Looking To Get A 2013 4 Banger Extra Cab 4X4 Manual, Any Reviews?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by STOCKTRD, Oct 31, 2012.
  1. Oct 31, 2012 at 6:17 PM
    STOCKTRD
    STOCKTRD [OP] Well-Known Member
    In Traffic
    CustomTacos Mafia!
    Cool Post Bro, Tell TJ Hunt To Update The Vlog!
    So I may be in the market for a new 2013. I was looking at a V6, 6-Speed, TRD OR Exta Cab. But Im not sure if I want to drop 31K on a new truck. So I might settle for a 2013 4 Cylinder, 5-Speed, SR-5, Extra Cab.
    Anyone have a SR5, 4X4, 4 Cylinder, Extra Cab, 5-Speed?
    Likes/Dislikes?
    How does the 4 banger drive? Is the power enough?
    Thanks.
  2. Oct 31, 2012 at 7:56 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    i test drove a 2011 4cyl access cab 4x4 and it felt fine! of course that was when i still had my 92 22re extra cab. after driving the truck i have now, and driving my dads 4 cyl single cab, i would have a hard time owning a 4cyl again. the 22re was popular then, the 1gr is popular now and its nice to have a motor with good aftermarket support and tons of info on since everybody and their brother seems to have one.
    not to talk bad about the current 4 cyl, as it seems to be a great motor. however i feel that toyota paid more attention to the 6. the shifter boot is more cleanly executed, (for some reason that means something to me) and it is much smoother. my dad's 09 vibrates compared to mine when under load. i know a 4 cyl will naturally vibrate more because of the number of powerstrokes per rotations, but my car is 4 cyl and runs like butter. i also appreciate the fact that with the six, i rarely have to rev above 2500 rpm. it has a relatively impressive torque curve.
    if your not hauling, nor have driven toyota's v6, the 4 cyl would be great. otherwise the v6 works quite well.
    and one major thing for the 4, it shares much of the running gear with the v6. if it was designed for the v6, but only has the 4 bange'rs power on it, consider it bullit-proof
  3. Oct 31, 2012 at 8:01 PM
    Corvus
    Corvus As the crow flies
    Cary, NC
    '12 2.7 5sp 4x4
    Loving mine. I have a '12 AC, 4cyl, 4x4, 5sp. Don't have the SR5 package though. I just lucked the hell out that it was everything I wanted sitting on transfer at my local dealership.
    You definitely feel like you're moving a big truck around with a modest engine, but it gets up to speed fine. You'll be shifting around 2.5k to 3k to get her rolling fine, but it doesn't struggle in the slightest. I haven't pushed mine just yet, but I have confidence in it's smooth powerband. The torque is there.
    I wanted the economy of the 4 and the capability of the 4x4. I'll probably be doing the basic upgrades: Headers, intake, exhaust, etc. to squeeze a couple more horsies out, but I am happy with mine.
    From what I hear, they are a pretty rare breed too.
  4. Oct 31, 2012 at 8:13 PM
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    Will you be hauling much weight, towing, or driving at higher elevations? If not, the 4cyl may be fine for you. Also, an MT can be a pain in heavy traffic.
    If possible, drive a V6 and an AT so you can compare the experience.
  5. Oct 31, 2012 at 8:19 PM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
    I have '11 4x4 5speed 4cyl in regular cab. I have no trouble with power and get decent mpg. ImageUploadedByTapatalk1351739996.678429.jpg
    ddiaz84 likes this.
  6. Nov 1, 2012 at 4:47 AM
    GuapOh
    GuapOh Well-Known Member
    Nor Cal
    2011 SR5 4x4 MT
    Skid Plate, Hood Protector, Wheel Locks, Snugtop XV, Yakima Rack, Weathertechs, Sick Speed Shifter, Avid Bumper, Avid Sliders, Bilstien 5100's, TSB Spring packs
    I have exactly the configuration you mention and love it. I came to the small 4 from a 5.3 Silverado 4x4 and don't regret a thing. It can serve you well.
  7. Nov 1, 2012 at 5:13 AM
    soldierguy
    soldierguy Well-Known Member
    Colorado Springs, CO
    '12 Access Cab 4X4 V6 6MT
    I have the 2012 V6 version of what you're considering. Before buying it, I drove a 2012 4 cylinder 5-speed 4X4 Access Cab, base model. Obviously I chose the V6.
    I loved the simplicity of the 4 cylinder. Simple, no-nonsense, no frills. The engine was smooth...I expected a little harshness because of its displacement, but it was quite smooth. It went about its business nicely, no fuss, and I would describe it as adequate. The shifter was nice too...smooth...and the clutch was definitely lighter than the V6.
    A couple things made me go with the V6.
    - my driving style. I don't like to have to rev an engine high to get some grunt out of it. The 4 cylinder requires more revs and more of its available power to haul around the weight of the truck. On the test drive, I was definitely feeling the need for more torque for how I prefer to drive.
