looking to add a lift
Discussion in 'Suspension' started by debuhr, Jun 18, 2011.
  1. Jun 18, 2011 at 2:32 PM
    debuhr
    debuhr [OP] Active Member
    Illinois
    2006 Toyota Tacoma 4X4 TRD SR5 Double Cab
    hey ive got some questions about adding a lift kit to my 06 4wd tacoma. actually, i have no idea im doing so we can start there. i am looking to just add a small suspension lift. not much over 2in but enough to notice that its lifted. i am in the process of adding some bigger tires and i think it needs a lift to balance it out. ive dont some looking, but i really dont know what im looking for to be honest. if anyone has any info as far as what EXACTLY to look for online, that would be great
  2. Jun 18, 2011 at 2:43 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    Your in the right place to be looking!
    Use the search button on the site.
    Search for bilstein 5100. You'll find a ton of info on them. Your best bet would be to get these. They are adjustable to a few different settings. The 1.75" option would be what u might want to do.
    Stay away from any spacer lifts.
  3. Jun 18, 2011 at 3:18 PM
    debuhr
    Illinois
    ok thanks. if you dont mind, just so i dont order the wrong thing...could you try to find a link to EXACTLY the ones i need to order (front and back)? i have found several different sites, but they all look different and they also have a bunch of numbers, settings, ect that i honestly dont really understand. im sorry to be asking so many questions but im not the most mechanically inclined person you will meet lol thanks for all of your help.
  4. Jun 18, 2011 at 3:27 PM
    trdtaco10
    trdtaco10 Well-Known Member
    Fayetteville, NC
    '10 TRD OR 4X4
    UWS toolbox, window tint, Bilstein 5100s on all four corners, black 16" TRD FJ wheels, 14" Shorty Antenna, Weathertech all weather floor liners, Satoshi Grill Mod, Rear leaf TSB, OME 885x's, Desert Racing UCAs, Icon 3 leaf AAL
    Don't have the exact numbers for you but Downsouth Motorsports is the best place to get new 5100s. They won't send you the wrong thing. personally I have the 5100s and they are good but the ride is a little firm set at 1.75 so i am getting some OME coils (885s) and letting the springs do the lifting instead of compressing the coil with the shocks. I'm also getting an AAL to make 2.5-3 inches of lift. Do note however that you need new UCA's (upper control arms) to get your alignment back in spec if you go 2.5+. I would recommend a set of OME 884s and a set of 5100s to give a good ride along with that 1.5-2 inches you are looking for.
  5. Jun 19, 2011 at 10:22 AM
    debuhr
    Illinois
    Ok so the coils are optional from what I understand?
  6. Jun 19, 2011 at 10:28 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Yeah, if you get the adjustable 5100s you won't need new coils. I would also check out Toytec Lifts
  7. Jun 19, 2011 at 10:31 AM
    trdtaco10
    Fayetteville, NC
    '10 TRD OR 4X4
    Yes they are but you will get a better ride if you let them do the lifting. The 5100s have better valving than the stock shocks/struts hence better ride yet again and they are a little longer than stock shocks so you can articulate better offroad. I would recommend saving a lil more money and getting both so you don't have to pay one on and then decide you want the other also and have to pay again to have then taken apart and put back together again.
  8. Jun 19, 2011 at 3:57 PM
    debuhr
    Illinois
  9. Jun 19, 2011 at 5:04 PM
    trdtaco10
    Fayetteville, NC
    '10 TRD OR 4X4
    either that one with the setting on .85 or OME lift kit with 884s and a 1 1/2 inch AAL not the 2 inch unless you want factory rake or possibly more depending on settling. Like i said before anything over 2.5 up front and you need some expensive UCAs. The eibachs have to compress the coil to get the 2-2.5 inches it will provide hence rougher ride whereas the ome coils do all the lifting and aren't compressed. BTW you can't go any bigger than 265/75/R16 on the stock wheels without a 3 inch lift. someone correct me if I'm wrong but the only way to fit 285s is to remove the mudflaps and put on some wheel spacers.
    ...this gets to be a very expensive hobby quick lol
  10. Jun 19, 2011 at 6:16 PM
    elwood
    elwood "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    I think what you are trying to do is similar to what I did. These are a couple of threads for my research and installation.
    http://www.tacomaworld.com/forum/suspension/149572-884-dble-cab-install.html
    http://www.tacomaworld.com/forum/suspension/140680-884-885-2nd-gen-double-cab.html
    I too agree with having the coil lift the truck without preloading it (5100 set at other than 0) and an aal. No block and spacer. Even keeping around the 2.5 inch area of lift does not eliminate the possibility of UCA swap for alignment. It is all a matter of what you expect out of the truck and what you will live with.
    Cheers and good luck:)
  11. Jun 21, 2011 at 11:51 AM
    debuhr
    Illinois
    after looking and talking with some friends, i think i am going to go with this lift http://roughcountry.com/toyota_4wd_tacoma_3.html just wanted to check with everyone on here to make sure it looks like a good one? comments and suggestions?
  12. Jun 21, 2011 at 12:10 PM
    CristianTRD
    CristianTRD Well-Known Member
    Cristian
    Texas
    08 PreRunner TRD
    Ehh.. I would rather go with the 5100's and the 885 coils for the front as mentioned before. I would stay away from the rear spacers and use add a leafs. I would rather spend more money now for something that will be better in the long run.
  13. Jun 21, 2011 at 12:35 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    Tough to beat the price but you get what you pay for. Don't expect that kit to hold up to any serious off roading. I'd rather have the coils and an AAL doing the work vs spacers and blocks.
  14. Jun 21, 2011 at 12:39 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    you will regret going with that set up.... bilstein 5100s in the front, and a add a leaf in the rear.
  15. Jun 21, 2011 at 3:09 PM
    debuhr
    Illinois
    I'm not really looking for an off road lift as much as just as lifting it for looks. Even with that being the case, I should still avoid that lift?
  16. Jun 21, 2011 at 3:39 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    Just get the 5100's from Downsouth Motorsports, and call it a day. You can get all 4 for $283! Set them at 1.75, or 2.5" in the front and they will ride better then a spacer lift. Throw in another $80 and get a 1.5"/ 2" AAL and you'll be gravy. From what you have said about wanting not much over 2" this would be a great way to go compared to that spacer lift. Set the fronts at 1.75", get a 1.5" AAL and it will look great and you won't need UCA's.
  17. Jun 21, 2011 at 4:02 PM
    debuhr
    Illinois
  18. Jun 21, 2011 at 4:10 PM
    kmok
    Kyle
    Columbus, Ohio
    Blocks in the rear and spacers up front...will most likely ride like crap. 5100s all around and an AAL will be the best way to go for cheap.
  19. Jun 21, 2011 at 4:11 PM
    kmok
    Kyle
    Columbus, Ohio
  20. Jun 21, 2011 at 4:52 PM
    debuhr
    Illinois
    do i just need front shocks or get all 4 5100's?
