Looking to buy
Discussion in '1st Gen. Tacomas (1995-2004)' started by djgigglz, Mar 24, 2014.
  1. Mar 24, 2014 at 9:21 PM
    djgigglz
    djgigglz [OP] New Member
    Devin
    Chino Ca
    Hey everyone. Super new user to this forum and new to Tacomas all together. I was hoping to get some input on what I should look for when purchasing a truck. I'm looking to get a 1999 Tacoma extended cab v6. My budget is between $5000-$5500. I've always loved the way this model year looked and I'm ready to get a truck. I've been driving little cars for a while and I want something bigger. So if I can get some info on what I should look out for, that would be great.
    Thank you for your time!!
    -Devin
  2. Mar 25, 2014 at 11:05 AM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Frame is 1st thing I would look at. Known for rusting out. Carfax if possible. Then your normal questions. Paperwork,record of recent work or maintenance. Fluid checks,etc. Are you going 4x4? Make sure it works if so. I would stay away from vehicle with too many mods.also. This is only my opinion,others should follow. And by the way,welcome to tw.!
  3. Mar 25, 2014 at 11:07 AM
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    dont spend more on it than it's worth
  4. Mar 25, 2014 at 3:40 PM
    djgigglz
    Devin
    Chino Ca
    Thank you for your input guys. I'll be keeping an eye out for rust. I would love a 4x4 but I have no need for it. I'll post soon when I actually purchase one. Thanks again!
  5. Mar 25, 2014 at 4:44 PM
    Andy.G
    Andy
    Virginia
    Not needing 4x4 should get you a nicer truck for your money also.
  6. Mar 31, 2014 at 9:49 AM
    NOLA ItsNotOva
    NOLA ItsNotOva Well-Known Member
    Brandon
    New Orleans, LA
    2011 DCSB TX TRD
    Same as andy said. Also, ask to take a brief test drive. I got mine for graduation and it had trouble pulling off from a stop. Found that it was the MAF sensor and spark plug wires that needed to be replaced. Also, if you have a mechanic you can bring along, have him take a look at it. Always helps. Good luck!