    - Next spring & summer I'll be doing a LOT of driving, much of it loaded, and at least several thousand miles of my driving next spring & summer will see a loaded bed and a cargo trailer behind it. On paper the 4-cylinder would have handled it...the stuff I'm expecting to haul around wouldn't exceed the tow rating or payload capacity of the 4 cylinder. However, based on my perceptions during the test drive, I decided that under the conditions I'll see in the spring & summer, the 4 cylinder would slide rapidly into the inadequate category.
    - My current (and projected future) daily driving and towing is at high altitude. The extra grunt of the V6 is really nice to have to compensate for the altitude.
    - There were no 4 cylinder 4X4 access cab SR5 Tacos available anywhere nearby when I bought mine...the 4 cylinders were all base models. Although I like simple vehicles, the SR5 adds some useful stuff, but it still keeps the fold-down front passenger seat...a must have for me.
    So I'd say this: if you don't plan to tow much of anything or if your towing will be shorter distances, the 4 cylinder will do the job...not quickly, but it'll do it, and you'll be rewarded with decent fuel economy, and a simple, honest character.
  8. Nov 1, 2012 at 5:37 AM
    bash42
    bash42 Well-Known Member
    Eastern PA
    '13 Tacoma Access Cab 2.7L 4x4 5spd
    I just picked mine up last monday in the same configuration except i dont have the SR5. I paid $24,400 for the truck. To me, it wasnt worth the extra $800 bucks for the chrome, back up camera and the colored fenders. I have the convenience package and it is great. I also owned a 2011 in the same configuration (but it had SR5)and I traded it in one year old with 20,000 miles and got $1600 less than I paid brand new. Through the lifetime both both trucks i have gotten roughly 21MPG around town and around 24ish on the HWY. this MPG is better than the 2010 Rav4 my wife had.
    I also took my stock 2011 off roading at Rausch Creek and it handled everything that my brother in law's jeep cherokee handled. Oh yea, they hold awesome re-sale value. The dealer i bought my new one from is selling a 2011 for the same price (invoice + $500 rebate) as I paid for my brand new 2013. :D
    Unless you plan on towing more than 3,500lbs, the four banger is the way to go (search for the "million mile thread")!
  9. Nov 1, 2012 at 6:04 AM
    Desert Drifter
    Desert Drifter Well-Known Member
    Bill
    Central Arizona
    Tacoma 4x4, SR5
    Icon MT suspension, Pelfreybuilt front bumper, Relentless skids, Avid sliders, Avid custom rack. Pelfreybilt HC Rear bumper.
    Iteresting thread. I bought a 2012 Access Bab 4x4 SR5 with the 4.0L V6 motor. Many years ago I had a couple Toyota 2WD pickups with the 4 cyl motor. These were both very basic standard cab pickups and they were great reliable vehicles. Both of them were 5 speed manuals and I rarely towed anything and hauling was modest as well.
    but todays Tacoma is a bigger truck, heavier truck especially with 4WD, and I wanted more from it, so I went with the V6 motor and the 5 speed automatic. On the highway I actually get 21 mpg. It runs great and I am happy.
    If I was needing top economy in both purchase price and fuel use I would get the standard cab and 2.7L inline 4, and manual transmission. But my daily driver vehicle is a VW GTI that gets 30 mpg, so I expect my truck to last a good long time and fule cost is less important with fill-ups a month apart.
  10. Nov 1, 2012 at 6:17 AM
    Corvus
    Cary, NC
    '12 2.7 5sp 4x4
    Excellent advice here and fits my application perfectly. I wasn't planning to haul much when I got the truck, maybe a trailer or two for dirt bikes. I really got it to haul my motorcycle around and to get me better fuel economy than my 97 Camaro did. It's already doing that and it doesn't run on premium :p
    Just like he said, if you don't plan on hauling much, doing steep inclines, or being at high altitude all the time, I'd go 4 banger. It's a fun little engine. You'd be surprised how easy it is to get the revs out of it. I'm the same way actually. I hate having to get into the high revs to move my vehicle. That's actually why I didn't make an offer on my dad's AC Sonoma. The little 4 in that thing always struggled just with both of us in it. The Taco 4 has been a little champ so far. And that's before any modest power boosting I'll prob be doing :D
  11. Nov 2, 2012 at 3:26 PM
    bash42
    Eastern PA
    Just did my second fill up and got 21.58MPG! Mostly city driving.
    382 miles before fuel light came on. I love it.
