Looking to increase a little MPG to the 4.0. Ideas?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kcruz4477, Aug 11, 2019.
  1. Aug 13, 2019 at 5:09 PM
    #81
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Theres no way thats possible... and even if it is, its marginal. The AT2 isnt going to have nearly as good of highway, wet road, ice, light snow traction that the MS2 will either. only thing the AT2 is going to be better at is off road / mud.
    knayrb[QUOTED] likes this.
  2. Aug 13, 2019 at 5:21 PM
    #82
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Let do some math but keep it simple and somewhat realistic. You get 20MPG on a 20 gal tank of gas at $3.00/gal. That’s $60 a tank. If you get 22MPG by being really conservative, that’s going to give you 40 more miles out of the tank. You saved about $6 on that tank. For me $6 a week isn’t going to change my standard of living enough to notice.
  3. Aug 13, 2019 at 5:32 PM
    #83
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Forced induction doesn't exaggerate. It induces forces.
  4. Aug 13, 2019 at 8:26 PM
    #84
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I wouldn’t turn down 2 free gallons every fill up though, or a free pass on bridge toll once a week, etc.
  5. Aug 13, 2019 at 8:33 PM
    #85
    nd4spdbh
    SoCal
    says the guy with a fuel sipping 4 banger 5 speed 5 lug taco..... #jealous.
  6. Aug 13, 2019 at 8:46 PM
    #86
    3roguen
    3roguen Well-Known Member
    Evan
    Altoona, PA
    06 SR5 4x4
    4th and D
    Lighter wheels and tires and the diameter of the wheels. I have 18s because i do a lot of towing and so smooth on the highway with great mileage. I think it makes the tire lighter overall. not as much rubber as 16s = less weight. The afe pro dry air filter apparently adds 1 mpg. I haven't noticed anything other than engine performance though
  7. Aug 13, 2019 at 9:44 PM
    #87
    bagleboy
    Scott
    Norcal, Santa Rosa
    :D 24+ last fillup on mixed driving w/700lb load which is midway between best and worst. I’d still like to swap the 15” steelies for some alloys. FWIW “best” was cruising ~70-75 with a similar load.
    nd4spdbh[QUOTED] likes this.
  8. Aug 13, 2019 at 9:46 PM
    #88
    Bishop84
    Bishop84 Well-Known Member
    You forgot.
    -Remove drive belt. Charge battery at work to save $$$
    -Use a hand pump for water circulation.
    Thyces likes this.
  9. Aug 16, 2019 at 10:46 AM
    #89
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    Many great suggestions to improve MPG. Personally I just drive my Tacoma enjoying every mile I drive, not every mpg I could have improved driving it. I do that with my Prius.:D
