Looking to install dual battery's in my taco, need help
Discussion in '1st Gen. Tacomas (1995-2004)' started by MDtaco, Aug 20, 2012.
  1. Aug 20, 2012 at 11:04 AM
    MDtaco
    MDtaco [OP] Member
    Mick
    Indian Head, Maryland
    TRD Off Road SR5
    I am going to install 2 dual batteries in my 2004 tacoma and i am ordering a dual battery tray from http://www.columbiaoverland.com/ but it does not come with a wiring kit. Anybody know where I can get one for my truck?
  2. Aug 20, 2012 at 11:23 AM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    yes, you scroll down on the same page that shows that battery tray. they sell kits too :D
  3. Aug 20, 2012 at 1:19 PM
    MDtaco
    MDtaco [OP] Member
    Mick
    TRD Off Road SR5
    I saw that, but i am hoping i can find some cheaper then that.
  4. Aug 20, 2012 at 1:48 PM
    paranoid56
    San Diego
    14 double cab taco
    you can build your own system too. depends on what bells and whistles you want.
    can you give us a idea on how you want your system layed out?
  5. Aug 20, 2012 at 1:50 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    try 12voltguy
  6. Aug 20, 2012 at 2:56 PM
    MDtaco
    MDtaco [OP] Member
    Mick
    TRD Off Road SR5
    I like it. Gonna order from there this week. Thanks brutalguyracing
  7. Aug 20, 2012 at 3:04 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
  8. Aug 20, 2012 at 3:14 PM
    MDtaco
    MDtaco [OP] Member
    Mick
    TRD Off Road SR5
  9. Aug 20, 2012 at 4:20 PM
    jandrews
    You are absolutely correct. Didn't even notice this was in 1st gen. Woops.
  10. Aug 20, 2012 at 4:26 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I made a dual battery tray for 12 bucks out of 1" angle iron, all thread and wing nuts. I put two Optimas in the fatcory location. I'm running an ASE electronics 100w battery isolator that will charge each battery individually. It also has the option to manually connect both batteries together to self "jump-start" if one battery falls below 11VDC.
  11. Aug 22, 2012 at 5:30 AM
    MDtaco
    MDtaco [OP] Member
    Mick
    TRD Off Road SR5
    Do you have any pictures you can post of it.
  12. Aug 23, 2012 at 5:23 AM
    MDtaco
    MDtaco [OP] Member
    Mick
    TRD Off Road SR5
    i just want to have one battery for aux and the other one just for running the truck. am i able to connect positive terminal to positive terminal and negative to negative teminal on the battery and have the regular terminals from the truck on the one battery? and if so will i be able to charge both?
  13. Aug 23, 2012 at 7:45 PM
    paranoid56
    San Diego
    14 double cab taco
    no, you need some sort of battery isolator to keep the batterys from draining each other (and to keep you from killing both batterys)
  14. Aug 23, 2012 at 8:09 PM
    MDtaco
    MDtaco [OP] Member
    Mick
    TRD Off Road SR5
    Do you think a 95amp Isolator would work well or should I go with a higher amp?
  15. Aug 26, 2012 at 2:29 PM
    medinacaver
    medinacaver New Member
    South Texas
    '03 Prerunner - Dbl cab - 2.7L
  16. Sep 14, 2012 at 9:30 PM
    HoookerDub
    HoookerDub Member
    David
    Colorado
    2012 Taco SR5 4x4 4.0L
    So I'm going to ask a stupid question but what are the Pro's of running 2 batteries? And is it worth it putting into the truck? Thanks.
  17. Sep 14, 2012 at 9:56 PM
    pippen
    pippen that was'nt a vitamin!!
    Pippen
    Eastern NC
    04 PreRunner Ext.
    Pros: 2's always better than 1! If your starting battery is dead you can jump yourself.
    You can use the battery to help power high powered lights, kinda like having a capacitor so you don't drain too much power from the main battery and alternator (dimming of the headlights is how you can tell if your drawing too much off your current system).
    Theres just endless uses for it, hook it up to a TV while your out camping, not have to worry about not starting, it'll charge back up next time you drive.
    Cons: More weight, takes up some of your engine bay space (which theres a good amount of if you ask me).
  18. Sep 14, 2012 at 11:32 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    96.5 FrankenTaco & 03 Stock dbl cab
    BFG KM2 33x12.5 tires, Wheelers Type B rims, Allpro 1.5'' Wheel spacers w/extended thread lug nuts 2 Alpine 10'' Type Xs 2 Kicker 6X9s 4 Sony 5 1/4s Pioneer 4100 HU Sway bar removed 4 Hella 500 HIDs Frankenstein Leaf packs 1'' lift shackles Eibach coils 5100s front 10'' 5150s rear BAMF BPV bracket Deckplate mod Elite Front bumper Magnaflow 14'' muffler Elite Off Road Rear bumper with Tire gate with jerry can and fold down table, BAMF sliders, Custom Homemade Bed, rack/roof rack, CVT Mt. Shasta Roof Top Tent, 20lb CO2 tank, BAMF diff skid custom front skid, GM CS144 140 amp alternator Blitzpro 21s HAWK side LEDs Blitzpro Custom made side mirror lights, LightForce 240 Blitz llights, Piaa 510 ION fogs, XRC8 Winch w/in cab controls,
  19. Sep 15, 2012 at 11:27 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    my layout is similar...
    but I feel muh batteries are better secured. ;)
    wonder what group YT's that OP in the link was using...
    would seem they have reversed terminals..! ? hmmm
    they look to be a tad larger (spelled heavier) as well
    Mine are group 34/78 YT's
    only available in the standard terminal layout :(
    think muh fenders appreciate the lesser weight
  20. Sep 15, 2012 at 11:34 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yea it looks like he did use a bit different battery..to bad he never gets on here anymore haha
    you have an isolator tho too right?
