*** Looking to improve gas milage... ***
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04tacomaSR5, Jan 14, 2012.
  1. Jan 14, 2012 at 12:06 PM
    04tacomaSR5
    04tacomaSR5 [OP] Proud Canadian
    British Columbia, Canada
    2005 Tacoma TRD Sport 4x4
    Toyota hard tonneau cover, custom seat covers, nerf bars, more to come...
    I recently did the math for my mpg and was a little upset with the results I found...
    I have a 2004 2.7L tacoma 4x4 and from my calculations I was only getting 15-16 mpg... to me that doesn't seem like that much for a 4 banger.
    I have a K&N air filter and the rest is stock ( in terms of engine components )
    does anyone have any thoughts on how to improve it or things to check that might be affecting my milage?
    Any advice would be appreciated!!!
  2. Jan 14, 2012 at 12:12 PM
    Swanson52
    Swanson52 Well-Known Member
    I advise you employ the search function of the site.
  3. Jan 14, 2012 at 12:23 PM
    04tacomaSR5
    would doing the deck plate mod, flowmaster/magnaflow muffler, new plugs / wires help?
  4. Jan 14, 2012 at 12:27 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Intake and exhaust will do nothing to improve mpg.
  5. Jan 14, 2012 at 12:27 PM
    04tacomaSR5
    i did... mostly talked about the secondary filter removal...done.
    i may just replace the plugs because i'm not sure when there were done last... bought the truck about a year ago and I haven't looked at them yet...
  6. Jan 14, 2012 at 12:34 PM
    04tacomaSR5
    lol touche... i assumed the last guy did it because it was already gone lol
    are there any tutorials/diy things on how to do it... newbie when it comes to fluid changes..
  7. Jan 14, 2012 at 1:05 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    No wires.
    Im at about 16 mpg mixed highway/city too.
  8. Jan 14, 2012 at 1:12 PM
    04tacomaSR5
    Snowman... is yours the 2.7L also?
  9. Jan 14, 2012 at 2:32 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    I would do a tune-up on it. Sparkplugs, possibly wires depending on their condition and mileage, fuel filter, synthetic oil change and maybe even seafoam it if you're ambitious and then see where you're at. You could also check for any codes to just to confirm that nothing's up.
  10. Jan 14, 2012 at 2:35 PM
    04tacomaSR5
    know of any forums/links on how to change fuel filter?
  11. Jan 14, 2012 at 2:38 PM
    Tacomadude89
    Austen
    California
    There probably is in one of the stickys listed at the top page of this section.
  12. Jan 14, 2012 at 2:59 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    There arent any wires to check. And unless your truck is missing and throwing codes wires wouldnt make a real difference anyway.
  13. Jan 14, 2012 at 3:25 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    I have a little experience in school from Aerodynamics and just by looking at your Avatar I'd say loose the front bull bar and the camper. Both of those components are spoiling the airflow over the truck.
  14. Jan 14, 2012 at 4:19 PM
    worthywads
    ^ +1
    Do you have larger than stock tires, if so that slows down your odometer and makes it seem like your mpg is worse.
  15. Jan 14, 2012 at 6:42 PM
    meatman
    meatman I deal with dead animals
    Greg
    Murphy N.C.
    (built) 04 Tacoma SR5 4x4 and 01 TRD 4x4 DD
    I think it has more to do with weight than airflow. I lost approx. 1 mpg when i put on my camper top. I avg. 19.3 mpg with it on then again i also have a a v6 so i could be the 4 bangers have to work harder to pull the extra weight
  16. Jan 14, 2012 at 10:24 PM
    Yamaha Dave
    It's actually both but I was not going to elaborate because I'd probably loose everyone..
  17. Jan 14, 2012 at 11:11 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
  18. Jan 14, 2012 at 11:43 PM
    04tacomaSR5
    sounds great then!
    I'm liking the black tool box you have going on there Snowman!
    I had to make a hard decision between two purchases last week... new black rims or sound system.... Had to go with the system for now... but black rims to some very soon!
