizona that can do that lift?
    Also, 33's will fit well with the 4.5" lift, correct? I'm not looking for anything too crazy, just a good lift, good set of tires and I'll be set. Right now my average is 16.2mpg, what kind of drop should I expect? DCSB 6sp SR5
  2. Nov 6, 2011 at 12:12 PM
    ATriplett513
    Phoenix, AZ
  3. Nov 6, 2011 at 12:14 PM
    jerretxx
    jerretxx Some do, others talk
    Jerret
    North Carolina
    2017 DCSB TRD Sport 4x4
    I have 3" procomp and 285 BFG KM2 which is 33x11.50 and i average 15 city, but I also have DCLB Auto
  4. Nov 6, 2011 at 12:15 PM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    I can't help with the install question, but you know you can fit 285s (33s) without spending all that money on an RCD lift, right?
    Some aftermarket shocks, coils, leafs and UCA's will let you clear 285s.
    Fink
  5. Nov 6, 2011 at 12:22 PM
    ATriplett513
    Phoenix, AZ
    I was thinking Bilstien 5100/5150's, the Icon leaf pack and TC UCA's?
    The only reason I'm thinking about the RCD lift is to leave it open for bigger tires in the future.
    The only reason I'm even looking right now is that my grandfather died and he was gracious enough to leave me some money. He built and raced cars his entire life and his basement was a full metal-working shop. I know he would approve.
  6. Nov 6, 2011 at 12:24 PM
    Fink
    Orlando, FL
    If you do plan on going bigger than 285s in the future, then the RCD makes more sense.
    Sorry to hear about your grandfather, I lost mine on my dad's side in 2009 - still miss him everyday.
    Either way you go, I'm sure he'll be proud!
    Fink
  7. Nov 6, 2011 at 12:31 PM
    ATriplett513
    Phoenix, AZ
    Will my truck look weird with 33's and 4.5" of lift?
    He was a great man, I won't ever forget him showing me how to use a lathe when I could still barely walk :D
  8. Nov 6, 2011 at 12:53 PM
    Fink
    Orlando, FL
    Check out Solus' build - he has the RCC lift with 305's I think.
    If you're going to do the RCD lift, I would just go ahead and throw on bigger tires while you're at it.
    Sounds like my grandfather, he had me out in his workshop before I can even remember - he was a carpenter, so he had all kinds of woodworking tools and stuff.
    Fink
  9. Nov 6, 2011 at 2:21 PM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    That's a big negative ghost rider...it'll look mean as shit!
  10. Nov 6, 2011 at 2:25 PM
    bridgcat
    bridgcat Well-Known Member
    Alabama
    Mag Grey 4x4 SR5 TRD Offroad
    Avid Off-road Light bar w/ Line-X, American Aluminum Black LP Toolbox, N Fab black step bars,In-Channel Vent Visors, two 10" Rockford subs, Pioneer Double Din DVD player w/ Metra dash kit, 285/65R18 Nitto Trail Grappler MT/s. 18x9" Black XD Monsters. Weathertech digital fit floor mats. Color matched grille with FJ Tacoma badge. De-badged with black, "4x4" badge on tail gate. Mud flap delete mod. Custon TRD decal, color matched rear bumper, Icon extended travel reservoir coilovers, Icon rear reservoir shocks, Dakar rear leaf pack, extended stainless steel brake lines, Camburg uniball upper control arms, timeren bump stops,Beefed Taco carrier bearing drop, Rockford Fosgate Door speakers, Dynomat doors and rear panel, All pro front bumper.
  11. Nov 6, 2011 at 5:13 PM
    andercal000
    andercal000 Well-Known Member
    Calvin
    Everett
    2011 Tacoma TRD SPort
    RCD 4.5 inch lift kit
    RCD all the way! Rides really good. I have RCD lift with 295/70/17R and it rubs a little when u are in parking lot but other than that it's great lift and i'm very happy with it
  12. Nov 6, 2011 at 7:01 PM
    ATriplett513
    Phoenix, AZ
    Thanks for the advice everyone, I like what I'm hearing.
    Should I get a carrier drop bracket as well?
  13. Nov 6, 2011 at 7:05 PM
    bridgcat
    Alabama
    Where exactly are you rubbing at Calvin?
  14. Nov 6, 2011 at 9:30 PM
    andercal000
    Calvin
    Everett
    rubs on mud flap. i'll take pic where exactly it rubs tmw
  15. Nov 7, 2011 at 12:21 PM
    jtlachac08
    jtlachac08 Well-Known Member
    Jeremy
    Phoenix, Az
  16. Nov 7, 2011 at 4:02 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
  17. Nov 7, 2011 at 8:24 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    If you wheel I wouldn't do RCD... do something real like a by-pass setup with Fox/Icon/King/ect.
    4.5" will let you clear 33's (aka 285's) or even more... however even with 285's you will need to trim some plastic and do the body mount chop... you will rub at full flex up front. Rears will clear, but wheeling they will rip your rear flaps off. You'll also have to ditch the front flaps. Additionally, at turn and full flex up front you'll hit the body mount pinch weld... only way to fix that is flatten it or cut it out and weld it back shut. Most people just live with it, I have lol. I'm only sitting at about 2.5-3" at the moment as my coils aren't cranked up... but at flex it doesn't matter anyway.
    GL.
    Also for shops, check out SDHQ
  18. Nov 8, 2011 at 7:58 AM
    Specalt
    Specalt Well-Known Member
    Phoenix
    2001 TRD 4x4
    I just finished my RCD lift this weekend. I was able to do it in my garage.
    I love it. I'm running 305/60/17s I have not had to trim any thing. The kit is awesome.
    It took me about 2 hours to do the back and about 15 hours to do the front. It was a lot of work but I absolutely love it.
  19. Nov 8, 2011 at 8:19 AM
    bridgcat
    Alabama
    Post up some pics!
  20. Nov 8, 2011 at 8:23 AM
    Specalt
    Phoenix
    2001 TRD 4x4
    I'll get some up soon, I have a set of rear springs coming in, Should be here this week, as soon as I have them in I'll do a build page.
