Looking to buy 2nd gen that has been sitting for 9 months
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kurts74, Jul 11, 2018.
  1. Jul 11, 2018 at 11:10 AM
    kurts74
    kurts74 [OP] Well-Known Member
    Flagstaff, Arizona
    2nd Gen 4-door longbed
    ICON Mid travel set up with Hard candy shell
    I have a lead on a 2nd gen Tacoma with low miles ~45k that has been on blocks in a garage since October. It was taken out once during that time for a 10 mile drive. After purchasing I will need to get it home ~120 miles and then would like to take it on a road trip in short order. Hoses and belts all look good. I will check all fluids for levels and overall condition, but are there any fluids you would say without a doubt replace right away, or any other input about how to make sure it comes out of storage successfully?
    Much appreciated.
  2. Jul 11, 2018 at 11:17 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    9 months is nothing. Fire a Jerry can of high octane gas in there and Trickle charge the battery then fire it up!
  3. Jul 11, 2018 at 11:50 AM
    JdevTac
    JdevTac Bawnjourno
    Josh
    GA/MD
    2013 DC TRD-OR 4x4 Pyrite Mica
    Why was it sitting for 9 mo?
    ChemDawg likes this.
  4. Jul 11, 2018 at 1:10 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Cypress Texas
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Put the key in it and start it. Then drive it like you stole it.
    koditten and black coffee like this.
  5. Jul 11, 2018 at 1:13 PM
    zmanlane
    zmanlane Well-Known Member
    South Florida
    2011 MGM Reg Cab 4x4
    Price?
  6. Jul 11, 2018 at 1:15 PM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    2013 Super White Tacoma DCLB TRD SPORT
    Pics?!?!?!?!
  7. Jul 11, 2018 at 4:24 PM
    Tcomaboy
    Tcomaboy Well-Known Member
    TX
    2010 PreRunner Sr5 TRD LongBed
    Only thing I’d be concerned about is the battery. Just replace it and go on your merry way.
  8. Jul 11, 2018 at 4:31 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Have a look at the tires for sidewall cracks and drying out.
  9. Jul 11, 2018 at 4:35 PM
    Ten Rounder
    Ten Rounder Old Man and his Dog
    Western Idaho
    2010 silver AC 4x4 2.7
    9 months? Sounds like and impound or repo. Maybe even a drug mule with hidden compartments, don't get stopped
  10. Jul 11, 2018 at 4:37 PM
    hemmjo
    hemmjo Well-Known Member
    Central Ohio
    2005 Access Cab 4wd, TRD, Off Road, Tow Package
    In addition to the issues mentioned....
    If it is in an area with big temperature changes I would be a little concerned with the fuel left in the tank. It can absorb moisture during the temperature fluctuations, then the wet fuel causes corrosion in tank, and fuel pump.
    I would drain the tank as much as possible, then fill it with fresh fuel.
    It may not be an issue, but its possible.
    Barzini and Motofox like this.
  11. Jul 11, 2018 at 4:39 PM
    dustin19d
    dustin19d Well-Known Member
    NorCal
    06 Sport, 4X4, 6-Speed
    AllPro, Armorology, Mobtown, Pelfreybilt
    Mine sat in a storage unit for 15 months while I was in Iraq. Fired right up when I got home.
    honda50r likes this.
  12. Jul 11, 2018 at 4:40 PM
    rnish
    rnish Well-Known Member
    Maryland USA
    Tacoma
    Run some injector cleaner through it, modern (read that’s a ethanol) gas starts to turn to jelly after 3 months.
    Barzini likes this.
  13. Jul 11, 2018 at 4:51 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white
    mods in process
    Why was it up on blocks?
  14. Jul 11, 2018 at 4:52 PM
    kurts74
    Flagstaff, Arizona
    Just to keep the tires in good shape.
    tacoguy88 likes this.
  15. Jul 11, 2018 at 5:08 PM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    Start it up and go.
    Change oil after a good hour drive
  16. Jul 11, 2018 at 6:44 PM
    Tcomaboy
    TX
    That’d be the jackpot!!!
  17. Jul 11, 2018 at 6:49 PM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    If u don't buy it can I have first dibs?
  18. Jul 11, 2018 at 7:45 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    9 months is nothing assuming it has at least been under carport. Hopefully the battery was disconnected too. Worse case scenario is you might need a battery... assuming the truck was in ok shape before it should be good to go.
  19. Jul 11, 2018 at 9:16 PM
    kurts74
    Flagstaff, Arizona
    Thanks for all the info. We tried to make deal several months back with a partial trade for mine, but couldn't get to terms. He eventually got busy let his CL add lapse for a few months then put it back up last month, so its just been sitting. I got a buyer for my 1st gen lined up so hoping to drop down and pick it up this weekend. He recently replaced the battery so should be good there.
  20. Jul 12, 2018 at 6:03 AM
    jross20
    jross20 Well-Known Member
    Georgia
    2011 White Tacoma Prerunner SR5 | V6 | Auto
    Dakar leafs & nitrochargers, running boards, ditch lights
    Make sure to check and change fluids. Oil may be gunky.
