LOOKING INTO GETTING KING SHOCKS??
Discussion in 'Suspension' started by WTFaulkner, Feb 26, 2013.
  1. Feb 26, 2013 at 12:22 PM
    WTFaulkner
    WTFaulkner [OP] Well-Known Member
    Kris
    SLC
    Tacoma
    Stuff
    looking into getting King 2.5" King Remote Reservoir Coilovers w/ Adjusters, for my 07 Toyota Tacoma
    and am also looking to to getting a 2.5"-3" lift but and am wonering witch order to buy all of my items?
    Lift & tires then springs or what? not very experienced under the hood but i am learning more and more every day and dont plan on stoping..
    Would research more but im currently working and dont have the spare time.
    Thanks guys:rasta:
  2. Feb 26, 2013 at 12:28 PM
    tostidos
    tostidos Well-Known Member
    Apple Valley, CA
    07 LT 6spd
    I would save the tires for last. And by springs you mean leafs or coil springs?
  3. Feb 26, 2013 at 12:40 PM
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    King 2.5" King Remote Reservoir Coilovers w/ Adjusters:rasta:
  4. Feb 26, 2013 at 12:49 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    well the kings would technically be your "lift". you adjust the coil with their spanner wrench. I dont know enough about the stock replacement stuff you may need after market UCAs and spindles.
  5. Feb 26, 2013 at 12:51 PM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    the king OEM replacement system will give you safely 2.5"-2.75 in stock config, UCA replacement up to 3 inches.
  6. Feb 26, 2013 at 1:13 PM
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    So in other words the King 2.5" King Remote Reservoir Coilovers w/ Adjusters im looking at will be giving me a 2.5"-2.75" inches higher than stock??
  7. Feb 26, 2013 at 1:15 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Yes
  8. Feb 26, 2013 at 1:16 PM
    SoCaltaco65
    x2
  9. Feb 26, 2013 at 1:26 PM
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    Awesome thanks fellas
    And what would you guys recomend to get the extra 1"-.5" lift after the KINGS? theres soo much that can be done :cool: lol. but i dont want to drop my diffs either.:rasta:
  10. Feb 26, 2013 at 1:36 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    like said before aftermarket UCA.
  11. Feb 26, 2013 at 1:37 PM
    Mitch
    Mitch
    Spokane, WA
    Crank the kings up till you get your desired height
  12. Feb 26, 2013 at 1:39 PM
    akaryanreynolds
    akaryanreynolds STRIKER TRD
    Los Angeles
    2012 DCLB MGM TRD Sport 4x4
    Debadged, Tint, Euro Antenna, OEM Roofracks, OEM skid plate, SMD LED interior lighting, AFE ProDry Drop-in, FX-R 6000K headlights w XB halos, VHT taillights, Fog light mod, Flyzeye V2W, T-Rex T1 Eyelids by Toyota Man, King 2.5 resis Front and Back, Devil Horns by Andres, Redline Hood Struts, PIAA 2500K H11 Fog Bulbs, Escort 9500ix, Ultra Gauge, Cobra 75 WXST, Firestik II w/ Quick Disconnect & Spring
    Get some total chaos UCA's. Just wondering what you getting the adjusters for?
  13. Feb 26, 2013 at 1:41 PM
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    Wont that make for a really "stiff" or unpleasant ride?
  14. Feb 26, 2013 at 1:48 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    nope you arent compressing the springs you are only moving them down.
  15. Feb 26, 2013 at 2:03 PM
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    Ok thanks :rasta:.
    So wanting a 3" lift and 285 tires (maybe 33x12.5) i can go with the KINGS im looking into and get about a 2.5"- 3" lift just with thoes?:D
  16. Feb 26, 2013 at 2:05 PM
    tostidos
    Apple Valley, CA
    07 LT 6spd
    well in the front yes.
  17. Feb 26, 2013 at 2:06 PM
    Large
    Large Red
    You need a rear lift too, like blocks, add a leafs, or a new leaf pack.
  18. Feb 26, 2013 at 3:35 PM
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    Are these King 2.5" Rear Remote Reservior Shocks w/ Adjusters, 2005+ Toyota Tacoma going to do the same thing as the front pair would do?
    http://www.offroadshocks.com/product...5001-121A.html
  19. Feb 26, 2013 at 3:44 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    By "Cranking" up a set of coilovers, compressing the springs is exactly what you're doing... You're gaining lift by preloading the coils so yes, it will make the ride stiffer. You can avoid this by buying taller springs.
    Rear shocks do not provide lift, they just dampen the ride.
    I gotta ask... King is great and all, but their remote reserior shocks and coilovers are pretty high end and built specifically to perform in high cycle rate applications. Do you have a need for that level of performance, if not you could save yourself some serious money. Do you need the performance of a remote resi shock or would a non-resi King, Icon or Fox shock do everything you'll need? If you have the money to blow, I'm not trying to talk you out of it, but at that price range you should know what you're buying.
    Lastly, if you're going to dump all this money into your suspension, I'd consider extended travel coilovers.
  20. Feb 26, 2013 at 3:58 PM
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    Pugga: Would the ride quality be the same with longer springs (just less preload on the longer springs)? I'm wanting 3" of lift out of Icons but I'm afraid it's going to be shitty if I crank them that high without longer springs!?
