Looking to buy a used Tacoma, need advice.
Discussion in '1st Gen. Tacomas (1995-2004)' started by smohan1, Jun 25, 2010.
  1. Jun 25, 2010 at 8:30 PM
    smohan1
    smohan1 [OP] New Member
    03 Silver SR5
    Stock..for now :)
    Hey guys,
    I'm a new member here and I am in the market for a used Tacoma. I had a 1996 reg cab which was totaled in an accident. I purchased a 1999 Ford Ranger, which I deeply regret, nothing but problems and I was not happy with it. The Ranger has since been totaled in yet another accident and I'm looking to buy another truck. I've decided to buy another Tacoma and I've found one but need some advice. I'm on a tight budget and am seriously considering this truck :
    http://www.fitzmall.com/fitzway/carfind/RESULTSB.ASP?V_XREFID=SVO402934788425926
    My previous tacoma was totaled at roughly 180,000 miles and it was running strong. I'm pretty sure this truck will last as well but I need some input. Should I buy this truck? Any super high mileage Tacomas here? Is the price appropriate for this mileage? This truck will be driven daily and on pretty rough roads.
    I appreciate any comments! Thank you in advance.
  2. Jun 25, 2010 at 8:31 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW!
  3. Jun 26, 2010 at 6:04 AM
    yota32
    yota32 Well-Known Member
    If it were me, I'd pass. Not because of the miles but because it's a pre-runner and an auto with the 4 cylinder (great engine but the trans sucks all the power out of it). Also, the front bumper looks crooked; does the carfax show an accident? And, toyota is buying back these year trucks (95-2000) due to rust problems with the frame. You could buy it (I would say for no more than 4k) and then have toyota buy it back and you'll get 150% of KBB. But I still wouldn't buy it only because there's always the chance the frame will pass and then your stuck with a truck you don't completely like. The 2.7 liter four is one of the most reliable engines ever; don't worry about the miles. Good luck in your quest!
  4. Jun 26, 2010 at 6:10 AM
    03redtaco
    03redtaco Well-Known Member
    Richard
    Myrtle Beach SC/ Starke FL
    03 Tacoma Prerunner SR5 DC 3.4L
    ^^^^It also looks like the bed is crooked. Maybe a suspension problem. Top off the cab looks level.
  5. Jun 26, 2010 at 5:23 PM
    smohan1
    03 Silver SR5
    Stock..for now :)
    Thanks for the info guys. I think I will pass with this truck and continue my search. It's difficult to find a low priced Tacoma, even with high mileage.
  6. Jun 26, 2010 at 9:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
  7. Jun 28, 2010 at 11:17 AM
    smohan1
    03 Silver SR5
    Stock..for now :)
