Looking to buy a taco - which years good/bad
Discussion in 'New Members' started by db-denver, Sep 18, 2023.
  1. Sep 18, 2023 at 3:34 PM
    db-denver
    db-denver [OP] New Member
    looking at Tacos
    Friend has an FJ but I need to haul dirtbike(s).
    What years / packages are the 'good' ones ?
    Need 4x4 and standard bed.
    Auto preferred (for Mrs.) but manual fine, too.
    buckhuntin-tacoma likes this.
  2. Sep 18, 2023 at 3:36 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
  3. Sep 18, 2023 at 3:39 PM
    Al Hoff
    Al Hoff Well-Known Member
    Grand Rapids, MI
    2018 Tacoma Off-Road QUICKSAND
    2018. But I’m biased. Real light bulbs. No CarPlay. Good nav in head unit. No sos button near your head. Both side bed cubby boxes. Its own separate trans cooler. Less “bugs” from the first 2 years 16 & 17 and in the sweet spot before they do their usual cost savings metrics.. nothing too tech fancy. Gives the illusion you can fix it yourself. :)
  4. Sep 18, 2023 at 3:42 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    "They're all good dogs, Brent."
    Narrow it down to things that are important to you. New or used? Do you want the radar safety stuff/ adaptive cruise or no? What kind of cab? Is a 2nd gen/3rd gen important? Power rear window? Little storage cubbies in the bed? What's your budget?
    saf023, buckhuntin-tacoma and Al Hoff like this.
  5. Sep 18, 2023 at 4:13 PM
    db-denver
    looking at Tacos
    Just the basics. No radar, adaptive cruise(?), pwr rear win - 2dr if possible, and not sure of the 'Gen' - hence the name of the post.
  6. Sep 18, 2023 at 4:19 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    They all have their issues:
    2005-2006 have head gasket leaks and cracked engine mounts
    2005-2011(?) have clutch throwout bearing that wears out the transmission extension housing
    2005-2015 have timing cover leaks (more likely than not)
    2016-current also have timing cover leaks, but less likely
    2012-2015 have an unreliable manifold air injection system
    2005-2017 have frames more susceptible to rust
    2016-current have a coolant crossover pipe that leaks on some trucks
    So 2018-current would be the best years. There are still more minor issues (low pressure fuel pump, high pressure fuel pump, vacuum pump, master cylinder, millwave radar...) but covered by recalls and campaigns. Consequently you'll find prices are as high as new trucks. :p
    Buy a Nissan Frontier, 2010-current are OK and priced more reasonbly. :cookiemonster:
  7. Sep 18, 2023 at 4:24 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    That narrows it down quite a bit already. 2018 was the first year to introduce TSS (radar), so 2017 and prior will not have it.
    2014 was the last year of the regular cab (2 doors, nothing behind the seat). Most years will have access cabs (2 real doors, 2 half doors, and enough room behind the seat to make a medium sized dog happy).
    Some people argue against 2016-2017 as those were the first two years of the 3rd generation Tacoma, and they have a reputation of some, ah, glitchy personalities. Personally that wouldn't scare me off. It scares some, but a tuned 2016 runs just as great as a 2023, and it has all of the aftermarket support as the current models.
    I would be the weird one to say look for a 16 access cab. But pretty much any pre 17 A.C. in your area will be worth a look if the price is right.
    saf023 likes this.
  8. Sep 18, 2023 at 4:29 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  9. Sep 18, 2023 at 4:34 PM
    STOCKTRD
    STOCKTRD Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Nachos, Lemon Heads, My Truck Is Stock!
  10. Sep 18, 2023 at 4:37 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    V6s from 2016 to 2023 aren't super reliable..so there's that
  11. Sep 18, 2023 at 4:50 PM
    mobySR5
    mobySR5 Well-Known Member
    2021 SR5 V6 4x4
    Stock
    https://youtu.be/b6tRAQ_r0Ms?si=8bz7I7HvUF7T8jRr
    Looks like 2018+
    I like my '21 SR5. Its solid as a refresh with electric driver seat. Apple/android car play. I've bypassed most/ (all?) the recalls. Only negative is that stock SR5 suspension is garbage. So Bilstein are a must.
  12. Sep 18, 2023 at 4:52 PM
    TRD_dee151
    TRD_dee151 Well-Known Member
    Oregon
    2023 TACOMA TRD OFF ROAD V6 Celestial Silver
    TRD Pro Grille 5% Window Tint WeatherTech Side Window Deflectors Cali Raised Catalytic Converter Shield Leather Seat Covers JDMCAR Center Console Organizer JDMCAR Glove Box Organizer High Flying smoke Sequential Turn Signal Tactical Sun Visor Molle Panel BumperShellz Armored Coated OEM TRD PRO Skid Plate Alpharex LUXX-Series LED Tail Lights Alpha-Black 255/70/17 Falken AT/4 all stock no lift. 17" Method 305nv Double Black with 0 offset Diamondback Switchback Baja Designs Squadron-R Fog Light
    mobySR5 likes this.
  13. Sep 18, 2023 at 4:55 PM
    Pwakchop
    Pwakchop Well-Known Member
    Nate
    Georgia
    2021 Cement DCSB TRD Sport
    Whole lotta' momentum
    Move along, they are plenty reliable. Its just people like you blowing it out of proportion, when the 1gr-fe came out, it had just as many problems. The difference is, it was 2004 and next to nobody was on forums like this complaining about it. In addition, the number of trucks that experience failure is SUPER low in comparison to the number sold. Toyota sells hundreds of thousands of these. Don't worry OP, they are one of the most reliable new cars you can buy, if not the most.
    mobySR5 likes this.
