Looking to do a 3" Lift, have a few questions.
Discussion in 'Suspension' started by tpblanke, Dec 20, 2012.
  1. Dec 20, 2012 at 8:11 PM
    tpblanke
    tpblanke [OP] Member
    Looking at 3" lift and leveling. Was going to go ahead and get the lift out of the way before ordering wheels/tires.
    Was looking at OME 885 pre-assembled on bilstein 5100's up front with an AAL pack for the back.
    Truck is a 2013 DCSB OR.
    1) What AAL should I be looking at if I want the truck level with 5100s@1.75 with the 885s
    2) Should I go ahead and get the 886s if I plan on a heavier bumper down the road? If so, should I run the 5100s@.85 instead?
    3) With the 885s giving 1.75 and the 5100s@1.75, that is 3.5" of lift in the front; will I be needing to do any other front end modifications to prevent issues? I've heard I'll need UCAs but I've also heard that I won't.
    4) Am I going about this the wrong way? I've been researching all of this but it is my first time lifting a vehicle and I'd like to make sure it goes smoothly. My budget is rather tight at the moment, and I feel like this is my most cost-effective option at the moment, I just don't want it to cause problems.
    Thanks a ton for the help guys.
  2. Dec 23, 2012 at 10:17 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    1) For the AAL, I did the 1.5" Toytec AAL for the rear (also bout the 7.5" Ubolts to fit (I too did 4 new Bilstein 5100's")
    3) Ive heard you need UCA for a lift of 3" or higher, in order to be able to get an alignment back to the factory specs. On my truck, I did 4 new 5100's, Eibach coils for the front, and the back, see 1 above. (also put a 3 degree shim for the drivetrain alignment). I got everything from either downsouthmotorsports.com or toyteclifts.com. all in all, ran me about 600$ instead of 3000 for the toytec specific lift. took me 4 hours in a do it yourself garage with a friend. Hope this helps!
    (cant help with the 885's, i dont know what those are)
    Recap: Bilstein 5100's (2 front, 2 rear), Eibach coils (used all factory bolts after I assembled the front coilovers with a spring compressor), 1.5" (or maybe 2") AAL's for rear, 7.5" U bolts for rear, and 3 degree axle shim. Im pretty sure that was everything I used. Pretty simple and fun to do.
  3. Dec 23, 2012 at 10:31 PM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    Dont quote me. But I don't think you are suppose to run the 5100s above 0 if you are using 885/886 springs. They will give you enough lift as it is.
    At 3.5" your gonna need new UCAs
    What is your budget? That will help a lot.
    Are you installing yourself or paying someone?
    How much lift are you looking at getting?
    Daily driver? Mild off road? No of road? Lots of offroad?
    If your future holds a plate bumper and winch I believe people are going full OME shocks and 886 springs
  4. Dec 23, 2012 at 10:33 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You'll get 2 1/2" from the 885's alone , billies should be at zero
  5. Dec 23, 2012 at 10:39 PM
    VancouverTaco
    VancouverTaco Well-Known Member
    Cole
    Vancouver, BC
    08 SR5
    Billy's 5100 all 'round, 2.5 front
    I've heard of people setting billies at .85 with the OME coils, is that a bad idea?
  6. Dec 23, 2012 at 10:40 PM
    OZ-T
    Peter North
    British Columbia
    I would just get 1/4" or 1/2" top plate spacers instead
