Looking to buy this 95 yota, worth it?
Discussion in '1st Gen. Tacomas (1995-2004)' started by oldbilwaulke, May 7, 2017.
  1. May 7, 2017 at 7:20 PM
    oldbilwaulke
    oldbilwaulke [OP] Member
    Clay
    Arkansas
    2010 Tacoma TRD Stock (for now)
    this truck for sale close to my house, want some opinions and advice. First thing I noticed when I pulled up was hubs were locked in, so I'm guessing has been drivin that way. Has 151k on original motor (22r) and tranny. Quite a bit of oil residue under neath. Drove great, shifted good, 4wd works. Body looks good except for back drivers side. Tail gait don't work, bottom front bumper dinged up. Owner said it used a little bit of oil. Looks like it's been using/leaking oil for awhile. Could be something small, or.... what you guys think? He hit me at $3,000
  2. May 7, 2017 at 10:09 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'd hit him at $2k and probably end up at $3k after sealing up oil leaks / new water pump / timing belt etc.
  3. May 7, 2017 at 10:12 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Check the frame. The fenders look like he's been battle rust and failed.
    Dalandser likes this.
  4. May 7, 2017 at 10:21 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    x2 plus that bedside is making my OCD flare up - I want to start sanding it down and see what's going on underneath there.
  5. May 8, 2017 at 6:45 PM
    oldbilwaulke
    Clay
    Arkansas
    didn't have time today after work to stop and check frame, but now that you mention that, I remember seeing some sort of registration sticker on bottom side windshield that said it was registered in Virginia, could explain some of the rust. all the salt on roads from snow perhaps? anyways ill stop tomorrow and check the frame, thanks for the help.
    dalandser, there's lots of bondo on that side, and quite a bit on the tail gait. I prob end up replacing bode side panels and tail gait, but don't plan on paying 3k and having to put that much money in it.
  6. May 8, 2017 at 6:56 PM
    KevinTaco98
    KevinTaco98 Well-Known Member
    Kevin
    1997 3.4L Tacoma
    None yet :D
    I just bought a 22r 4 cylinder 84' yota a rotted frame and an aluminum flatbed for $400. After welding new steel onto the frame it's very strong and structural again
    "Is it worth it" in my opinion is really up to you and how much work you want to put into it. I'd offer $2000 IF the frame is good.
  7. May 8, 2017 at 6:58 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    2k..
  8. May 9, 2017 at 3:28 AM
    KevinTaco98
    Kevin
    1997 3.4L Tacoma
    None yet :D
    For the one OP is looking at? Yup. But that would be max
  9. May 9, 2017 at 3:37 AM
    Clearwater Bill
    Billy
    Largo Florida
    Will they unlock?
    If the frame is good and you are looking for a beater to refinish with bedliner (www.monstaliner.com) and either tool around town or the local woods with, it might be a great candidate. But it deserves more inspection.
    Get it on a lift if at all possible. Do a compression and leakdown test. Inspect the brakes and suspension.
    Regardless of all the rage about Toyota truck value, ones like that are truly a niche market. Yea, someone will buy it, but not everyone will be flocking to throw money at him. Besides, I'm not sure that thing even has cupholders or iPhone compatibility, something critical to many buyers.
  10. May 9, 2017 at 10:22 PM
    oldbilwaulke
    Clay
    Arkansas
    yes I unlocked both sides, not with ease though. both prob need to be repacked. checked the frame this evening after work for rust. def some throughout but it wasn't eat up. thinking more around 1500 now at the most
