Looking to do a small lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Scoleman, Oct 24, 2014.
  1. Oct 24, 2014 at 9:53 AM
    Scoleman
    Scoleman [OP] Member
    CT
    2011 sr5 double cab short bed
    Hey guys,
    Being honest here. I don't know anything about trucks but I just picked up my first tacoma. It's a double cab sr5 short bed. I''d love to give it a small lift and wanted some opinions.
    I'm not going to be doing a lot of off roading but do live in a rural part of CT with shitty dirt roads.
    After doing a little research, seems like the blisten 5100 front and rear seems like a good option. Should I also go ahead and upgrade the leaf springs. I'm willing to spend up to a grand with parts and labor.
    Cheers,
    Seth
  2. Oct 24, 2014 at 9:58 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    for about a 1k.. you could definitely get better than 5100's.
    OME 885's and an AAL or the Icon pack (leave the overload in) and you would have a better ride and performance.
  3. Oct 24, 2014 at 10:14 AM
    cgs2k2
    cgs2k2 old man
  4. Oct 24, 2014 at 10:18 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    How much is a small lift? Lift the front 1.5" to level the truck and fit bigger tires?
  5. Oct 24, 2014 at 10:23 AM
    teamcurtis
    teamcurtis Well-Known Member
    Curtis
    San Diego
    2015 DC 4x4 Super white
    285/75/16, snugtop xtravision, pop-lock
    does a grand include tires?
    a lift will look silly on stock tires (my opinion)
  6. Oct 24, 2014 at 11:11 AM
    cgs2k2
    cgs2k2 old man
    if you only lift it 1.5-2 inches it wont look too bad on the stockers.
  7. Oct 24, 2014 at 11:31 AM
    Ma Deuce
    Ma Deuce Well-Known Member
    Joe
    Colorado
    I just put a 2.5" lift on mine. Had to return a bad wheel so I'm on stockers for a couple more days.
    It doesn't look terrible with the stock tires, but it will definitely look nicer with the new wheels and more rubber.
  8. Oct 24, 2014 at 11:35 AM
    Scoleman
    CT
    I picked up some toyo open country AT 2's. I'd like to keep it under 3 inches.
  9. Oct 24, 2014 at 11:37 AM
    Scoleman
    CT
  10. Oct 24, 2014 at 11:43 AM
    cgs2k2
    cgs2k2 old man
    If you never/rarely haul anything, a small block will keep the ride similar to stock. An add a leaf (AAL) is an overall better option, but will make things more stiff. People tend to hate on block lifts in the back because its the cheap route, but in my opinion any block 2" or less, and you will be fine.
  11. Oct 24, 2014 at 11:58 AM
    SabMotocross
    SabMotocross Well-Known Member
    Bobby
    Santa Fe, Texas
    2014 Tacoma PreRunner SR5 DCSB V6 TRD S/C
    TRD BAJA Suspension...Rims and tires, blackout badging, TRD oil filler cap, front skid plate, N-Fab step bars, GrillCraft custom upper and lower grills. K&N air filter, TRD Supercharger.
    I second this....
  12. Oct 24, 2014 at 3:46 PM
    Ma Deuce
    Joe
    Colorado
    I used a Wheeler's AAL instead of the rear blocks that came with my 2.5" lift. A little stiffer than stock and it rides very well. Also has the bonus of not getting as much squat in the back when you have weight in it.
  13. Oct 24, 2014 at 3:50 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    If your going to spend up to $1K in parts I'd say you should do a better lift then the 5100's. Dont get me wrong that is a descent lift but since you live in a rural area I'd upgrade a little more and get a full 3" lift. Trust me you wont regret it!! :D