  12. Nov 2, 2012 at 3:49 PM
    jkulysses
    jkulysses Well-Known Member
    Jake
    Oregon
    98' Xtra Cab 2.7l 5spd 4x4 SR5
    I went to the dealership with every intention of getting a 4 cyl access cab 4x4 manual. I test drove one and liked it but where I live there are a lot of hills and I felt like a high school kid trying to race civics around because I had to rev it up so high to get enough rpms to shift to the next higher gear. It just really wasn't for me and I felt kinda bummed but then I test drove the V6 model and instantly fell in love. It seems to have power everywhere and is just so much smoother and quieter even just sitting there idling it seems smoother and more refined. That was just my conclusion and I'm sure if you live in a pretty flat area or just don't care about running the motor in the higher rpms to get power out of it then it will be fine. The 2.7 is a bullet proof motor and has been around for a while which is what attracted me to it.
  13. Nov 2, 2012 at 4:24 PM
    bash42
    Eastern PA
    yea i can see that.....it all depends on whatcha need. There arent any real serious hills around here. I would have gone with the v6 if i wasnt driving 40+ a day. the 4.0 is proving itself to be an awesome engine as well!
    TACOS FTW!
  14. Nov 2, 2012 at 4:37 PM
    jkulysses
    Jake
    Oregon
    That's not bad at all! The best I've gotten so far with my v6 is 19.5 mostly highway miles. I typically get closer to 17 with mixed city and highway and I pretty much drive it like an old man lol. I usually skip gears to try and save gas also like I'll shift 1 3 5 or if i start on a downhill i go 2 4 6 and so on.
  15. Nov 2, 2012 at 5:29 PM
    bash42
    Eastern PA
    yup! same here. I skip gears whenever I can. :D
  16. Nov 2, 2012 at 5:31 PM
    mikesfarm
    mikesfarm Well-Known Member
    Florida
    2011 4wd Tacoma AC
    I have a 2011 4cyl 5spd access cab 4X4 with 10,000 miles on it. I love it. 23mpg city.
    It has plenty of power for me in flat Fla.
    Regards
  17. Nov 2, 2012 at 7:11 PM
    Krol
    Krol New Member
    I have a 2009 AC 4x4 2.7L 5spd. I have a lift and 33's on it. I do quite a bit of driving and live in a remote area of Northern BC, Canada. It's about 600km's of logging roads to get to my community from the nearest town. I couldn't be happier with the 4cyl. Living in the Rocky Mountain trench, I have to say the driving isn't always easy. In the winter I'm often plowing through snow that's a foot or more deep, and in the spring I have to deal with wash-outs, deep mud and flooding. I haul supplies back from town and am loaded down at times with a 1000 pounds of supplies. I pulled my heavy utility trailer (back half of a 1 ton Ford) loaded down with a Ski-Doo, fuel and supplies from Vancouver BC all the way home (1600kms). This truck never misses a beat! I do have to plan when I pass trucks on the highway and make sure I time things right. Because of the larger tires, I did notice a difference when towing my loaded trailer, but that was only from a standstill and on an incline; personally I wouldn't mind a re-gear. This past summer I drove from Vancouver BC to Inuvik NWT, part of it along the Dempster highway. The round trip was about 8000kms. I had everything in my truck that I needed to live out of it for a month, including topper, sleeping platform, food, some spare fuel, water, two full-sized spares, kitchen and recovery equipment. I averaged 11.2L/100 km or about 21mpg. I'd say that's not too bad.
    As mentioned before, all the other running gear is identical to the heavier V6 and double cab platform. Being this isolated, I needed a truck that was capable, reliable and fuel efficient. I love the truck and she hasn't let me down, especially important when it's -40C and you're hundreds of km's from the nearest civilization.
    Hope this helps; you can't go wrong with either platform!
  18. Nov 3, 2012 at 1:59 AM
    Sunacus
    Sunacus Well-Known Member
    Sun
    Surrey, BC, Canada
    '12 Tacoma
    All stock!
    I have a 2012 4cyl Access Cab 4x4 SR5. I love it. My driving style has changed a lot since my days with my 92 Integra. I had a '06 Subaru wagon before my truck. I was used to go booting that around.
    It has sufficient power. I've done a road trip to Penticton from the Vancouver area and it was great. I got great mileage. Around town, I get about 650ish kms.
    I made a trip up to Mt Seymour to hike this summer and it's quite different from my Subie. It has power, but I didn't want to gun it up the hill like I usually do. I will find out this season how it gets up the mountain with snow on the stock Dunlops.
    Overall, I don't do a lot of towing or hauling. The heaviest load I had so far since I've owned my truck is 250lbs. I've taken it offroading with the local TW guys and it is VERY capable. I thought the gas was going to be crazy since it is a truck. But I have to say, I get better mileage in the Taco then my Subie from what I think.
  19. Nov 3, 2012 at 6:16 AM
    Corvus
    Cary, NC
    '12 2.7 5sp 4x4
    Hearing from you Canadian guys that actually push these trucks out in the bush really convinces me I made the right decision with mine. Great to hear your feedback! :D
  20. Nov 6, 2012 at 6:44 PM
    bash42
    Eastern PA
    What's the verdict?
