looking into getting fit
Discussion in 'Health' started by 95 taco, May 1, 2013.
  1. May 1, 2013 at 10:23 PM
    95 taco
    95 taco [OP] Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    i'm looking into getting fit, opinions appreciated.
    physical specs: 16, 6'3'' and 260 lbs
    goals:i want to get my endurance up, my weight down, and my strength up, and get rid of my moobs
    quick, intense workouts a few times a week?
    i benchpressed some tonight for the first time and i liked it, i also did a curl (?) on the bench and i liked those to, i have a bike to ride but i rarely do as i don't have alot of time.
    i also tried a rowing machine and i liked it.
    i like to run but i don't like the high impact on my joints.
    budget is as cheap as possible, i'l probably get a bench press from goodwill or somewhere for cheap.
    Edit: Update here on page 2
  2. May 1, 2013 at 10:29 PM
    iliketurtles
    iliketurtles Well-Known Member
    You have a bicycle? I rode mine A LOT when I was your age.
  3. May 1, 2013 at 10:39 PM
    95 taco
    yeah, a ful suspension mountain bike, i bought it 2 year ago as a birthday present and have never really used it.
    i'm gonna be starting college in fall so i'm thinking 3 15-20 minute high intensity workouts a week.
    i'm not really into sports so i doubt i'll go find a local team.
  4. May 1, 2013 at 10:58 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    work on cardio. Keep your heart rate up 30 mins a day. Weight training isnt going to burn fat as well as this.
  5. May 1, 2013 at 11:04 PM
    TyT
    TyT Well-Known Member
    Ty
    Canton, GA
    2016 Black Tacoma TRD Sport
    diet is everything man its literally 90% diet 10% gym
    if your going to go hard as hell in the gym it does you know good to that then eat like shit!
    PM if you want I just helped another member on here yesterday so ill be happy to help you too!
  6. May 1, 2013 at 11:07 PM
    2008taco
    chris
    san diego
    ^^this too
  7. May 1, 2013 at 11:20 PM
    95 taco
    so if i exercised thrice a week, i'd go 2 cardio 1 weight training?
    i do juice 2-3 times a month, i should probably do it more often, but my diet probably isn't gonna change to radically, i'll add a few veggies and fruits to lunches and dinners.
    thanks, i might.
  8. May 1, 2013 at 11:22 PM
    tn2012taco
    tn2012taco Well-Known Member
    Nathan
    Nashville, TN
    '12 PreRunnin Trooper
    Plasti-dipped wheels, Bilstein 5100's @ 1.75, 1 in. block in rear, CB in center console, 12V outlet in console, weathertechs, N-FAB wheel-to-wheel 3in. tube, Action packer cheap toolbox, Spidertraxx 1.25" spacers, Kensun 5000K in fogs, K&N drop-in filter, foglight anytime mod, Anytime Panty-dropper mod.
    Do you play any brass instruments? Best way to get in shape is to do a summer of drum corps.
  9. May 1, 2013 at 11:23 PM
    95 taco
    no sir, the only instrument i play is piano, and that is mostly played by ear.
  10. May 1, 2013 at 11:24 PM
    95 taco
    i don't drive every day, i have projects that i work on at home, fixing up a 1948 cub, and finishing a storage space in our barn so we can sell our house and move out of state.
  11. May 1, 2013 at 11:26 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Juice as in...steroids?
    I hope not if you've just started lifting! That's a quick road to hurting yourself.
  12. May 1, 2013 at 11:27 PM
    95 taco
    no, juice as in putting a apple, carrots, and celery in a juicer and making a drink.
  13. May 1, 2013 at 11:53 PM
    2008taco
    chris
    san diego
    My neighbor and his friend were both about 260 less than a year ago. They disagreed about which way to lose weight was best. One went to the gym everyday, the other walked 3-4 times a week and got on the atkins diet.one has lost 95 pounds, the other 35. Care to guess which one lost the most? The one who dieted lost 95 lbs. <answer.
    You're wasting your time without major diet changes. This doesn't mean just eating more fruits and vegetables. These contain A LOT more sugar than you would believe. Juice is even worse as it leaves you with mostly sugar and water and removes a large percent of the other nutrients.
    Dieting also doesnt mean suffering. You might be surprised that things like steak, cheese, butter etc, arent that bad for you. Its all about control, and after a week or two it becomes an easy habbit.
    Toyota4x46921 likes this.
  14. May 1, 2013 at 11:57 PM
    Camo23
    Camo23 Well-Known Member
    Drew
    Fallbrook, CA
    08 DC 4x4
    Not much yet
    cardio(as much as you can push yourself without hurting yourself) and diet. once you start losing the weight then lift weights.
  15. May 2, 2013 at 7:16 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    No radical diet changing are going to happen? Then you don't really want to loose weight. You are age wise a part of the fastfood generation. Unless you have a chemical issue in your body, your diet is what caused you to become so large.
    3 high intensity 15-20 minute workouts a week? Can't see you making it 5 to 10 minutes at your size being 16. Start by getting on a treadmill and cycle bursts of high intensity to build up to it.
    You like bench, curls and rowing? Then you are doing them wrong. When you row shoot for 500 meters in under 2 minutes. Build up to 1000 meters in under 4 minutes. You won't like it much after that.
    It won't be easy, but that's why America is obese.
  16. May 2, 2013 at 8:15 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Train for boxing, at first you will be puking a lot if you push yourself, but within 5 months you will be a boss...
    Not sure of there are boxing gyms near you, but I boxed for a few years and damn I looked like a statue! A small one, but still...and had cardio for DAYS!
    I have been working out most my life and boxing training was the singlemost difficult training I ever had by far.
    My .02
  17. May 2, 2013 at 2:44 PM
    95 taco
    mom and dad used to do dieting, i'm not a fan, i'd rather cut back on what i eat and not change it to much.
    i don't like steak, but my big weakness besides chocolate is burgers (especially venison burgers).
    my diet before i left on my trip was, breakfast: 2 eggo waffles with creamy PB and a little bit of honey.
    lunch: usually a ham sandwich with mayo on one side, 2 slices of ham, and a slice of cheese.
    supper: varies widely, almost always something that mom fixes.
    i talked to my cousin today (she's doing cross fit), and she said that rowing is cardio? i could do rowing.
    not really, i think if i increase my activity level, and decrease my caloric intake i can lose weight, it won't be fast but that isn't the goal.
    that's the goal, maybe i won't be able to it that long when i first start, but i'll work up to it.
    the reason i liked the bench and curls was i was in competition with a friend to see how many we could do of the different weights, and i think we were doing them right, lay on your back, pick up the bar, bring down to chest, then lift until your elbows lock right?
    the curls i did laying down to just bring my hands together over my chest.
    the rowing i did right, i was doing 500m in 2:10.
    i've used a punching bag before, it's fun but i don't like it that much.
  18. May 2, 2013 at 3:10 PM
    2008taco
    chris
    san diego
    Don't lock your elbows, stop just before that. You want as little impact on your joints as possible when especially when yyou have extra weight on them.
  19. May 2, 2013 at 3:16 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Try a low carb diet, meats and veggies. You will lose alot more wieght in 30 minutes of an intense workout then a 2 hour bike ride. You could do thirty minutes of uphill mountain biking one day and do wieghts and abs the next. When doing wieghts and abs try not to take breaks. go from one intense activity to the next keeping your heart rate up. 2 weeks of this and you will see results. I promise.
  20. May 2, 2013 at 3:19 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    not meaning to hi jackt hread but running 30 min day how would you run 30 min jog? springs?
    thanks
