Looking to go down from 285/70/17 to 285/75/16
Discussion in 'Wheels & Tires' started by Dansly56, Jan 19, 2021.
  1. Jan 19, 2021 at 12:34 PM
    Dansly56
    Dansly56 [OP] Well-Known Member
    Dan
    Valencia, California
    2013 Toyota Tacoma Baja Edition 4WD
    Light bars, electronic side steps, bed cover, light bars, grills, roof rack, falken tires, method racing rims
    What are the benefits of going down to a 285/75/16 from a 285/70/17? Same wheel and tire package. Is the 16” rim with more sidewall on the tire a better option for off-roading?
  2. Jan 19, 2021 at 1:34 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Not sure what you mean. Only difference is wheel size. Tire specs are the same.
    whatstcp and Rock Lobster like this.
  3. Jan 19, 2021 at 1:35 PM
    gotoman1969
    Well you gain a little sidewall height but that’s negligible imo.
  4. Jan 19, 2021 at 1:36 PM
    Dansly56
    Dan
    Is there any benefit to having more sidewall while off-roading on the 285/75/16 vs the 17?
  5. Jan 19, 2021 at 1:37 PM
    Dansly56
    Dan
    more tire and less rim, would that be better for off-roading?
    sawbladeduller likes this.
  6. Jan 19, 2021 at 1:39 PM
    gotoman1969
    The 1/2” gained on each side of the rim imo makes no difference.
  7. Jan 19, 2021 at 1:40 PM
    Ferball
    Ferball Well-Known Member
    Brent
    Unity, New Hampshire
    2019 Cement TR5
    Yes. The extra sidewall is advantageous when airing down.
  8. Jan 19, 2021 at 1:42 PM
    Dansly56
    Dan
    How far down in psi would I have to air down vs a 17” rim?
  9. Jan 19, 2021 at 1:43 PM
    Dansly56
    Dan
    Interesting... I was thinking more sidewall would ride better off-roading
  10. Jan 19, 2021 at 1:46 PM
    Ferball
    Brent
    2019 Cement TR5
    I dunno. But the best way I have seen to figure your psi is to park on top of a 3/4 inch square tube and air down until your tire touches the ground. With this technique you can understand how extra sidewall would help.
    Dansly56[QUOTED][OP] likes this.
  11. Jan 19, 2021 at 1:49 PM
    sawbladeduller
    sawbladeduller semi-realist
    North Cal
    '15 DCSB '98 2.7L
    fully zip tied
    not sure of benefit or not. probably negligible, but I'd always choose less rim and more sidewall. so a 75 instead of a 70, and even better is the 85, just not on a 285
  12. Jan 19, 2021 at 1:51 PM
    Dansly56
    Dan
    like a 265/85/16?
  13. Jan 19, 2021 at 1:57 PM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    I doubt you are changing enough to actually see the benefit. Going from 20s to 16s would be noticeable for the benefit of more sidewall, but there just isn't a lot of difference in the two sizes you are talking about. I would not make the change based on performance only.
    Blackbeard83 and gotoman1969 like this.
  14. Jan 19, 2021 at 1:58 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    The tolerable PSI levels have more to do with tire construction than size. A tire with more ply/ heavier rating has the ability to hold a bead better than a lighter weight tire so you’d be able to run a lower PSI with less risk of breaking a bead offroad. That being said, the difference in 1” of wheel size would be negligible for most trucks. You’re not going to notice enough a difference to make a full wheel/tire swap worth it IMO. If a lower PSI is your goal (which would help with tire flex off-road) then you’re probably better off getting full (real) bead locks rather than gaining an inch of sidewall.
  15. Jan 19, 2021 at 2:01 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    This. @Dansly56 As a general rule you're right about smaller vs larger sidewall but the difference you're talking about in this specific situation is pretty negligible and you're not likely to notice much of a difference, if any at all. Personally, I'd select which wheel size is better based on the availability of tires for that size wheel and/or if you need a 17" wheel for better brake clearance.
  16. Jan 19, 2021 at 2:02 PM
    Dansly56
    Dan
    so more rubber won’t help with off-roading after airing down? What about gas mpg would that be a difference
  17. Jan 19, 2021 at 2:06 PM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    Yes, it helps, but the change you are talking about is so small as to not really be noticeable. For the money, there are probably better things to spend it on that would make a difference. If you want to change for looks, then go for it, but I doubt you see any real noticeable difference while driving. Also for MPG, any idea the difference in weight between the two packages? I wouldn't think you'd get much of a weight savings one over the other.
  18. Jan 19, 2021 at 2:09 PM
    Dansly56
    Dan
    this does makes sense. I watched a few YouTube video and some recommendations are the smaller rim and more sidewall as most trophy trucks, buggies, dirt bike off road version, quads, baja trucks, etc use a smaller rim and bigger tire id figure this would be the same to building a off road Tacoma truck. Now I know those are all different vehicles and I huge difference in tire sizes but for whatever reason I thought the concept of tires and rims would be the same. I wanted to run it by this forum since most people on here have gone through various wheel packages and wanted to see the benefits and thoughts of the setup I’m inquiring about. What about a 295/75/16 vs a 285/70/17 would that also be the same as you mentioned?
  19. Jan 19, 2021 at 2:14 PM
    Dansly56
    Dan
    this is more a trade package that someone wants to trade with me. Same E rated tires also. Not sure about weight, just a $260 difference in package
  20. Jan 19, 2021 at 2:22 PM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    I would go off looks and tire availability for whichever rims you decide on. As long as the 16s fit and have enough brake clearance, expect same results, just with a slightly different look.
    Blackbeard83 likes this.
