Looking into getting a winch...
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgang123, Dec 30, 2009.
  1. Dec 30, 2009 at 12:46 PM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    so i have a couple questions:
    1. how strong of a winch should i get? would like 8000lbs winch work?
    2. how should i go about mounting it?
    3. is it possible to have a removable mount set up so i can move it to the rear of the truck, say like the trailer hitch?
    4. do i need a new front bumper of brush guard or something to mount it?
    any other advice would be great thanks.:D
  2. Dec 30, 2009 at 12:52 PM
    Sheepdog
    Sheepdog Well-Known Member
    Gary
    San Diego, CA
    Black 2002 Tacoma Xtra Cab, 4x4, TRD, SR5
    Eibach/Bilsteins, Beefed shackles, Bushwacker Cut-Outs, Custom roll bar, TG Sliders, Elite Front Bumper, XRC8 Winch
    Warn makes a winch mount that lets you slide it into the receiver hitch on the truck. So you can get another hitch welded on the front, then you can put your winch wherever you need it.
    If you go this route, you can save a lot of $$$. Instead of buying 2 winch bumpers and 2 winches. That's what I'm gonna do because I don't want to have to get out and keep swaping the big ass thing from front to rear all the time. And it looks sick.
  3. Dec 30, 2009 at 12:55 PM
    rustyshakelford
    rustyshakelford Well-Known Member
    Brett
    Magnolia, TX
    i bought a smittybilt xrc8 with syn line. so far its been great, but ive only been stuck once. if you want a multi mount, you will have to go with one from mile marker or one similar to it. the warn one will not work unless you do quite a bit of fabrication
    brett
  4. Dec 30, 2009 at 1:21 PM
    Wreckless_71
    Wreckless_71 WRECKLESS for Life...
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    3" Lift via OME 881's, Bilstein 5100's, Dakar OME 3" leaf packs, MBRP custom exhaust, HID headlights, CB, Canopy, aluminum wheels, upgraded sound system, full set of studded snow tires and wheels, auxilary lighting, more to come.
    Yeah man an 8K should work fine, I would go with a 9.5K if I was gonna do mine but I would use it for utility stuff other than getting my truck un-stuck. The reciever mount is pretty slick and is the way to go. Even when I build my plate bumper I'm gonna go with the reciever mount. That way you aren't limited to front only pull or rear only pull. My buddy has that set-up on his '92 and it's great.
  5. Dec 30, 2009 at 1:26 PM
    TacomaDan
    TacomaDan Don't go off ninjin
    Daniel
    Woodland, CA
    1996 Toyota Tacoma Fully Not Loaded
    Love, Cobra 29 LTD BT CB w/ A2000 Highgear antenna, FOX/Fabtech Coilovers, Magnaflow
    The good thing about a reciever mount is that you can remove it therefore decreasing weight so youre not wasting gas trying to push a winch and winch bumper around. Plus its kind of a security issue also. You can remove it so its safe at your house when youre not needing it!
  6. Dec 30, 2009 at 1:32 PM
    wolfgang123
    Skyler
    Charlotte, NC
    1997 TACOMA - 4x4
    i really like the reciever idea aswell, but i have never seen a reciever mount on the front of a truck though? where could i get one?
  7. Dec 30, 2009 at 3:37 PM
    rustyshakelford
    Brett
    Magnolia, TX
    the reason i didnt go with one is because they go below the bumper. in my opinion it wouldve been to low and more than likely would get hung up on stuff. i bought a custom bumper off craigslist and had a reciever mount installed.
    just google tacoma front reciever or call 4 wheel parts. they had one ordered for me for right at 180 if i recall
    brett
  8. Dec 30, 2009 at 3:58 PM
    Wreckless_71
    Justin
    Pullman, WA.
    98 ext cab Tacoma
    or you could pick one up from a junk yard rig and fab it in between the frame rails. just cut the 2 inch square out of the bumper for it to stick through...
  9. Dec 30, 2009 at 6:49 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    be careful on how ever you do it..I had the winch stolen off my old 4runner since it was just bolted on. Weld it if you plan on leaving it on the truck
  10. Dec 30, 2009 at 10:04 PM
    Sheepdog
    Gary
    San Diego, CA
    That's why I'm getting internal winch bumpers. So if they want to steal my shit, they're gonna have a helluva time trying.
  11. Dec 30, 2009 at 10:11 PM
    pittim
    pittim mittip backwards
    Pink slider.
    Superwinch EPi9S
