Looking to buy 2013 TRD Off Road
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kools, May 6, 2020.
  1. May 6, 2020 at 9:28 PM
    kools
    kools [OP] Member
    DFW
    2012 DCSB TRD Sport
    Hey y’all I’m looking to buy a 2013 Tacoma with 93,000 miles from a local dealership. It’s only got one owner and looks really clean. They let me borrow it for a night. What should I look for or look at to make sure as best I can this is a good truck to grab.
    Thanks for any help
  2. May 6, 2020 at 10:11 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Look at the frame for rust.
    Also inspect it visually for any leaks while you are under there.
    I’d check to see that the 4WD works along with the Locker.
    They can get “finicky” when not used frequently and with age. (Age not likely in your case)
    Other than that, Drive it and go from there.
  3. May 6, 2020 at 10:31 PM
    kools
    kools [OP] Member
    DFW
    2012 DCSB TRD Sport
    Thanks. It switches really well between 2 and 4WD. Drives well. Right now I’m having an issue getting the doors to lock with the remote. They lock then unlock. Can’t get them to lock without using the key. The rear door locks but the fronts don’t when I press lock.
  4. May 6, 2020 at 10:32 PM
    kools
    kools [OP] Member
    DFW
    2012 DCSB TRD Sport
    There’s a light that flashes on the center dash that has is a key symbol inside a truck. What’s that?
    Can’t find it in the manual
    found it. Just the security.
    still. Can’t figure out why the doors won’t lock with the remote.
  5. May 7, 2020 at 4:45 AM
    Steadfast
    Steadfast Well-Known Member
    Thane
    S.W. Ontario Canada
    2013 Limited
    Does that one have the backup camera in the rear view mirror?
  6. May 7, 2020 at 6:41 AM
    kools
    kools [OP] Member
    DFW
    2012 DCSB TRD Sport
    Yes it does
  7. May 7, 2020 at 7:05 AM
    Lindelowj
    Lindelowj Well-Known Member
    Jordan
    Texas
    2015 TRD Supercharged 4x4
    TRD supercharger kit, TRD skidplate
    Sounds like a door lock actuator possibly failing
  8. May 7, 2020 at 7:13 AM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    2013 - Best Year™
    Frame rust is probably the big one.
    But then like was mentioned, other obvious leaks/noises.
    I had my rear main seal go just before the warranty had expired, and have heard from a few others on this forum of theirs going early as well. Not super common, but seems like it could happen. So just look for oil film/spray.
    kools[OP] likes this.
  9. May 7, 2020 at 7:16 AM
    kools
    kools [OP] Member
    DFW
    2012 DCSB TRD Sport
    Well it’s weird. It used to chirp when I unlock the doors. Now it chirps once when I lock the doors. I put the key in and turned and held it in one direction for a few seconds so I wonder if that changes the chirping
  10. May 7, 2020 at 7:18 AM
    13tacosport
    13tacosport Well-Known Member
    Arbi
    818
    13 Trd Sport
    What’s the price? My 2013 Trd sport is 2wd and had 92k miles when purchased last July for 23 out the door. One owner and super clean. Just curious
  11. May 7, 2020 at 7:20 AM
    kools
    kools [OP] Member
    DFW
    2012 DCSB TRD Sport
    $20,900
  12. May 7, 2020 at 7:23 AM
    13tacosport
    Arbi
    818
    13 Trd Sport
    Sounds like a good price. Run it by a mechanic before purchasing it. Good luck man
  13. May 7, 2020 at 7:33 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I would look for signs for possible flood damage. Not due to it being a Toyota or a Tacoma but due to dealers buying from auctions. Are there rust stains under the dash, dirt where it should not be, is the carpet in better shape than it should be for mileage, etc..
  14. May 7, 2020 at 8:46 AM
    amyracecar
    amyracecar suck it up buttercup
    Virginia Applejack
    SouthEast USA
    2013 AC V6 MT OR Spruce/Mica
    I second this. .
    I was in the market for a 2nd gen till a month ago. .
    The first one I test drove, drove fine but when we put it up on the lift to do a pre/purchase/inspection [which should cost you 30/40$ and is totally worth it] - it was complete RUST BUCKET!!
    So 3 months later, I thought I found the winner - 53K miles V6 MT OR AccessCab - one owner, it lived in Arizona for its whole life - dry heat, no salt roads etc. .
    & when i took it to a local mechanic for a pre/purchase/inspection - it passed with flying colors. .
    - no play in the U/joints
    - all the fluids, including tranny/diffs were clean/new/fresh
    - all OEM glass, no evidence of damage
    - not a spec of rust
    - clearly it had been cared for, the undercarriage was in great shape as was the engine bay
    Pre/purchase Inspection all the way!!
