Looking to get a bumper made, need some advice.
Discussion in 'Long Travel Suspension' started by Lil'Taco, Mar 23, 2013.
  1. Apr 17, 2013 at 10:54 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Honestly i think it needs more bracing just those front plates in not enough. You hit a dune in pismo that thing will cave right into the grill. I had to fix Rob's because of the same thing.
  2. Apr 17, 2013 at 10:57 PM
    Lil'Taco
    Lil'Taco [OP] Well-Known Member
    Scotty
    Corvallis, OR
    2010 PreRunner Sport DCSB
    Grillcraft grill, Weather Tech floor mats, HID headlights and fog lights, aFe CAI, Borla Cat-back exhaust, Total Chaos +2" Long Travel, Coil Bucket Gussets, Spindle Gussets, LCA Cam Gussets, Glassworks 4" fenders, B.A.M.F. rock sliders with fill plates, Blitzpro 21S LED light bar w/ B.A.M.F. behind the grill light bar mount, Red Label Off-road tube bumper, Redline hood struts.... It has more stuff done to it now.
    What do you mean more bracing/ plates not being enough? like the plates where it mounts to? or the Aluminum plating that will go on over the tubing?
  3. Apr 17, 2013 at 11:01 PM
    JLee
    Jerry
    Bay Area NorCal
    I needs more mounting points those 6 bolts in the front are not enough. If thats all the tube they are putting on it that bumper will not be strong and it will bend very easy if you bump into something. Even a tube that wraps around to the side of the frame and bolts to those holes would be good.
  4. Apr 17, 2013 at 11:26 PM
    Lil'Taco
    Scotty
    Corvallis, OR
    So there will still be another tube that will go up higher (skinnier red line) for a light bar to be mounted to, This tube I know will provide very little if any structure. I still think there needs to be another tube going across lower to support the plating (since it will be fairly thin aluminum up top/ the thick red line) the green line was a 1x2 (it might be thicker then that) steel tube that is replacing an original cross member that had a tow hook on it tying the frame rails together.
    The tubing goes under the engine into a belly pan that will have steel plating and at least 4 more mounting points. Is that what you mean by more mounting points?
  5. Apr 17, 2013 at 11:32 PM
    JLee
    Jerry
    Bay Area NorCal
    Is what I mean is the top tube needs to be supported somewhere. From the looks of it the bumper is 1.5" HREW and I'm sure .120 wall well it better be a least. if you hit anything higher then the frame mounting point the bumper will bend without more support up top. I'm on my phone or I would draw it out for you.
  6. Apr 17, 2013 at 11:37 PM
    IDtrucks
    IDtrucks My screen name is now slightly incorrect...
    Mark "Buck"
    Jackson Wyoming
    you need more support connecting the very top tube of the bumper...to something. even if you have more tubing running width wise there is not really anything keeping it from caving into the radiator/grille of the truck
  7. Apr 17, 2013 at 11:40 PM
    Lil'Taco
    Scotty
    Corvallis, OR
    Oh so you mean up here...
    There is going to be more bracing going around under where the headlights and grill are to make mounting points for the plating that will fill in the top, we could probably tie into the frame or something...?
  8. Apr 17, 2013 at 11:43 PM
    JLee
    Jerry
    Bay Area NorCal
    BINGO!!! find a way to add support up high and you should be a lot better off if you and up hitting that bumper on anything.
  9. Apr 17, 2013 at 11:48 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    yup. its not steel plate lol. those two tubes coming up from the mounting location will bend very easily .
  10. Apr 17, 2013 at 11:48 PM
    Lil'Taco
    Scotty
    Corvallis, OR
    Sweet! I have tomorrow off so I'll be hitting up the shop and probably before they even get to much further on anything (first thing in the morning). As I can recall though there really isn't a whole lot of anything structural to tie into up there and I'm starting to think that's why some people do a pretty beefy boxed part from the frame rails up to that area. any idea on how to make that work with it still being bolt on?
  11. Apr 17, 2013 at 11:53 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    hmm. not sure....you are right though. really not anything up top to tie into. Might just have to tie in some more support pieces to that new cross member, then sort of boxed in/square support from the mounting locations up to the bottom of the grille and flat out to the bumper...sort of like a triangle shape?
  12. Apr 18, 2013 at 12:06 AM
    Lil'Taco
    Scotty
    Corvallis, OR
    There is a single plate of steel from the mounting plates connecting the tube to it but now that I'm talking about it and looking at other peoples bumpers I think it won't do much. Baja Bumpers (green) have some tube going to somewhere further up for bracing up top on their bolt on bumper so I think there has to be somewhere else to attach to.
  13. Apr 18, 2013 at 9:03 AM
    Lil'Taco
    Scotty
    Corvallis, OR
    so after taking a look at the front end this morning there doesn't look like anything you can really tie into up top...
    we though that maybe extending the plate further up the front tube on the inside. we wouldn't be able to do any on the outside because the mounting bolts would be in the way.
    Jerry, I don't want to tie you up anymore then I have to buy is your shop number your cell phone I can text or call you at?
  14. Apr 18, 2013 at 11:05 AM
    Lil'Taco
    Scotty
    Corvallis, OR
    What did you end up doing on Rob's bumper? and what is his screen name? I'm just afraid tying into the body mounts to the top tube would do some serious damage if anything was hit, sending the force into the body isn't a good idea. I would rather have the bumper bend and prevent the body from taking the blow, then I also don't want the whole bumper collapsing into the grill either...
  15. Apr 18, 2013 at 11:10 AM
    #35
    JLee
    Jerry
    Bay Area NorCal
    Well your you have to make the choice I tied Robs bumper into the body mounts Jberry did the same thing. I'll tell you this you hit something hard enough to shear off those bolts your going to have more problems then the bumper bending into the body. And the way your bumper is now it would cause more damage with less of a hit then it would with the bumper tied into the body mount bolts.
  16. Apr 18, 2013 at 11:31 AM
    #36
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Just sayin
  17. Apr 18, 2013 at 11:33 AM
    #37
    JLee
    Jerry
    Bay Area NorCal
    Or that ^
  18. Apr 18, 2013 at 3:52 PM
    #38
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    I take it this is the 1st tube bumper this shop has made?
  19. Apr 18, 2013 at 4:17 PM
    #39
    Lil'Taco
    Scotty
    Corvallis, OR
    Well maybe tube bumper of this style. They guy has made a couple other bumpers, roll bars, and frames for some 6x6 vehicles at least.
  20. Apr 23, 2013 at 10:12 PM
    #40
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
    So how much are you selling these for?
