Looking to buy a 2008 toyota tacoma
Discussion in 'New Members' started by Karen74, Nov 28, 2018.
  1. Nov 28, 2018 at 7:52 AM
    Karen74
    Karen74 [OP] New Member
    Karen
    Colorado
    2008 toyota tacoma
    One of my dreams is coming true always wanted a toyota tacoma I found a 2008 with 83k miles for 17k what should I look at to make sure I'm not buying a lemon its a Manuel trans with access cab please help it's been one of my dreams to own a Tacoma but have no clue what to look for help it's also a v6
    Bigdaddy4760 and irayfz6 like this.
  2. Nov 28, 2018 at 7:57 AM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Welcome to the forum Karen.
    I’d say the frame condition is the biggest issue with these trucks.
    Maintenance records are nice to see.
    buckhuntin-tacoma and irayfz6 like this.
  3. Nov 28, 2018 at 10:00 AM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Welcome!
    As others have stated, frame rust is the biggest issue to look out for.
    buckhuntin-tacoma likes this.
  4. Nov 28, 2018 at 10:25 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!!
    irayfz6 likes this.
  5. Nov 28, 2018 at 10:32 AM
    Clearwater Bill
    Billy
    Largo Florida
    Pay a trusted independent mechanic for a pre purchase inspection, incuding a compression and leakdown test. And a proper frame inspection as others suggest.
    boostedka, Dawdaw808 and irayfz6 like this.
  6. Nov 28, 2018 at 8:14 PM
    Bigdaddy4760
    Maner
    Poolville Texas
    Welcome to TW!!
    :hattip: :cheers:
    irayfz6 likes this.
  7. Nov 28, 2018 at 8:24 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    This x 2.
    irayfz6 likes this.
  8. Nov 28, 2018 at 9:27 PM
    Dirt King Taco
    Dirt King Taco Well-Known Member
    Deric
    Oxnard, CA
    2010 TRD OR 4x4 LT
    This is excellent advice. If it's not an option for some reason, here are some steps I take when purchasing a used vehicle - nothing Tacoma specific though:
    • Start it cold. A lot of issues 'go away' once warmed up. Small exhaust leaks, burning oil, bearing noise, etc...
    • Test all the electronics. Windows, Stereo, HVAC, locks, mirrors, etc..
    • With the owner's permission, drive it a little hard. Go through the gears at WOT, test for steering play, slam the brakes - test that ABS.
    • Plug in a scanner. They're pretty affordable now. Check emissions readings, see if anything was reset. If so, why?
    • Check the fluids for discoloration and odor.
    • Probably the most obvious, crawl underneath and take a look for leaks, rust, damage, abuse, worn parts, etc.. if they say a part was recently replaced, it should look recently replaced.
    • Inspect all the common maintenance items, ball joints, bearings, belts, springs, shocks, tires, brakes, hoses, etc... If any are nearing the end of their life and you can replace, use it against the asking price.
    But, like others have said, a trusted mechanic and history report goes a long way.
    Hope that helps and good luck!
  9. Nov 29, 2018 at 6:29 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Welcome to TW!
    irayfz6 likes this.
  10. Nov 29, 2018 at 8:35 AM
    boostedka
    James
    NM
    If it is a 4wd, make sure you test that out as well.
    irayfz6 likes this.
